Texas_Ace MT09R Modding thread, 20k+ lumens, 80CRI, can start fires? Yes please.
Ooooh. Thank you. Didn’t understand why it didn’t change. Thanks for the response.
So, Level 1 is the lowest brightness possible, and Level 7 is the highest moonlight brightness possible, right?
This driver also improve MCPCB heat sinking right?
Correct, 1 is also the default.
I am not sure what you mean? The MCPCB is what the LED’s are mounted on, they are completely separate from the driver?
The driver itself does maximize the heat sinking of the components on it, although there is not a lot of heat it has to deal with in comparison to the 7135’s.
I still have to take an official inventory on Monday but I do still have 2 items only 1 of each that I will let go of at more than half off.
In fact they are basically my cost plus shipping.
I have 1 SC02 I will leave the price for that 1 single unit at the price shown here https://hesaidshesaidsales.com/shop?olsPage=products%2Fhaikelite-sc02-5000k-emitter-tint-color-white
And 1 MT09R 35 high white (really silver) which already had the new TA driver installed and has calculated out to be a 1000 meter thrower. Using this exact light which is the first one I tested TA's new driver in I found a water tower 822 yards away and it was no problem at all. These are excellent throwers.
Unless you happen to want an emitter upgrade this light needs nothing and is ready to ship directly to the customer with the new driver installed of course Narsil that you all know about.
I have 1 that I will sell for $110.00 that is less than my cost once you add in the driver that I had to purchase and shipping. Actually the $10.00 is mostly to cover the shipping and to make sure that my daily sales does not show a loss. You can find it here https://hesaidshesaidsales.com/shop?olsPage=products%2Fhaikelite-mt09r-triple-cree-35-high
I Think I have 2 more of these I just have to locate them and order a driver from TA for them. That will be next week sometime when I do a quarterly inventory.
Until you actually see one of these throw, no picture or video can do it justice...
Got the MT09R on stock LED emitters, it is cooler than my 5700k MT03
Here are 2 pics to compare them.
The MT09R is doing super good with stock emitters and throws very well.
But MT03 just blast everything right in front of me much better.
Both are great. But if I must pick one I’ll pick the MT03…
First is the MT03 TA 23k lumen
MT09R TA 20k lumen
Good pics! Are they taken at the same time? The tree in the forefront doesn’t have leaves in the MT03 pic.
You should take two pics at the same time so we can compare colors, air haze, and the same foliage.
You have two super blasters now!
Nice comparison between 5700k and stock led ( 6500k ? )… so it look like mt03 have floody beam…
Yea I took them at the different day. And yes the MT03 is a super good flood light. MT03 is 5700k and MT09R is stock NW emitter.
I will take pics on the same time maybe tomorrow night
The MT09R is definitely more throwy than MT03. However if you use DC Fix, it increases the spill tremendously but still maintains good throw.
Can it handle the power level of the MT09R though?
At 96% optical efficiency, it is going to be taking(0,04*19 000 lumens), it will be taking away 760 lumens, which isn’t insignificant. Can it handle the heat? Or am I wrong?
Also, guys, what kind of mods are you doing yourself? The reason I didn’t want any spring bypasses is that I’m going to replace the stock springs with phosphor bronze springs, as an example.
Any other soft mods that I could do to improve the light itself?
Those stock NW emitters are 5000k 75CRI
You are correct. His mt03 have an upgraded led, so 5700k.
Hey guys I sold the MT09R 35 high CW White(Silver)
I normally always take Sunday off but I knew I had one more 35 high and all I needed to do was install TA's driver so I now have only 1 35 high left.
Black and even though the box is not marked for some odd reason I can just about bet the emitters are CW. 6400 lumen in my tube using 30q's
I am about to process the order for the white one and I will add this black one to the stores inventory when I do and at the same price.
Thanks for all of the support and please keep the pictures coming. love seeing them... That MT03 is 100 percent flood and extremely bright. I just like the extra distance from the 90R...
I don’t have any issues with my DC-Fix handling the heat and I love to go repeated turbo.
I have a palight Boss1 with the xpl dedome… it have ring around the corona and do you think dc fix will eliminate?
image post
DC-Fix is not recommended for dedicated throwers since you want max concentrated hotspot, whereas DC-Fix will diffuse the beam. With that said, however, I think I remember reading someone saying you can cut a donut ring with the DC-FIX so it doesn’t affect the hotspot. I have no idea whether that works.
Ok. Just curious… having a ring is good, atleast in this light… it got a highest intensity… anyhow…
Wife has that... says it does a great job.
Nice… i ordered two from amazon last night… one for me and one for my parents…
