Any chance on a special for the Acebeam EC65? Cree XPL LEDs or Nichia 219C LEDs.
i am trying since i had it in my hands ;)
very good question:))
Hopefully my next purchase will be the EC65.
mine too:)
it would take a month if they pre-order now
Acebeam EC65 looked very interesting, until I saw lowest mode of 20 lumens. And they call it “firefly” mode!
NEW: Klarus Mi1C army green / rose also black, copper and titanium
Hello my dear friends!
who has them all?
Klarus Mi1C
XP-L HI V3 600Lumens Mini-might Brightness EDC LED Flashlight
Army Green
Rose
Black
Copper
Titanium
deals can be seen here by members – or you ask me
Features:
• Mini-might brightness, thumb-sized.
• XP-L HI V3 LED, maximum output up to 600 lumens.
• Extreme runtime, up to 9 days in moon mode.
• Professional optical lens design, even-lit flood and soft beam.
• Tail magnetic base function, attach to a metal surface to provide “hands-free” illumination.
• Fade-in and Fade-out function when the turbo mode is the initial mode for on and off to promote eye safety and improve user experience.
• Newest Intelligent Temperature protection System(ITS) monitors internal temperature and adjusts output to regulate heat dissipation; protects LED and internal components for perfect balance of output and safety.
• Intelligent Battery Capacity indicator to view remaining battery capacity at any time.
• Unique lock-out mode prevents accidental activation; avoiding battery drains during storage or travelling and prevents unintended directly shining into eyes.
• Reverse-polarity protection prevents damage due to incorrect battery orientation.
• One-touch low and with mode memory function.
• Aerospace Aluminum Alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
•Compatible with CR123A and 16340 Li-ion battery, KLARUS high performance 16340 battery with Micro- USB port included, no need to bring a charger, easy to use, safe and reliable.
Package included:
1 x Klarus Mi1C 600Lumens Mini-might Brightness EDC LED Flashlight
1 x 16340 Li-ion Battery with Micro-USB Charging Port
1 x Stainless Steel Clip
1 x Spare O Ring
Hi Martin,
Do you see any chance to get a substantial discount code for the Convoy L2 and L6 again? Unfortunately, the existing codes have been expired („more than 100x used“ or so). Thank you so much!
a lot people asked about a good 8-bay charger to use with their BLF GT (which sells for $250 if you are member )
here is a very nice one:
(picture is the link to the shop – please click it)
Nitecore i8
Multi-Slot 5V USB Intelligent Charger For Li-ion/IMR/Ni-MH Battery
use my code: MI8NC to get the price to US$ 37.46
Festures:
-Active Current Distribution (ACD)
-Monitors and charges each of the 8 slots independently
-Compatible with and identifies Li-ion batteries, Ni-MH and Ni-Cd rechargeable batteries
-Features three charging modes (constant current, constant voltage, -dV/dt)
-Automatically detects power levels of batteries and selects the appropriate voltage and charging mode
-Over-charging prevention
-Reverse polarity protection and short circuit protection
-Activation function for over discharged protected batteries
-USB output
-Designed for optimal heat dissipation
-Made from durable PC material (fire retardant/ flame resistant)
Can you check on some codes for 18650 batteries? Most seem expired. Looking for higher end batteries, Samsung 30Q’s or equivalent.
finally its on stock!
Fitorch M30R
XHP35 HD 1800LM 6Modes Dimming USB Tactical LED Flashlight & Mobile Power Bank
find the deal here: M4D M4X DEALS or ask me…
(pictures links to the shop for further info and specs)
beside the groupbuy: Wuben TO40R XP-L2 1200LM Dual Switch USB
i got some also quite ice items on sale:
(the pictures are links to the shop – please use them ;) )
WUBEN T103W
XHP35 HI 1280Lumens USB Rechargeable Tactical LED Flashlight +18650
>>for the deal just look here or ask me <<<
Convoy S9
XM-L2 580Lumens 4Modes USB Rechargeable EDC LED Flashlight 18650
>Code: YCVS9 loweres the price to US$ 15.95-16.95 <
Sofirn SP32
XP-L2 V6 956Lumens 6Modes Neutral White EDC LED Flashlight
> Code: 6cbdf8 loweres the price to US$ 14.69 <
Sofirn SF36
XP-L V6 1100Lumens 4+1Modes Neutral White Tactical LED Flashlight
> Code: f6b801 loweres the price to US$ 15.69 <
AMUTORCH JM30
XM-L2 U4 1000Lumens 4Modes Tactical LED Flashlight
> Code: YJM30 loweres the price to US$ 31.80 <
AMUTORCH VG10
XM-L2 U4 1200Lumens Portable Tactical LED Flashlight 18650
> Code: YMVG10 loweres the price to US$ 25.99<
JETbeam II PRO Copper
Xp-l Hi Anniversary Limited Edition 510Lumens Tactical EDC LED Flashlight
> Code: JTIIPO loweres the price to US$ 73.69<
Blackwater SR71
3x XP-G2 1000LM USB Rechargeable Mini LED Flashlight
> Code: 1c6741 loweres the price to US$ 63.0 – 105.00<
Miboxer C2-4000
LCD Display Rapid Smart Battery Charger For 16850 26650 Battery 2Slots US Plug
> Code: 8fa94b loweres the price to US$ 24.69<
Klarus K1 USB
LCD Display Smart Li-Ion/Ni-Cd/Ni-MH Battery Charger For Almost all Battery Types
>Code: 934eva loweres the price to US$ 3.99<
Manker 20mm Copper MCPCB
XPL XPE XPG Direct Thermal Path Circuit Board
>Code: 1147a7 loweres the price to US$ 1.69<
and last, but not least:
A BIG collection of discounted flashlights
CODE ECFKL can add another 20% OFF
todays deal:
Sunwayman C22CC
XM-L2 U2 + XP-G2 R5 820LM Rechargeable LED Flashlight
only US$38.99 – get the discount code here: M4D M4X DEALS
Features:
-Aerospace-grade aluminum body with military-grade Type-III hard anodized finish
-Ultra-clear tempered glass lens is both impact and scratch resistant
-Smooth metal reflector surrounding primary LED for max beam distance
-Special secondary side LED used for softer, up-close lighting
-Single pushbutton side switch used to access all outputs
-Stainless steel crenulated tailcap used as glass breaker, self-defense tool
-Tailcap also used as tripod mount for hands-free illumination
-Micro-USB charging port underneath tailcap for recharging battery internally (18650 and 16340 Only!)
-LED power indicator above side switch glows when charging, flashes when fully charged
-Tail-stand capability for candle lighting
Package included:
1 x Sunwayman C22CC XM-L2 U2 + XP-G2 R5 820LM Rechargeable Flashlight
1 x Removable Pocket Clip
1 x Lanyard
1 x Spare O-Ring
I have an older C22C and really like it. The switch on this newer one looks much better!
seems some people did not like my choice of terms - sorry
Klarus K1 says code invalid.
Jetbeam E20R showing “Sold out”
Is it not being restocked? Discontinued?
