✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
RAVEMEN CR300 300LM German Standard Anti-glare 6 Modes Bike Light Wired Remote IPX6 USB Rechargeable
Use coupon code 3eefc4 to get 29% discount
» Jump to First post quick links/deals list «
RAVEMEN CR900 900LM Touch Control LED Display German Standard Flood Bike Headlight USB Rechargeable IPX6
Use coupon code 01db2d to get 29% discount (-$23.10)
RAVEMEN PR600 2* XP-G2 600LM Bike Front Light USB Rechargeable 3 Modes and 8 Lighting Levels LED Remote
Use coupon code PR60011TH to get 28% discount (-$15.39)
RAVEMEN TR20 20LM USB Rechargeable Bicycle Tail Light Red High Intensity Rear LED Accessories
Use coupon TR2011TH to get 30% discount. Price drops from $14.95 to $10.46 (-$4.49).
Astrolux SC/SS/S2/S3 BLF X5/X6 Flashlight 2LED Lighting Switch For DIY
Use coupon code PASXS to lower the price to $1.99 (-$1.00/-33%)
This one is just the switch on PCB (2 LED version) - without any mounting rings etc.
»Version with retaining rings and transparent silicone boot here «
LiitoKala Lii-S1 Intelligent LCD Display USB Battery Charger for 18650 26650 14500 21700 Battery
It’s now in flash sale until 20th March for only $6.99 ($12.29)
Successor of most popular compact Lii-100.
Apparently someone from Liitokala reads BLF and saw all those lii-100 voltmeter mods :smiley:
They even added current readout!
BlitzWolf® BW-ET1 XP-L V6 750LM Stepless Dimming Mini EDC LED Flashlight 14500/AA
use coupon code: 51517a to lower the price from $29.95 to just $16.77 (-$13.18)
Extension tube available separately here:
BlitzWolf® BW-ET1 LED Flashlight Extension Tube for 2xAA
for $1.99 or $1.59(VIP5) - $1.69 (VIP0/1) using BG points.
Astrolux A01 Nichia 219B 102LM AAA Mini Waterproof Keychain EDC LED Flashlight
Use coupon code PAS01 to get $7.88 price.
Dude, some of your coupon codes have expired. I tried the BLF A6 and the Imalent DX80 from your first post links and those don’t work.
This deal for DX80 still works:
I’ll check codes for A6.
EDIT:
A6 code 2017FNL expired, 8a955d still works. For Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 coupon code 76648A works.
I generally try to remove expired deals from the list in first post, but I’m not able to check everything all the time and end dates are most of the time not disclosed and/or change. Some very old coupons still work, others can be disabled and then reeanbled again.
That wasn’t the deal linked in your first post - it was the one for the DX80 for about $208. Nice to see you still have something in there, thanks!
Both are listed - in fact also another one (older one with 2$ higher price but also working).
It’s best to use search function (Ctrl-F in most browsers) and check for all deals in first post.
XANES D25 1650LM 2 x XPL2 LED 6 Modes Stepless Dimming USB Charging Interface IPX6 Waterproof Cycling Headlamp 18650
New headlamp from Xanes with 2x XP-L2 LEDs. It’s now in preorder: first 50 pcs for $12.99, up to 500pcs for $13.59, then $16.99 and final price is supposed to be $25.49.
  • 2x Cree XP-L2 CW
  • 2 Aluminium OP reflectors
  • 1x18650 power supply
  • 6 modes with stepless dimming
  • micro USB rechargeable
  • max output up to 1650lm (with decent high drain battery - Samsusng INR18650-30Q is suggested)
  • weights onlly 80g without battery (2.8oz)
Good day ,
I can ask for a BLF A6 coupon
I'm interested in 5A color light / can also be version with battery /
For XANE D25, may I know what is the lowest output for its moonlight mode?
Apparently there’s no moonlight if the description is accurate. Lowest setting seems to be ~200lm
This however looks like a nice candidate for modding - I was thinking XP-L HI CW with reflector for throw in one socket and high CRI Nichia with TIR Optics as second LED for close range flood beam.
ThorFire C8s Upgrade XM-L2 900LM 5Modes Cycling Outdooors LED Flashlight
It’s now in flash sale for $12.40 ($16.95).
Offer expires in 3 days and 15 hours.
It’s basically a complete flashlight for the price of a host.
For both:
use coupon code 8a955d
Ordered a Xanes D25 to check it out
Code for Thorfire C8s upgrade please.
