Having used a few of the irons with integrated tip heater cartridges, the JBC, Aoyue 2930, and TS100 are the ones I can think of off the top of my head. They really are just better than the old slip on Hakko style and with the TS100 being pretty reasonably priced it’s hard to suggest something else if that’s your price range. Haven’t used a TS100 yet but the Aoyue and JBC just heat up crazy quick, so much more efficient at transferring heat from the cartridge to the tip if there isn’t a gap in there. Personally I’ve got the Aoyue and while I love it the handpiece can be slightly wonky in making a good connection, need to work on that at some point.
I’d forgotten about Pace. I wish you hadn’t posted that link. I want one.
ADS-200 / 8007-0580 is £205 from Farnell UK. Looks very nice from the specs and video. 120W. Lots of metal. Simple to use. The iron stand is clearly better than Weller. I like the tip change too.
I have two handles so I don’t have to change hot tips. But if I only had one handle changing tips would take time.
Their video targets the Weller magnestat irons. I didn’t realise they were still popular.
I’ve soldered for like 10 and only used a crappy 30W all in one iron.
Was a great upgrade to get the 1010.
It’s like the lowest end weller model but from the new digital series, so even though it is “low end” it’s a brand new design and still got more power and features than almost any other station at that price.
Heats up in seconds, tip lasts a long time, very precise temp control, etc.
This thing should last me decades of soldering
Yes it is my video. The vice is alright, I got it from harbor freight. The vise part is good but the suction part kinda sucks, it does not stay very well. I have since upgraded to a Panavise where the suction is awesome, courtesy of a screaming ebay deal.
After using a 40 watt Radioshack pencil iron for years this soldering station upgrade was well worth it. I have done some simple mods in the same time I have waited for my old iron to heat up. No need to go all out but the direct heat irons (Hakko FX951, Pace ADS200, JBC CD-1BE, TS100, TS80, etc) are worth it 100% if you will end up using them a lot
So why are they supposed to be better? Why is this method of heating supposed to be better?
It actually has a noteworthy downside - you can’t change the temperature. You need a specific tip for a specific temperature. This might be a big deal for a hobbyist who doesn’t always build the exact same circuits every day.
At first glance they are just another kind of direct heated tip iron.
Don’t knock it until you have tried it. There is a good reason why these $500 irons sell, steadily, and nobody appears to have knocked them off yet.
Twiddly knobs, flashy displays, perhaps a separate calibration stand, count for nothing when you can just turn the thing on, and 60 seconds later be ready to go. Absolutely consistently. Once you know, and can trust, a tool, you can do almost anything.
Melting solder isn’t rocket science. Making a good consistent reliable ergonomic trustworthy tool is a different art. And if you have to use it every day, for a full shift, not just dabbling about as I do, these things really do matter.
Oh, and the quality of the bits really does make a difference.
I dare-say you can get the same or better results from a Chinese knock-off of a Hakko, for 1/10 the price. That’s probably the best choice for most.
I’m just trying to explain that better things do exist and can make life much easier, if the investment is justified.
There are also $3000 soldering irons from JBC that sell.
Unless your job is soldering stuff 24/7, there is no reason why you need to spend that much money even if it is better.
My cheap weller station also heats up in 60 seconds, has a very consistent temperature, and is reliable with plenty of good tips available.
I ordered Hakko FX888D this week. I am in Europe, so I was cosidering also Ersa stations (Pico, Nano) and even JBC CD. But they are still much more expensive and spare parts as well.
From my point of view FX888 is still a good value for the money, even for 150Eur (final price incl. vat).
Get some decent spool of solder, some fluxes, tools etc. and you re ready to go for many years of realiable soldering.
I’ve done a bit of research into the “budget” Metcals, and actually they look pretty good. I was dubious because I can be a bit cynical, but I withdraw my doubts. Ten years ago I would had to have paid £1000 each for much the same thing.
I’d say well worth the £200. They would be good enough for most work, and the choice of tips is almost overwhelming. IME the tips also last forever, if you don’t wreck them by e.g. scrubbing on those pads made of metal swarf (the secret weapon designed to make you keep buying tips). And changing them is a doddle, a minute later and you are good to go.
The same induction heating of the tip, at about 450 kHz, albeit 60W not 80. But that is still plenty. The power is delivered to the induction coil in the handle through co-ax, with a BNC connector to the base, a signature feature of a Metcal.
The top-end jobs are getting very fancy, with thermal monitoring during the soldering cycle, LED indication of a satisfactory joint, even networked in for SPC etc.
