Let me check with them.
Instock NOW! Limited sets.
Ordered one XHP 70.2, thank you freeme
Disappointed, if it’s not too late, I’m interested in XHP 70.2, thank you , freeme
I can not use the code…
When will it become available?
I received a PM from Freeme.
Does anybody know a good holster? I tried a bootle cage… but this solution wasn’t very nice…
Is this still available? Interested if so.
I like how the FLYYE PH-M004 1000D fits my MT09R. I got mine at hkequipment, but I’m sure other places also have them.
If available, I am still interested in a code please.
If still available, i’d be interested in the triple XHP 70.2.
Thanks
Hi , I remember you …
Ordered a black XHP70.2 NW.
Thanks Freeme! :+1:
Thank you for your continued support!
Interested in the XHP70.2 x 3 version.
My MT09R XHP70.2 is on the way… However, reading part of this thread i get the impression some units may have issues like under performing due to wrong FET or else…
How will i know whether i have a ‘good’ one?
It’s not really a wrong FET.
It’s just a part that has slightly higher internal resistance and lower rated current(40A vs 50A+ of the FET used in the original TA driver).
Other than that, it isn’t problematic.
I get that, but doesn’t it impact performance - like under 20k lumen on turbo?
Maybe i’m just confused about what i read in this thread… I got the impression someone had a lower then expected output because of it.
Still, is there a way to tell which one i will get - possibly without taking the driver out…
Sorry if this is a non issue… I’m just a bit anxious you know… :person_facepalming:
You will get about 18k lumens stock.
You will not be able to get 20k+lumens without a spring bypass.
Mine gets 19k lumens with Texas Ace’s own driver without a spring bypass
Basically, the lumen rating of the lights are overrated by quite a bit.
24k lumens is the startup lumens Texas Ace got on one of his samples with P2 binned XHP70.2s, bypassed springs, and his own driver.
That is the absolute best scenario, and yet, Haikelite put on this number as stock.
Mine is on the way too. 25K is definitely far fetch but I will be happy to settle for 18K for this size. For over 20K, you probably need at least 4*XHP70.2 i guess.
