My C8 is running an XPL-HI. I like it a lot, but I find it a bit slow when I want a quick powerful beam of light to enable me to spot my dog.
Hopefully the SP31T will be able to run higher current.
What do you mean by slow? You can get a bit more power by going with a lower Vf emitter like a sliced SST40.
Do you think you want more beam intensity or beam width or both?
This is the light you’re talking about:
You can’t expect readers to keep up with the Sofirn catalogue.
You like the C8.
Go for a C8+, and upgrade if necessary.
Nicely balanced torch to carry that one
and well upgradable to more beam plus…
C8+ is not a C8 though…
But he wants a side switch and more throw/more power.
Since he has already bought the sofirn, there are a few options.
If the OP wants more power and throw there are better lights than the sofirn to get it, but since he already bought it, I think the above options are what he has.
This light uses a buck driver, which is not such a good idea with an XP-L HI or XP-G2 because they have high Vf.
The “White Flat” would work very well i.m.o. Low Vf and very tiny die.
Yep.
And since it’s a regulated buck driver, that means not only will the LED run in a good and efficient zone, but it will stay at max brightness for a long time.
It will also give you a ton more throw.
The buck driver most likely is not powerful enough to drive any of these emitters optimally, so it will have to go in any case.
If C8 reaches high output too slowly, change mode group and/or use mode memory?
I can go from off to turbo in under a second on my Atrolux in 4 mode without memory…
By ‘slow’ I mean it takes too long to scroll through the modes to get to full power.
What I’m after is instant full power as soon as I hit the button. I don’t really want multi modes on this particular torch.
I’m sure my C8 could be made to throw a bit further, but it’ll never have the side switch that I want.
I don’t want a tiny spot of light either. I’m happy with the XPL-HI, but need a bit more range.
This light hasn’t cost a lot, so if the consensus is that it’s not right for the job, then I’m open to suggestions, but I want something that fits in a jacket pocket.
You should just be able to set mode memory on to achieve that. What version of the C8 do you have?
I’ve fitted a A17DD fet driver to my C8. Can’t remember what the tail amperage is though without checking.
For speed I prefer a side switch to a tail switch
I certainly wouldn’t try to dissuade you from buying/modding another light (I think that’s like… illegal here?) but in the meantime you can use this to set up the mode memory on your C8 and IDK if you’re on 4-mode or 7-mode but changing that will make mode switching way faster too.
3 or 4 mode driver, mode order high to low no memory
you always come on at turbo, just to lower output need to cycle
I got Bistro HD OTSM drivers for most lights including the C8
Yes, I can change the UI so that the C8 goes straight to turbo, but that won’t increase throw or make it any easier to handle/switch on.
I need a bit more throw than I’m getting with the C8. My L6 throws further.
Thinking of a SST-40 driven to the max.
Yes, although it depends on what you consider optimal.
Don’t know if the stock driver is moddable to do 4 Amperes or 4.5 Amperes.
I mean, you can put another sense resistor on top of the stock one, but the coil may get too hot…
This Sheet is private
SST-40 wont beat XPL HI for throw in a C8 unless its dedomed. Youre gonna get more backscatter/glare unless ypur C8 is already cool white too.
D1S, GT Mini or Oslon emitter in C8 are the only real choices for more throw from the same size light.
Whilst talking about the C8 and wanting a bit more throw:-
I have two Convoy C8s, an unmodified Silver one and a modified black one. The Silver C8 has 2.8A at the tail on maximum and the Black one has 4.3A at the tail on max. The thing is, there is little difference in throw between the two, to my eyes at least. I would have thought the modified one would throw noticeably further.
Same emitters, etc. between the two? Maybe the higher amperage one is a lower output bin or outlier emitter too? Hard to say with only current measurements.
