BLF GT Modifiedā¦ā¦.De-domed E4 XHP35A-00-0000-0D00E40E1 That I purchased from hereā¦ Cree XLamp XHP35 High Density LEDs I bought the triple and de-domed all three.
Boosted the driver with a R075 for 3.01amps at the emitter. De tuned with 4.5āā long Tinergy 24awg leads I reduced the current pull to 2.76-2.78amps at the emitter, where my Light Meter stayed steady. (Ghetto Tuned)
I marked the leads at what I thought were 1/2āā lines, but they were 1āā lines, and dropped the driver, unsolder the leads, snipped (a 1/2ā at at time then a 1/4āā when I got closer) then soldered the leads to test, till I got the desired pull (current increase) from the driver, and the light meter didnāt increase, Never upsetting the reflector/head set-up.
Yep when both drivers were stock, and both being CW, according to my light meter.
And now the E4 is boosted, YEP! Possibly more LUX gain when I shave the centering ring bar down, I opened up the holes in the bar and mcpcb slightly to allow more float, kept the mcpcb screws slightly loose, the spot didnāt look right after the re-flow, it needed better centering, loosened the head and tightened it a few times, floated it in, the spot looks great now crisper! Itās a Massive reflector, so any misalignment your going to see it, so is the meter!
Youāll see when you get yours and start messing with itā¦
Dropped a TA driver from Lexel into my MF01 today. Now I have no problems with the light. The UI is amazing I wish more lights came with such intuitive firmware that makes sense, but maybe it will happen now that Emisar and the BLF Q8 are out there. The LEDs are being driven as they should be and the light becomes too hot to touch at 30 seconds then holds heat for at least 4 minutes. With my approximating shoe box Iām reading around 15,000 lumens. That makes it twice as bright as my Q8 after bypasses and TLC.
BLF GT XHP70.2 Used the SD75 6volt XHP70 MCPCB and 2xSD75 (2S2P 8.4v) battery carriers in series, had to modify slightly to make the 2S (-) connection on the carriers, spring bypassās. Running a Modified 30mm Hyperion FETDD (https://www.arrow.com/en/products/bsc009ne2ls5atma1/infineon-technologies-ag) Simple 5 modes, 18awg leads 20+ amps at the emitter depending on batteries. seen as high as 21.7amps VTC5Aās but running 8x30Qās 20.2amps.
So far I have run these emitters thru the GT, and Iām not happy with themā¦the 5700k isnāt too bad, but I have 3 other emitter Iām going to try out,see if they work/look betterā¦ā¦the XHP70B01D0BP240E to me looks like the exact tint that the Stock BLF GT XHP35HI NW 4000k looks like, if your into that flavor?
As a added bonus, the GTās MCPCB fits the SD75 so I built one more SD75 XHP35 HI using Lexels E2-3A that I had in this GT before I converted it to XHP70.2
Really like the XHP35 HI E4-3A I purchased from Lexel, first time I have ever seen or used this bin/tint in a build, I should of purchased a couple more!!! :person_facepalming:
Today I putted in an SST40 in my heat colored L2 and TA OTSM 20mm driver. Still need to replace switch with a reverse clicky and make orange lighted tailcap and make some photos and beamshots from the end result.
And here is my shorty clear S2+ with stainless button with blue lighted tailcap and screw clip.
Same things and preparations as in this build
Some correction : You doesnāt need to grind down the steel button lower edge for clearance. it is good for more light coming out.
On the left grinded button with six led board. On the right stock button 2 led board:
Another standard Convoy S2+ mod. This one with an RMM 3 amp Moonlight Special driver and a Nichia 90+ CRI LED, but with a couple noteworthy (read time consuming) enhancements.
First, I trimmed down the driver retainer ring so I could screw down the driver rather than solder it in.
Second, I added a green lighted switch (read the most time consuming part).
I really like the warmer 4,000K tint that the Nichia LED produces. And considering how small the flashlight is, it still throws pretty well.
The 5 channel full ramping driver (FET+1 for white, red+green+blue) with 2 additional resistors for ultra low white moonlight and red indicator light, color channels pretty overdriven for about 1.5 Amps at each color XP-E2 (NOT recommended though):
Very nice beam:
Even nicer rosy beam with all LEDs on max current, about 1500 lumen (white LED is XP-G2):
I had made a similar light two years ago with the DrJones RGBW driver, a Dsche quad board with some cuts, and a re-build Solarstorm SC02 (and it is still one of my favourites!), but the D4 makes it way easier.
Thanks, it were your posts about the color driver with D882 which made me build this driver. Iām using this light as EDC for about 3 weeks now and itās the best EDC I ever had.
My adventures with that driver felt quite lonely, I do not think after me anyone has ever tried to use it like that. But iām glad it inspired at least you
Thatās interestingā¦ What is the driver? How does it do 1.5A per color instead of 350mA? Do the chips get hot burning off the wide voltage gap for color LEDs? How low can the color ramps go? What is the firmware and interface like?
This reminds me I should probably finish a few more details on my RGBA firmware. Itās not intended for flashlight use though; it makes patterns which look more appropriate in a lightsaber. The general idea is that the user can make their saberās illumination pattern(s) unique in much the same manner that one builds new sounds on an analog synthesizer. Except, um, simplified to make it more accessible using a single button.
