Budget friendly adjustable bench Power supplies perfect for testing LED's and other uses!
Thanks for your shara, I will buy it when I need
thank you
BTY, i see your location is china, are you chinese?
Commnunication version for DPS3005 and DPS5005
Good News, DSP3005 and DPS5005 communication version is published. New software and hardware.
But before you buy this, you should down load upper computer software to check that your computer fit it or not.
DPS3005 communication version:
https://www.aliexpress.com/store/product/RD-DPS3005-Communication-Function-Constant-Voltage-current-Step-down-Power-Supply-module-buck-Voltage-converter-LCD/923042_1000004279003.html
Upper computer file and software :
http://www.mediafire.com/file/btwtvu4wrw4bdsw/DPS3005+PC+Software+V1.3(2017.06.08).zip
DPS5005 communication version:
https://www.aliexpress.com/store/product/RD-DPS5005-Communication-Function-Constant-Voltage-current-Step-down-Power-Supply-module-buck-Voltage-converter-LCD/923042_1000004290003.html
http://www.mediafire.com/file/4kt1j1v93h4d3mw/DPS5005+PC+Software+V1.3(2017.06.08).zip
Note: there are two choices:
  1. USB board : DPS+ USB communication board
    2, USB + Bluetooth: DPS+ USB communication board+ Bluetooth communication Board
    Note: there is no open for communication interface on housing , it need you add a open on the housing , if you can’t do this , please don’t buy this housing for communication version
    You can choose what you need, hope you like it and tell your more friends
    http://ae01.alicdn.com/kf/HTB13N9tRFXXXXaaXVXXq6xXFXXXw.jpg?size=122647&height=1000&width=1000&hash=661f7e06318cac35927270b1fd187f82
    http://ae01.alicdn.com/kf/HTB1CaODRFXXXXaCXFXXq6xXFXXXZ.jpg?size=251186&height=1000&width=1000&hash=eb8985e090c175347af3f0ca9a304fae
    http://ae01.alicdn.com/kf/HTB1PSqGRFXXXXcHXpXXq6xXFXXXj.jpg?size=180796&height=1000&width=1000&hash=d2d33cd005c9a0b7b6141bc5a3089ffd
    http://ae01.alicdn.com/kf/UTB8veHza.\_4iuJk43Fqq6z.FpXad.jpg?size=232960&height=588&width=1000&hash=aff91339194a626752b5f5c4f8dfdf71
    http://ae01.alicdn.com/kf/UTB8e1Lza.\_4iuJk43Fqq6z.FpXaJ.jpg?size=253177&height=585&width=1000&hash=29d7383a487c3cec5ceabe35de1c9395
Very important:
1.Before buying this product, please download the upper computer software and test, if it fits your computer , you can buy
2. the upper computer only support For Win7 and above
we just make a new video for DPS5015 ripple test ,. later I will publish DPS5020 ripple test, if you have question , please leave a message
Hey, does anyone know if this power supply saves settings when powered off or disconnected?
Such that when turned on, it would immediately output the previously set voltage and current?
Thanks.
It does remember the settings but you need to push the on/start button to turn on the output voltage.
Anyone using the ESP-470 power supply with this controller find a solution to the constant on fan ? Or maybe my unit is defective-do all esp-470 have constant on fan? I would have thought it would be temperature or current dependent but mine is on full speed all the time if it is plugged in. It’s very anoying!
Awesome, sounds good.
Planning to use the DPS5020 as a power supply for an LED, since it can do constant current and also very high currents like 15A+ :slight_smile:
Thanks.
Hi RD Tech,
Is the communication protocol published? As in the specifications for how to use it? I think it is just a serial connection at 9600 bps.
Some other sources are calling this Modbus - is it that? Is there a document defining the registers and their values?
Also, which of your power supplies are suitable for doing a CC - CV - saturation until 10% of capacity? eg, cutting off when current during final CV phase is below a certain amount?
Thank you
sorry , there is no this function
if power off when you are setting the data , and not saved it , it will be lost
yes, he should save this first , if he is setting the data , power off , those data can’t be saved
Brands shopping week will begin from 28st Aug to 1 st Sep ( US time). There is the Biggest discount in this year on aliexpress, there are many coupons on aliexpress. And our shop discount is from 17% off - 30% off. And there are many coupons:
8 usd for over 75 usd value at home page (https://rdtech.aliexpress.com/store/923042 )
And 2 USD , 3 USD . 5 USD coupons.
1, DP and DPS power supply : 24–30 off DC-DC Power Supply module - Shop Cheap DC-DC Power Supply module from China DC-DC Power Supply module Suppliers at RD Official Store on Aliexpress.com
2, USB Tester meter : 24–30 off USB Tester meter - Shop Cheap USB Tester meter from China USB Tester meter Suppliers at RD Official Store on Aliexpress.com
3, 7 in 1 OLED multifunction meter 24–27 off 7 in 1 OLED METER - Shop Cheap 7 in 1 OLED METER from China 7 in 1 OLED METER Suppliers at RD Official Store on Aliexpress.com
4, JDS6600 : 20% off (23% off at phone app) Group - Shop Cheap Group from China Group Suppliers at RD Official Store on Aliexpress.com
Hope this can help you. Happy shopping
Have a nice day
Best Regards
RD official store
Today it was raining so i was busy :slight_smile:
Nice, so you have 3 fixed voltages and 1 that is adjustable up to 12V
What are the 5 way binding posts in the rear for?
There are 3 fixed voltages from PC power supply.
Adjustable is up to 32V 5A buck-boost (DPH3205) powered from the same PSU.
Binding posts and one 5.5x2.1mm connector on the rear are for powering DPH3205 from any DC 6-40V external power supply when I don’t have access to 250V AC.
Other 5.5x2.1mm connector is 12V out from PSU.
Nice work. the main system is easy, one DPH3205 , one switch power supply . you all many voltage current meter
seems great
thank you for your great work
Ahhhh, that’s right. There is now a buck - boost version and you used that one.
:+1:
Anyone?
@ Lightrider:
AFAIK it’s a constant on fan. Yep, somewhat annoying when working late at night.
@ RD tech:
Found a relatively cheap 57V DC power supply to feed my DPS5015. Please comment if this PSU is good or not. I read your manual and try not to use 60V DC input as it’s the upper maximum limit for DPS5015. And 55V is the minimum input to get 50V output.
https://www.aliexpress.com/item/ETL-Approval-Dual-output-57V-12V-Switching-Power-Supply-500W-SMPS-from-China-Manufacturer/32799893372.html?spm=a2g0s.13010208.99999999.264.mOKMvD
Thank you,
Clemence
