Not for sale yet.
interested in ODF30
thanks
Interested in XHP70.2 3500lm
Interested in acebeam XHP70.2 3500lm
Interested in acebeam 3500lm headlamp!
Headlamp interest….thank you
FLASH SALE
Fitorch M30R XHP35 HD 1800LM 6Modes Dimming USB Tactical LED Flashlight & Mobile Power Bank - PREORDER >>> PM for Special DEAL!!!
Edit: Coupon fixed!
Features:
- CREE XHP35 HD LED, 50,000h life span
- 4 switches tactical &illumination modes Included
- Any time, tail cap tactical switches operates priority,one step action to shoot target
- Tail cap tactical switch lock function
- New FCD rechargeable & chargeable function
- Integrated aluminum housing design is to assure LOGO and patterns in line
- Smart temperature control system
- Smooth brightness mode change
- Harmony breathing blink beacon
- Battery detection
- Low battery Indication
- Constant current circuit without flicker
- High-strength aerospace aluminum body, Mil-Spec hard anodized for extreme durability
- Coated tempered resists impact glass In high light transmittance
- Metal filmed reflector to create a high intensity beam
Specifications:
- LED: Cree XHP35 HD
- Input: DC2.75V-6.00V
- Output: max 1800 lumen
- Reflector: precise metal filmed
- Glass: filmed mineral glass
- Material : HA-III military hard-anodized finish aluminum alloy
- Housing: Premium Type III hard-anodized anti-abrasive finish of black
- Switch: Side Switch and tail switch
- Powered: 1*18650 battery or 2*CR123A
- Size: Ø 1.44 inch/ Ø36.5mm, housing: Ø 1.1 inch /Ø28mm, Length: 6.26 inch/159mm
- Weight: 6.06 Ounces/169.8g (exclude battery)
The Nitecore LR10 code is not working anymore.
Sorry pal, we only have "BLF" coupon for 5% discount.
New products for the week.
Weekend Offer
Interested with Lumintop ODF30.
Nitecore MH23 XHP35 HD 1800lm 8 Modes Switchable Micro-USB Rechargeable LED Flashlight - PM for DEAL
Features and Innovations
- High-performance compact searchlight
- The LED CREE XRP35 HD LED is used with a maximum luminous flux of 1,800 lumens
- Technology of crystalline coating in combination with "High Precision Digital Optics Technology" for improved reflector performance
- The beam with a maximum intensity of up to 21 600cd, maximum range - up to 294 meters
- A two-stage power switch is used to control all functions
- Highly efficient DC power board provides maximum operating time up to 330 hours
- The built-in power indicator displays the value of the remaining battery charge (Patent for utility model, No. ZL201220057767.4)
- The power indicator shows the battery voltage (with an accuracy of 0.1V)
- Intellectual circuit charging Li-ion battery (via charging port micro-USB)
- Built-in advanced temperature control technology (ATR)
- Reverse polarity protection.
- Optical lens with anti-reflective coating
- Made of durable aviation aluminum alloy
- Hard Anodized Cover for Military Class NIII
- Waterproof according to IPX8 (immersion up to 2 meters)
- Shock resistance from a height of up to 1.5 meters
- Possibility of installation of a lantern on the butt
All MH23 deals shared!
My new Convoy after almost two years, with brand new look and operation. Excellent choice for first time flashlight owner. Worth every single dollar in my opinion.
Convoy C8+ XPL HI LED 1100LM Portable Flashlight - DESERT SAND - $19.99 / Coupon: CC8OY / Link: GearBest
NEW DEALS
JetBeam HR30 SST40 950lm USB-C Rechargeable Headlamp
$43.21 | Code: BLF
$43.21 | Code: BLF
NITECORE HC65 XM-L2 1000lm plus CRI and Red LEDs Headlamp
$49.40 | Code: MAP
$49.40 | Code: MAP
Nitecore EC22 XP-L HD V6 1000lm infinitely variable brightness
$38.03 | Code: MAP
$38.03 | Code: MAP
