if only you can measure lumen, the main problem with zoomies is they lost a lot of light when zooming out
Unfortunately, I cannot measure lumen on this! I have a luxmeter, but I guess it won’t help that much without a tube :zipper_mouth_face:
It surely loses some lumens when zooming out, of course, and that can be seen naked eye!
I normally don’t care much about numbers as well (unless to have a “relative” percpetion or the general output vs my needs), as I will use the light according to space it will light, close or distant!
If I manage to measure the lumens zoomed in and out I will post them here, though
Thanks for reading! :+1:
How good is the lens? Does it throw well? Has anyone put a white flat in their i3 already?
I mentinoned this on the review:
The lens is well made, it is glass not acrylic, so it has good quality! The flashlight allows 1 cm to zoom in.
I didn’t mod it yet, but it is on my plans to put a black flat or XPL-HI led on this, I am just waiting to get a nice driver as well, what will take a while (I’ll probably buy from MTN, 15cm driver with guppy3drv).
With an XML2 U3-3C, it throws at 45-50m, as shown in the images above (click on them to see a bigger picture)! I believe that with some more power and a different LED it will thrown more.
There will always be some “artifacts” on the beam due to the reflection on the reflector and bezel, but it surely is different than other cheappo zoomies with non glass lens
BTW, look at the links from djozz mods on post #1, he made some mods back then with an older version!
Has anyone seen an 16340 aspheric light with a magnet tail cap (side switch operated)?
AliExpress has lots of those side switch zoomables to which we can add a magnet on the tail, but those are “crappy” lights!
A good light, zoomable with side switch and good UI…is missing!
The tail switch on this i3 somehow avoids a longer length that a side switch would require due to a bigger head (to have space to push-pull).
It would be nice if lights like the Klarus Mi1C or the Utorch S1 mini were zoomable as they already have the aespherical lenses…
Yesterday I modded the OTR i3 with an XPL-HI U6-1A (bought from Convoy Store). I will mod it later with a OSRAM LED, but didn’t ordered it yet Also, I will mod it with another 15mm driver but…I still need to order it as well!
So I kept the original driver, changed the LED and blackened the lens, the “reflector”, the gasket, the bezel and bit of the MCPCB plate with permanent marker!
Here are some photos of before and after.
The “blackening” surely helped to remove rings despite there is an “halo” when zoomed in! I wonder how it will work with the OSRAM
Only tonight I will be able to check the distance it covers and compare it with the previous LED configuration.
More beamshots will follow
Nice mod. But XML2 stock looks much better imho. Lets see what other guys think.
Looks like you can’t focus it on the die properly…
Hum, can you explain a little better why you think that? Does it have to do with the beam, colour?
Or is it related to what Agro said?
If so…that was my flaw :person_facepalming:
My cellphone has some issues focusing sometimes, and I guess I missed that good focusing manually :zipper_mouth_face:
Sorry. In reality, you can see the LED details, all of them with a good definition!
Heres a zoomed in photo of the zoomed in beam
I will tell what I feel about the new LED and the overall mod!
a) The beam while zoomed out is rounder, ’cause as you can see, with the XML2 sometimes it looked squarish due to the LED+gasket combination.
b) The tint is obviously cooler, but I wanted to try the U6-1A because the U6-3A (Neutral White) gave me some tint shifts on the Odepro KL52, so I wanted a cooler tint to avoid that. So far, so good (allied to the other mods, namely the blackening).
c) The zoom in is very good but some “yellow dots” of the LED can be seen against a white wall/surface, at a certain distance, as seen on the 1st photo (more or less :D) !
d) Outdoor, I feel like the zoom in functions better with the XPL-HI, while the zoom out worked better with the XML2 due to the tint and eventually the “floodier” beam. I guess that domed LEDs will work better on the Zoom Out situation!
And here are some night beamshots! I guess the distance covered is a little bit more, but I can’t measure it correctly (specially because it’s raining and there’s a foggy night coming, eventually)! I will check this again when I get the new LED and driver on this…despite it will take a while :weary:
The house (right photo) is at 70m!
Feel free to make comments, please!! I wanna improve my skills and mods!
And thanks for your comments so far
The problem with using XP-L HIs in aspherics is that the flat layer of silicone on top of the die is lit up by the die and shows up in the projected image.
So you have the square hotspot, and then a bigger square which is the whole LED die.
If you want a sharp and super-clean hotspot I highly recommend using a dedomed LED or one of the osram LEDs which have nothing on top of the phosphor
Great job though!
Oh well, that’s what make that “frame” around the die (in the reflection)!!
I will do that mod, with OSRAM Led, to see if it improves the distance range and eventually the overall shape of the zoomed in beam! I tried to minimize all the other things that contribute to the reflection (inside and outside) but I guess that only a better led will make the beam more neat
Thanks for your words, explanation and suggestion too :+1:
I’ll post my “results” when done
Last week I put a FET + 7135 Driver - 15mm - MTN-15DDm , with Crescendo firmware, in my On The Road i3!
This was like a “second chance” not only for the flashlight, but also for that driver and firmware
If, on the one hand, the previous UI was less attractive, on the other hand this driver and Crescendo gives this light a better usability and also makes it have better luminous levels, namely a moonlight mode and a higher max output.
I am still using the XPL-HI U6-1A (CW) and the OTR batteries (non-high drain)
Here are some photos in comparison with the Odepro KL52 (XPL-HI U6-3A + Astrolux X5/X6 Driver) !
Lowest level & Highest Levels
OTR i3 >>> Odepro KL52 (the Odepro produces lower and higher levels, but the OTR i3 has improved significantly with this mod!)
OTR i3 (measured through Google Maps!)
70m >>>>> 185m >>>>> 210m
Nice.
Thanks Agro!
I know you like zoomies too, so I’ll tell you this is a nice light for it’s size.
I had to rework in the lens a little bit (using black marker in the base to avoid some artifacts) and also painted in back the edges of the XPL-HI Led to avoid the white box around the center. It is working good, specially with the new firmware , and being this small it is useful on the one side and “playful” on the other
I can’t avoid the constant push-pull on it :partying_face:
In terms of illumination, I guess the photos speak for themselves
Yeah…
I’ve had a very similar build in my head. Just with high-CRI XP-L HI. Didn’t think about Crescendo but it would likely be a good choice for me.
But it’s really a bit large to carry on my neck. I wear Foursevens Mini Turbo sometimes and it’s too large already but I love the punch that it offers. i3 has the same diameter but is somewhat longer…So I’m not really into getting one but it stays there at the back of my head. And if I had one it would surely have its use.
Hum, a High-CRI in this would be nice, specially when zoomed out :heart_eyes:
I opted for the CW, as I was trying to get more light out of it. I should have used a Neutral White, specially for indoor use. But…I still have in mind to change it and eventually use a Luxeon V or V2 on it
Yup, to neck carrying it is quite bulky, the head is large in this light! Larger than the 4Sevens, I’m sure! It can be a light to carry in the pocket or jacket, maybe, and that’s the way I’m using it after this mod.
As for neck light, I’m carrying the RovyVon Aurora A8
BTW, if you even decide to buy it and change the driver, please be aware that 15mm drivers fit, but only without springs or 7135 chips in the back. There is small space for the switch spring and the battery itself!
Thanks for the note.
BTW 47 Mini Turbo has one inch diameter. So actually slightly larger than this.
Too large to be usable on a short string but if it goes down to my belly - it’s actually OK. Surely not something I would call practical though.
Ooops, I confused the flashlight, thought it was the thinner
Ahah, only issue I see with these big neck lights is we have them in the chest some friend slaps you there and we scream an “Ouch!!!”
They also make a big bulb under the shirt.
And can get really uncomfortable while sleeping. That’s the only issue that matters really.
