Thanks for the video review. What a great thrower for the size. I’m not sure if there’s a better thrower with this same size head. I’m quite impressed that they got so good numbers with a dedomed sst40. Must have a good reflector and driver. Xpl- hi outthrows a dedomed sst40 right?
The nitecore p30 has a slightly bigger reflector but this maxtoch outthrows it.
I actually changed out the SST40 in this light with a XP-L HI V3 3C already and did nothing else but swap the board and emitter out.
With the driver that is in the M1 , the lumens went down considerably with the HI emitter as did the amperage. I am sure it is due to the difference in the VF of the two emitters mostly.
Without doing anything other than the emitter swap the HI emitter was making 1110 lumens at 4.97 amps at the tail while the dedomed SST40 is making 1557 lumens at 5.89 amps with the stock Driver that came in the M1.
If both emitters were pushed close to their maximum amperage in this light I am sure the SST40 would have a much better throw due to the shear amount of lumen output , but you would also have way more heat from the SST40 and way more amperage draw also with much less runtime from the SST40 than the HI.
Overall I think Maxtoch did a pretty good job of balancing the amperage , output and run time to be using the SST40 emitter really and it is a pretty good little thrower in the end.
I did take some measurements and I forgot to write those down unfortunately , but if my memory is serving correctly I think it was 649000 for an ANSI meter throw of 804 meters?
Great review and vid Robo, Thank you, looks like it’s time to buy a new Max, not to sure about the knurling but if you say it’s alright then it’s alright, will give it a go.
Thanks again…!
Edit: Speaking of knurling, I can’t seem to recall but one light that had knurling anyhow.
I personally love those rubber grip things, use them on a lot of different lights, wish I could buy a bunch of them.
Thanks and YW…….Yes it don’t look like much , but the little ribs across those raised or higher spots do have a fairly good grip to them , much more than I anticipated when I first looked at the light.
800m from the specs = 160 kcd, which is very good for a C8 size flashlight.
This light looks much nicer than a C8, performs best in this form factor, has a simple and useful clicky UI and being a Maxtoch must be very robust, and personally I like the rubber grip ring. It is nice to see that Maxtoch does not go with the flow of e-switches and fancy UI’s. :+1:
Lack of sleep is a serious number scrambler, it’ll get ya every time! Coffee, bold strong coffee.
6490 (meter lux reading on x10 setting was 649) x 25 (5M measure distance) = 162,250 (162.25Kcd) for 805.61M throw.
I need one of these. lol Seriously though, I like the look and size, like the reflector, might change the driver but I really like the overall form factor a lot. Thanks robo…
I had the right number in the wrong place and without writing down anything the other day when I did the figuring I got the numbers mixed up in my head.
The 6490 was my meter reading the other day and it was a x 10 factor , so the throw and kcd numbers you 2 guys figured were right on the money.
I was wondering why you didn’t show up on this thread yet… I knew this light was your type of light. I’m assuming this will dethrone your nitecore p30 now, but not your olight m2xsut
I made room for this last night by giving my Shooter 2X with sliced and diced SST-40 to my nephew. Now there’s an empty space that needs filling. Gotta love it when a plan comes together…
Oh, and as it so happens I have a lone LED4Power driver sitting around waiting for a home that is just coincidentally a 9A variant. Man it don’t get no better than that! lol
