ENEDED
Nice :smiley: Thank you! I was just asking cause I thought that due to size it would not take them ! Being that way is nice :wink:
Okay, it’s the S1R that has the magnetic charger base. It seems to be a few mm taller than the S1 to it’s right.
Avoid battery with built-in charger. My brand new KLARUS went into self-destruction when i kept it in the box alone for less than 3 months.My other Nitecore NL1826R anode became hot (>50°C) when i removed from a Nitecore light. Top plastic cover deformed by the heat.
I don’t know if you can say that all brands of this battery style are bad based on just 2 examples.
Have you figured out the cause of those battery failures? Was it anything to do with the charger circuit or was it just bad batteries?
I don’t have any of this battery style simply because I don’t like having to take the battery out to recharge it.
freeme, can you post it here Flashlight with in-built charger OR flashlight + battery with in-built charger? ?
Or can I quote you to put on that thread?
I have few more models that i don't really use. Maybe i spend some time with them then share my findings over there later.
You’re right :wink: Better “testing” than early conclusions on single episode! Still, it is a data that makes me think about these batteries…
But, the thread is “On The Road” so let’s keep rolling :stuck_out_tongue: Sorry for off-topic! :arrow_right:
When is this torch likely to appear?! My status on GearBest is shipped, has been for some time now, but guessing as there are no reviews yet it’s probably not shipped at all?
Mine left the China sorting center on Sept 4th. It may be on its way to the USA right now. The delivery window is Sept 5th to 17th. So maybe I’ll get it some time this week. You never really know how long it will take for shipping, 2 to 4 weeks is common. It will eventually get there. Lol
I don’t expect anything new as far as reviews go. It’ll probably have the same mode spacing as the original M3. About the only thing that’s changed is the built-in charging.
Well mine has arrived :slight_smile:
Faster than I expected.
Mine came in as well :slight_smile:
I got mine today. Heres my mini review. No surprises. It’s just a better version of the M3. :+1:
Αnybody with first impresions?
Like I said in the post right above, it’s basically the same as the M3, but it has the added built-in charging. There are tons of reviews both in this forum and on YouTube.
Thanks Jason i read your nice review.I had the m3 5C. It is too warm but i like it.What you think about the tint xpl 1A in the m3 pro?Is it more throwing? and the rate off charging?
I’m not sure what you mean by the tint being more throwing. It’s small OP reflector does a good job of throwing, just like all the tints. I prefer CW and the tint seems fine to me. There’s no blue in it.
The charging rate is 1A. I reported 0.94A in my review.
Thanks for the answer.I mean between xpl 1A and xml 5C (that i have) any difference in throwing?
Both emitters use the same size die, so throw should be the same. I checked my old xml2 M3 and new xpl M3 Pro on the low setting and they got exactly the same candela.
Depending on what lux meter you use, the warmer tint may have a slightly lower reading. I know my HS1010A lux meter reads NW about 5% lower than CW.
The M3 is really not a thrower type of light. It’s more for close up use in my opinion.
Order full pack cw.Thanks
