Part 1- Sofirn SP32a Flashlight.
How does the step down work in ramping mode? If it’s at its full brightness, does it still step down after a couple of minutes? And to what level does it step down?
RickW12
Please tell me if you need more of the manual posted for your answer. Thanks.
Click on the manual to see the three pages larger.
Thanks for posting that. It only mentions Turbo and High being reduced; I don’t see anything about what happens in ramping mode. Can I assume that when it is ramped up to those levels, it will also be reduced automatically?
I will give it a try later and post results.
When ramping high is about 1000 lumens and low is Moonlight mode which is about 1 lumen. After three minutes it looks like medium mode. Double click for turbo. After three minutes it goes down to medium mode but stays at 900 lumens for about a minute. Does this answer your question?
Does this SP32A have this bug (I think it’s a bug)?
3 quick-clicks to get to Strobe mode
then do 4 quick-clicks to Lock-out.
Now, the flashlight is locked-out in Strobe mode.
Pressing the buttons does nothing, except doing 4 quick-clicks which unlocks the lock-out, then flashlight is back to normal.
Thanks, 264. That does help. Since medium is 160 lumens, that’s what I’d have to work with most of the time. My Coast polysteel 250 will serve me better.
Yup, I got that on mine too! Never noticed before :person_facepalming:
After 4 clicks my flashlight blinks twice signifying flashlight is locked out. Everytime you press the button the flashlight blinks twice till you repeat the 4 fast clicks to unlock the light.
Hum, d_t_a was mentioning to activate lockout while the strobe is ON! :wink:
When the light is OFF, mine behaves like you described :wink:
But when the strobe is ON, if the lockout is activated, it remains like that, the light gets locked and then you cant turn Strobe OFF.
Unless with 4 clicks to lock-out or unscrewing the threads !
I cannot get mine to lockout while the strobe flashes.
So the Strobe doesn’t get locked if you click 4 times while it is “strobing”?
There must be some bug in my light and d_t_a’s, then :person_facepalming:
Oh, just managed to lock the light in strobe mode. Mine is just like the others. Buggy.
Hum, that may be a bug of all of them!
Maybe some other users can give input on this to see if it is a “random” bug of a “unexpected” bug!
Thanks for confirming 264 :wink:
I do think wanting to lockout the flashlight while it was in strobe mode was unforeseen.
The SP32a is a fun and useful flashlight. Not surprising us flashlight nuts find quirky things about different flashlights.
Reported the issue to Sofirn…
Update: just got a reply from Sofirn, which doesn’t seem to be helpful since they don’t acknowledge there is a bug…
this is the reply from Sofirn:
Yeah. The issue is very trivial. It’s nothing to fret about.
I just realized you got sent a protected battery. They now bundle an unprotected battery with these that are capable of a lot high amp draw.
I don’t really see it as a bug because I’d never perform a lock out with the flashlight on in any mode. Only for traveling or putting in my bag.
