These are the best:
There are some keeppower 6000mAh ones which are the same cell with a different wrap.
These are the best:
Hey guys sorry and thanks for all your replies! All these emails were going into my promotion folder or whatever it’s called in my Gmail. Wasn’t seeing them my bad.
I’ll be using them in an ODF30 and a modded L2. I have 4 of the AWT cells but I just kinda want something different. That I can preferably buy in the US and not overseas.
Thanks
I’m not sure if the Shockli 5500 or Keeppower 6000 will fit in the ODF30.
You need both a slim battery for the ODF30 and a raised top for the L2.
The Basen 4500mah might work. I’m not sure of their reputation, though. Maybe someone can comment on that.
There’s not much to choose from in the US.
Not many overseas either. The Liitokala is always good and there are other good cells out there, but you would need to solder blob the tops so they make contact in series.
Got a couple of those Basen 4500mAh on the way, shipped last Monday so hopefully here by the weekend, to try out. Got a couple of these yesterday might be worth looking into
Yeah, I remember those from a long time ago. The little springs won’t carry current for #$!, but maybe they will be fully compressed and not have much resistance. It’s a long trip from overseas, you might as well get some Liitokala’s while your at it (not from Aliexpress). Those are great general purpose high drain cells.
Here are some good usa choices if you had that spacer to connect them in series. They should also fit the ODF30.
The best 26650 is the shockli 5500mah
It’s too fat to fit the ODF30. So now what?
Forgot all about my L2. It is modded so I only use it with one cell. Not 2.
And also when I seen the new promotion email, it won’t let me open it. Says page not found.
Anyone know what’s going on as to why I’m not getting emails when you all are posting on here? Thank you all. I will do some looking around.
I feel bad. I’m not ignoring you.
Guys I’ll mostly be using them in the ODF30 if that helps narrow the choices down for you.
The ones from post 12 are most likely to fit the ODF30. They are fairly small diameter. At least they’re listed dimensions show that they are small diameter. I’ve never use either of those two batteries.
Someone may have posted in this thread and then later deleted their post so the link in the email going to that particular comment was now gone.
Thanks I’ll check them out
Don’t know about hi drain, but EVVA 5200mah from Mountain is slim.
I just recently got this from amazon 4 for $20. So far they’re working great with my flashlights. Sc26, odl20c, m8, L2, UT02 and also works great on my olight r50.
The PLB-55 Cell is the best one. It is in the Orbtronic 26650 5750mAh , The Shockli 26650 5500mAh and the KP 26650 6000mAh cell.
I have the Orbtronic and Shockli version……
A slight variation OR are my Orbtronics better?!
Wolfdog not gonna lie im a little confused lol. Could you send a link to the keep powers and Shockli & orbtronics please?
I was reading the review about the Cat V6 and you all went into battery details.
Thanks. Still got them leather hands
Idk what a PLB-55 is
The PLB-55 is supposedly the “CELL” that is used in all three of the batteries I mentioned. It is the best cell as far as capacity and plenty of amps[~ 20A continuous] for our flashlights.
I would definitely go w/ the Orbtonic cells over the Keeppower. It is about $4 cheaper/cell.
The link was already given for the Shockli[Mt. Elec.],I got mine elsewhere.
Orbtronic
Keeppower
Woah dang! Ok Orbtronics it is thanks all!
According to specs, that Orbtronic is as fat as the Shockli, which means it’s not going to fit in his ODF30.
