Any flashlight drivers with built in USB charging?
11 posts / 0 new
Enderman
Enderman's picture
Last seen: 35 min 15 sec ago
I haven’t been able to find any drivers for sale that have built in charging, even though there are several flashlights on the market with USB charging now. Anyone heard of any? (other than the BLF lantern project which has a USB charging driver)
In the future I plan to make a USB rechargeable flashlight that can also take regular cells (not the double-ended proprietary stuff)
Some flashlights are already like this, the charging circuit is in the head where the driver is, not in the tailcap.
USB rechargeable, uses regular cell ^^
If all else fails, I guess I can either pull a driver out of a USB rechargeable flashlight (which I would rather not do because I want to choose my specs)
OR
I can also remove the circuit from one of these batteries and have it directly between the driver and regular cell, since it will share the same ground as the driver.
This is the easiest solution I can see at the moment, since it can be used with literally any driver and battery combination.
PS- I wasn’t able to find another post about this topic, if I missed one plz link it Smile
CRX
CRX's picture
Last seen: 2 hours 26 min ago
Not exactly what you are looking for but I have installed pass through chargers to a couple of lights.
A lot of work involved doing these though.
If the current draw requirement isn’t too high one of the 18650 celltop charger units might work well.
I used one in this build.
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
Enderman
Enderman's picture
Awesome, great to see that somebody’s done it before and it works Smile
I checked all the nitecore batteries and the highest I found is the NL1829RLTP which can do 5A continuous, which would be enough for me.
Which passthrough chargers have you used? Did you also rip them out of USB rechargeable lithium cells?
Phlogiston
Phlogiston's picture
Last seen: 1 day 6 hours ago
You know, CRX, I was just thinking of your post here:
http://budgetlightforum.com/comment/1293077#comment-1293077
while I read Enderman’s OP.
Your link was where I found out where to get those tiny charger boards, so thanks again for that Thumbs Up
CRX
CRX's picture
No, for the high current lights I built the chargers from scratch.
I used a tiny ME4056 chrager board enclosed in a C shaped piece of .75mm thick brass so the battery contact is the same continuous metal as the head positive contact with the charger wired to it in between and then to a press fitted ground ring and fully potted.
I think I used the Lumintop 18650 cell charger for the carbon fibre cube light, seemed the best at the time, passthrough current of around 7A. HKJ review .
I think he has tested some other brands too.
CRX
CRX's picture
Yeah they are really useful for smaller lights etc Thumbs Up
Enderman
Enderman's picture
Awesome, just what I was looking for, thanks!
EDIT- if anyone else is interested, here’s the link to the ME4056 charger: http://budgetlightforum.com/node/57414
CRX
CRX's picture
Thumbs Up
Lightbringer
Lightbringer's picture
Last seen: 14 min 13 sec ago
I grabbed these https://www.amazon.com/gp/product/B01LHD9D7E/ for my lantern project, if it ever gets off the ground.
Charger + protection circuit combined in one. Lets me protect a 3P arrangement and be able to charge it on-the-fly.
e1000
Last seen: 5 hours 2 min ago
Enderman
Enderman's picture
Those look nice, unfortunately it’s 3A max Sad Won’t work in my design.
e1000 wrote:
EagleEye X2R?
http://budgetlightforum.com/node/49369
Interesting, I’m definitely the type of person who would buy a whole light just to use the driver Silly
