I don’t think this should be underplayed. Given the range of other flaws, the fact something like this can be ‘forgotten’ makes me wonder just how safe these lights are, either for experts of those less experienced. What other electrical nonconformities are yet to manifest?
So far, from the GB batch, we have:
- underpowered lights (mainly the 35s)
- lights which don’t turn on at all
- lights which turn on a flash a few times and turn off
- lights which require the thread to be loosened to make a proper connection
- lights which don’t turn off (illuminating the button even when otherwise off)
- no indication of any thermal regulation
moving goalposts about expectations of GB quality
Every indication was given that the quality of these units would be solid, and a rigorous QA process would be applied on every unit before dispatch. Unless somehow this all happened during shipping, I’m not sure what QA protocol could have been followed for this to happen.
For me, if I’m paying $100+ for a light, I expect it to work as advertised. I should not have to worry about me or my family burning their hands or shorting 4 18650s.
Friday night we tested my MT09R XHP35 Hi from this GB and a Haikelite MT07s. The MT07s has a bit higher range, but the beam of the MT09R is much wider.
My luxmeter shows 220.000 candela for MT07s and 196.500 candela (MT09R:6meter, Sony VTC6) for my MT09R (NW, but it looks like CW).
Our second luxmeter shows 27% more candela ! But my luxmeter compared with many other luxmeter and shows the same candela for many other flashlights like other TLF users had detected.
For example:
Astrolux MF02NW: 422.640 cd (6 meter, Samsung –30Q)
Acebeam K60: 144.000 cd (6 meter, Imalent MRB186-P30)
Imalent DT35: 121.320 cd (6 meter, Imalent MRB186-P30)
Jetbeam T6: 129.600 cd (6 meter, Imalent MRB186-P30)
Klarus G35: 195.000 cd (6 meter, Imalent MRB186-P30, is very sensitive with different batteries!!)
Utorch UT02 NW and CW: 86.000 cd (1 meter, with different batteries)
You guys are wrong or maybe not doing it righ. Let me present you my observation.
Haikelite mt09r xhp70.2 CW. Use infrared temp to get the reading next to the switch.
All are in fahrenheit… yes. This light have an automatic step down.
I turn on light to high mode.
Initial temp. 63 fahrenheit
1 min. 80
2 min, 93.5
3 min. 104
4 min. 110.5
5 min. 111
6 min. 111
7 min. 112.5
8 min. 113.5
9 min. 115.5
10 min. 115.5
I could feel step down after 3 min., slow shift. My eyes wouldnt notice. This light is not hot… handle was 93. After 10 minutes, i double click. Then it go back go bright high mode.
Conclusion. My light have authmatic thermal step down.
I don’t quite understand. If there was a step-down after 3 minute as you say, why isn’t that recorded in your minutes/temp? Am I missing something? Thanks.
Newlumen, I think you are right. I think I just don’t notice the stepdown because the eye is not reliable for lumen measurements. Also mine gets pretty darn hot under extended use on max brightness but not dangerously hot like some people report here. I guess it may have some form of thermal protection. If that’s the case, then that makes this light even more impressive considering how much better it can maintain useable high output compared to other lights with thermal regulation.
I said i feel like the light step down after 3 minutes. My eyes couldnt tell. It was slowly step down… i didnt see any flicks while the light step down…
I will do 10 minutes high test again on monday night using fully charged 18650, and i will also record lux number as well…
I know my light have thermal protection, because temp are 115.5 fahrenheit…
I have used some of my other similarly equipped lights as a photography source for up to an hour. I don't run them in turbo mode as I don't want them changing or doing radical step downs while I'm shooting, so I usually select the level below maximum/turbo. I've never bothered to measure how hot they got as I was always comfortable grabbing them when it was time to switch them off.
Not so with my XHP35 MT09R. I set it on the the 4th step in Group 5 (the one below Maximum/Turbo) when doing a battery test. and it hit 151° F (66.1° C) after 20 minutes (measured with an accurate Fluke IR thermometer with emissivity set properly). That's certainly above the stated 55° C thermal regulation spec, and in the realm of burned skin and decreased Li-ion battery longevity.
I haven't run/tested mine on Turbo for any extended period of time because that's generally not the way I use my lights.
Does thermal regulation possibly only work on the maximum (Turbo) setting? Or only on (some) XHP70.2 MT09Rs?
So here is my conclusion. Both version of mt09r will step down after 2 minutes from the high, and maintain at the medium mode for long period of time.,
I have an MF01 being shipped to Lexel to swap out the driver for the NarsilM. How do you like it? How does it compare with the MT09R? I read the lumens on the 219C version is 12k+ or more.
Same with my light, after 2 min i can also feel it must be around 65c or more then i ofc step down to lowest or so, but its weird if some lights has it and some not ?
