Olight I3T EOS Dual-Output Slim EDC LED Flashlight - Philips LUXEON TX CW - 180 Lumens - Includes 1 x AAA
Item #: OLIGHT-I3T-EOS Brand: Olight
$19.99
Save 17%| Reg. Price $23.95
Olight I3T EOS Slim EDC Flashlight
Tiny But Mighty
Featuring a slim design and an exceptionally bright output, the Olight I3T EOS Dual Output LED Flashlight is the ultimate EDC illuminator! This compact torch measures just 3.5” long and comes with a handy two-way pocket clip, making it easy to carry in your pocket or bag wherever you go! Despite its small stature, the I3T EOS still packs a considerable punch, capable of emitting a 180 Lumen beam that can throw nearly 200 feet, more than enough for most everyday tasks. The handy little flashlight also comes with a secondary 5 Lumen output for when you need just a bit of brightness rather than the full force.
Ergonomic and Stylish
Every inch of the I3T EOS is designed to be as ergonomic as possible for optimal user experience. The powerful light operates on just one AAA battery (included), making it one of the brightest single AAA flashlights on the market and making replacement batteries extremely easy to find. The light’s pushbutton tailcap switch makes one-handed operation crisp and easy. The EDC flashlight’s body is crafted from machined aluminum alloy, making it incredibly impact and water resistant so it’s safe to use anywhere. The body even features a unique helix-like knurling that catches the eye and provides a comfortable and secure grip.
Features:
Quality machined aluminum body is impact and water resistant
Compact design for easy every day carry
Stylish helix knurling wrapping body provides secure grip
TIR (Total Internal Refraction) lens provides smooth, evenly dispersed beam
Tactical tail switch allows for momentary and full activation
Dual-sided removable pocket clip for easier carry
CE and RoHS certified
Comes with Olight’s 5 Year Warranty
Included Accessories:
1 x AAA Alkaline Battery
1 x Removable Metal Pocket Clip
Specifications:
LED: Philips LUXEON TX CW LED
Power Source: 1 x AAA (Alkaline, Ni-MH, Lithium) (Alkaline Included)
Peak Beam Distance: 60 meters (196.9 ft.)
Peak Beam Intensity: 900 cd
Brightness Outputs:
High - 180 Lumens - 21 Minutes
Low - 5 Lumens - 16 Hours
IPX Rating: IPX-8 (Waterproof and submersible up to 2 meters)
Impact Resistance: 1.5 meters (4.92 ft.)
Dimensions:
Length - 3.5” (89 mm)
Diameter - 0.59” (15 mm)
Weight (With Battery & Pocket Clip): 1.45 oz. (41 g)
SPECIFICATIONS
Turbo High Medium Low Moonlight
Lumens: 180 180 - 5 -
Runtime (Hours): - 0.35 - 16 -
Output Modes: Dual Brightness Levels, Momentary
Compatible Batteries: 1 x AAA
Batteries Included: Yes
Included Accessories: Batteries, Pocket Clip
Flashlight Usage: Every Day Carry
Throw Distance (Max): 60m
LED: Luxeon TX CW
Switch Location: Tailcap
Product Certifications: IPX-8
Brand: Olight
Warranty: Battery Junction 30-Day Warranty, Olight 5 Year Warranty
Return Policy: Battery Junction Return Policy
Primary Material: Aluminum
Product Weight: 1.45oz
Product Dimensions: 3.5” (L) x 0.59” (Diameter)
UPC: 6926540908467
MPN: I3T-EOS
Country of Origin: CN
recently received the test units, this is a really nice EDC light. although review text is ready but I do not have the green light to post the full review until they officially release it worldwide... rumor has it it's early July... compare to i3S-cu EOS (mine is brass), this new light has a better sustainable high mode runtime. Without going into full review details, I'll leave you with one of a few runtime charts (to be available in my review) a comparison of high mode between the said lights...
Thank you guys for providing early info about this light. From the cached text I’m not sure whether there are only two or multiple modes, also if there’s mode memory, but we’ll see.
Olight just announced via their Facebook page it’s available now as of July 2nd on their main wesbite only. Better grab one while you can. I am sure they will be sold out before the end of the day.
I had the same complaints but bought the lamp anyway, as I wanted to get a feel of it and send a signal to Olight that AAA clickies are appreciated.
I'll add that the sort of "spiral threading" on the body is pretty ugly (for me), ineffective in terms of grip and uncomfortable. However that isn't too much of an issue in practice given the clip provides excellent grip.
5 lumens is okay for me in practice, but I really have no use for the highest setting - too bright.
I can only say i would have liked a moonlight mode, rest is not much to care for, it will have a purpose low and high. i mean for 20 bucks this light is worth it.
Don’t know if it will help you, I did a huge comparison between the two modes (and autonomy, color temperature, beam…)
The 5 lumens mode is great, enough light to walk quickly in the darkness. With a moonlight mode, I’ve got some difficulty. But you are right, 5 lm is more than you need for some uses !
I’ve been using the i3T EOS for a while. Today it started flickering like a strobe on both modes! That’s correct, the battery (Ni-MH) was below 1V .
I also tried some almost drained AA Alkalines and the same behaviour is noticed.
Just wanted to say this as I don’t know if you have seen it on yours :+1:
