I thank for your detailed answer.
Is the battery of Efest the following product?
Efest IMR 26650 LI-MN 45A 5000mAh.
The consecutive electric discharge upper limits:45A
Maximum moment electric discharge:50A
Diameter:26.50mm
Length:65.20mm (±0.2mm) http://www17.plala.or.jp/x000x/battery3.jpg
You have Efest IMR26650 5000mah of 67.5mm.
The length of Efest which I checked, 65.20mm.
Are these two the same things?
Yes, it’s the same battery. My measurement might not be too good. Was using my daughters school ruler so it may be a little off. That is the same battery that fits in my ODF30 and works just fine. Going outside in a bit as soon as it’s really dark and I will post some beam shots.
Same here. I got my lumintop odf30 from banggood. Big discount using coupon code. Great quality light… lumintop did good job on the quality control and stuff.
I have a question about 26650 Efest IMR LI-MN 45A 5000mAh.
I checked Efest IMR 26650 LI-MN 45A 5000mAh.
Diameter:26.50mm
However, Mr.M4D M4X lists it when 66mm is too short.
Mr.toddcshoe,
You put Efest IMR 26650 LI-MN 45A 5000mAh in a flashlight.
And, please wave a flashlight lengthwise.
Does the battery not act violently in a flashlight?
I will purchase Lumintop ODF30 by the end of this month.
Lumintop ODF30 is not sold in Japan.
I will purchase it in gearbest or Banggoode.
And I will purchase 26650 Efest IMR LI-MN 45A 5000mAh.
Hi, CM2010
Do length and the diameter of Kppower imr6000mah 26650 not have any problem for ODF30?
I can obtain KEEPPOWER IMR 26650 5200mAh in Japan.
MAX : 30A / Constant : 15A
Diameter:26.10mm (±0.2mm)
Length:67.50mm (±0.5mm)
This battery is long.
As for your Keeppower imr6000mah 26650 battery, is Length 67.50mm?
Does the battery fit ODF30 without a problem?
I asked Lumintop.
Lumintop recommends the battery with the protection function.
It is not IMR battery.
Is Lumintop wrong?
Should I use IMR High-drain battery?
Is Efest IMR LI-MN 45A 5000mAh 26650 High-drain battery?
Is Keeppower IMR 6000mAh 26650 High-drain battery?
Those discharge rate specifications are a lie. Period.
Efest rewraps cells from OEMs. Nothing wrong with this, but they like to inflate the actual OEM cell specifications in a twisting, consumer misleading way, and on top of this try to charge you more. No way Efest.
I second Newlumen's cell suggestion but please check these AliExpress vendors' offers with a much cheaper shipping and handling quote to Japan (cells are blue wrapped but they're equivalent):
Love my r50 pro seeker LE
This is our family go to work horse for around the house.
Stays in the kitchen cabinet in its charger always ready to go.
Nice size and hand.
Olight perfection on fit and finish, if your into that kind of stuff…
