Hi old friend
How are you ? it is me again
Because there are 2 good news. So I will both you again to tell you
1, New product DPH5005 buck- boost power supply will be published at 11,11 US time.
There are 3 version, no communication version, USB communication version, USB+ Bluetooth communication version, the price is at least 33.98 usd only 3 days,. After 3 days, the normal price is about at least 38 usd . please seize the opportunity
2, 11.11 biggest sale promotion will beginning at 11.11 US time. There are many big coupons on aliexpress. This is our home page :
In our shop, there are many big discount and coupons
DP and DPS, DPH power supply: 23–27 off (24–27 off at phone):
My dear friend
there is a new products was published again- DPS8005 buck power supply. https://www.aliexpress.com/item/RD-DPS8005-programmable-constant-voltage-current-Step-down-power-supply-module-Voltmeter-Ammeter-buck-converter-80V/32849962454.html
there are 3 version, No communication version, USB communication version , USB+BT communication version.
Input voltage: 9-90V, output 0-80V/0-5.1A, Most function are same to other DPS series power supply.
But this time, there is new function for PC software, data download and data export.
You can download all file My Files and there is a simple video : New Products DPS8005 Digital control buck power supply 80V/5.1A - YouTube
As the old rules, when new products was published, there is 4 days lower price.
Now no communication version 27.88 USD (normal price 33 USD)
USB communication version:30.43 USD (normal price 36USD)
USB+BT communication version: 32.98 USD (normal price 39 USD)
Only 4 days, please hurry… hope you like it
Lastly, there are 2 kinds power supply case, but they are not suitable for DPS8005, because the fan board MAX input voltage is 60v. but you can use the case, not use the fan board
1, TC64 Type-C meter, Type-C port is full function port, support Type-C fast charge and most all type-c device, but not Type-c identity resistance (no type-c trigger), Quick charge recognition mode:QC2.0、QC3.0、APPLE 2.4A/2.1A/ 1A/0.5A、Android DCP、SAMSUNG
And Application for PD charger measurement; PD car charger measurement; Type-C U flash measurement, and etc.
Video:
2, As for new products rule, first 6 days , lowest price 7.99 USD/piece, after 6days, normal price 10 usd, please check
3, our UM series APP was updated, one APP can support UM24C, UM34C, UM25C, you just update the old APP to get the new APP
Are all the bench psu’s in this thread the type you have to build a case for? I was looking for a ready built one with everything nicely integrated together. Are those type just too expensive?
Yes, all of these come in kit form but they do offer kits now days that make it easy.
When I was searching there was a drastic price increase for a ready made all in one unit and they had much lower specs. For the same price I got a 15A power supply pre-made units only had ~3-5A, which is almost useless for flashlights.
Does anyone happen to know why the typical cheapie bench power supplies, like a 30v 10A, is limited to 10A even when the voltage is turned way down to like 8 volts?
Then we have the DPS5020 which can take that same 30v 10A and put out 20A at say 12v.
I’m not really understanding that. Does the DPS 5020 just have better circuitry in it? Is it a better design overall?
I’m considering buying a cheap 30v 10A bench supply, that can actually output those numbers, and then mount the DPS5020 controller on top of it. I’d mount the electronics of the DPS5020 inside the bench supply case.
I could reroute the output wires of the bench supply to the DPS5020 then route the output of the DPS5020 back to the original output terminals.
So I would power up the bench power supply and set it’s output to a bit more than I need, maybe leave it at 30v 10A, then do the actual controlling through the DPS5020.
Yes it costs a bit more, but I would have a nice looking enclosure in the form factor I want plus have a decent power supply for the DPS5020.
One reason for fixed output current can be because it is a linear supply. This means less electric noise on the output current, but more wasted heat (They usual have some transformer taps or use a SCR/Triac to regulate the transformer).
In the case of the DPS series, they are limited by the fixed output current. This is mostly due to current being much harder then voltage to control and the components are rated for that amount of current.
Other cheap power supplies are not so good and will not support the full current / voltage range except under ideal conditions.
Your best idea is to get a cheap fixed output power supply, like a 24v or 48v unit and then connecting the DPS unit to that.
I have 1 DP unit built inside an ATX power supply, it works great but is limited to 11v output. They have buck/boost options now though that could boost the power.
I have another DPS5015 setup with an old 48v server power supply that I use for most things and have no complaints. Although the ripple voltage is higher on this one it does not effect most things we do with flashlights.
The part where one brand (cheapie) is limited to 10A regardless of voltage.
It would be nice if instead of 30v and 10A (300 watt), a cheapie bench supply could also do 8v and 27A (also 300 watt), but it can’t.
I really don’t know much about bench power supplies. I want to learn, though.
I assume the DPS5020 is a switching type due to its small size, light weight, high efficiency and no big coil.
I come from an automotive background, so I know how an alternator generates AC voltage then it goes through a bridge rectifier (3 big diodes, sometimes 6 to improve reliability) and a voltage regulator to get 14-ish volts DC. I guess this more closely resembles a linear type power supply? I’m not sure.
Current is basically always going to be the limiting factor.
Voltage is really easy to handle, you just pick some higher rated components that cost a little more and you can handle higher voltages easy.
Current on the other hand is what makes components heat up and there is no real option for handling higher currents other then getting beefier and bigger components. This can drastically increase the cost and complexity along with needing changes to the entire design.
Same reason that a lot of the older driver designs we used to use worked fine for low currents of ~5A but have major issues when we try to run them at 15A.
The DPS is indeed a switching power supply.
Overall the DPS series is the best bang for the buck that I could find by a long shot for high current power supplies. Most cheap power supplies are limited to around 5-10A max.
If I could find a proper enclosure cheap enough I might go that direction. Unfortunately, the cheapest, and only, case I found in the form factor I want is $130 shipped. This one.
This is why I think it’s better for me to just buy an existing bench power supply, like a cheap 30v 10A, and convert it.
