KD (kaidomain): Deals and new products thread
Thank you Ban! :slight_smile: :+1:
Hi Lux
I had posted the P60-TRI driver board on KD.
P2500 20mm 3V - 9V 2.8A 1 cell or 2 cells 5-Mode Driver Circuit Board for KDLITKER P6-TRI
P2500 is for parallel configuration
I3N 20mm 3V - 9V 1.5A 1 cell or 2 cells 6-Mode 3-Individual Channel(Negative Shared) Driver Circuit Board
I3N is three led individual channel (3 negative shared). You need to have the LED PCB that is supported.
If you have any question, please feel free to contact me.
Thank you
Ban
I had not seen those separately operable triple P60’s yet, and with full choice for all 3 leds, pretty cool :cool:
Yeah, we had launched a new triple P60 drop-in in recent.
KDLITKER P6-TRI Cree XP-E2 Triple Color P60 LED Drop-in
And we get a BLF member to help to review on that.
Enjoy
Thank you very much Ban! :-)
Can you please check the picture of this driver?
http://kaidomain.com/I3N-20mm-3V-9V-1_5A-1-cell-or-2-cells-6-Mode-3-Individual-Channel-Driver-Circuit-Board
It says 2.8A max. Is that correct? So with 9V I could use 3x CR123?
Hi Lux
Sorry for careless mistake on the photo.
This driver board is designed for Cree XP-E2 led, the max . current is around 1500mA
I will correct it tonight.
Thank you
Ban
Hi Lux
Picture is updated.
Yes, you can use with 3 x CR123A battery
Thank you
Ban
Hi Ban,
Thank you so much! :beer:
If you ever plan to sell this driver with 16-17mm diameter, I would be glad to hear about it. It would be perfect for a Convoy S2+ triple flashlight. :slight_smile:
Cheers,
Thomas
Hi
Will you sell this dropin only shell host ?
http://kaidomain.com/Flashlight-DIY-and-Tools/led-drop-in/KDLITKER-P6-TRI-Triple-Cree-XP-E2-Amber-590nm-800-Lumens-3V-9V-5-Mode-P60-Drop-in
Hey Ban.
Some time ago I bought a lot of empty p60 pills. I noticed that the surface on which the mcpcb is sitting isn’t flat.
I admit that I feel a bit cheated, because something that should provide better heat dissipation from the diode in reality is not much better than the classic p60 modules.
I need a lot p60 to finish all my flashlights and I paid a lot.
I’m dissapointed.
I want to say thanks. The new dust cap looks nice and fits perfect!
Will you get them also in bigger sizes? I would love to get one for my UF 1504 (70,5mm) to protect the aspheric lens.
Ban should stock some copper P60 pill. It will be more expensive but people will still buy it for the much better heat dissipation especially considering the powerful multi emitters.
Hi Chatika vas Paus
I am sorry i am not understanding what is your meaning?
What is the MCPCB are you using?
Can you take a photo to show what is your problem?
Thank you
Ban
Sure.
Let me see the bigger dust cap (69mm) can be used on UF 1504 or not.
Thank you
Ban
Hi SKV89
Sure, i will keep to improving our product.
Thank you for your advice.
Ban
I will check with our existing stock to see this is happened or not.
If you not like the pill, you can consider to return to us.
And i will refund to you.
Sorry for any inconvenience cause to you.
Ban
That’s a weird issue the tooling in the CNC must of been warn out and uneven. Pretty poor job from the manufacturer to not notice i wonder what else went out with faults. In fairness i highly doubt ban looks over all the stock and checks if its even.
This shouldn’t even be an issue you need to check.
While I’m here any chance you will stock any Osram LEDs?
He does stock an Osram IR led.
If you want to solve this problem in stead of returning them, i have some suggestions.
It depends on how thick the shelf is, but it could be enough to tighten the reflector and the pill so that the shelf bend flat,
or you could give the shelf a tap with a rod in the middle, using a hammer.
Or you could use a vise to bend down the shelf, clamping on a bush or something placed in the middle of the shelf.
Either way, hope you can solve the problem.
