I have doubts about this device.
I need to do some tests using the DC Calculation method to verify but I’m getting results that aren’t consistent.
That said, I removed the cable separator because the leads were too short to get to both sides of my batteries.
Does anyone know if there is some magic in that simple plastic separator that could affect the readings?
Thanks for sharing! That would be a useful baseline reference.
I only have a few of those batteries from your list. I don't have the SM8124A, but instead got the YR1030. I wonder how different the measurements taken by the SM8124A compared to the YR1030...
FWIW, it takes a lot of patience and two calm hands to get useful values with the SM8124A.
Especially, with button top batteries it’s quite a nightmare to align the probe correctly in order to get useful information.
I guess it’s the same with the YR1030 from Vapcell. They had it for a very decent price on Black Friday. Unfortunately, I forgot to buy one as I would have liked to verify my values with a second device.
LOL…“PITA”…that’s exactly what it feels like.
Later on, I try to amend my chart with values I took from my 26650s (Shockli 5.500mhAh, Keeppower 6.000mAh, Dolidada Fake PLB-55-As, Thrunite 5.000mAh, etc.).
I have now added some more batteries. All cells were measured in new, unused condition. However, the 26650 cells I bought had some differences between them.
I also got 3pcs 30Qs bundled with the Fireflies ROT66 (I am unable to purchase 30Qs without flashlights [bare batteries from any foreign online store cannot ship to my country, except if inside a flashlight], so all my 30Qs are only purchased when I purchase a flashlight, either the “BLF A6+30Q” or the “S42+30Q” bundle from BG).
The 30Qs I got from BG have lower IR than the 30Q I got from Fireflies… Will do some measurements again. Forgot the figures but there are noticeably higher IR, measured either using the MC3000’s IR test or with the YR1030 battery resistance tester.
I think it was mentioned somewhere before that battery manufacturers use the AC method to grade the cells and then sort them depending on the results. It seems there may be A-B-C and possibly even D grade cells of the same make that are then sold off accordingly.
I am pretty much amazed about the extreme low impedance of the Tesla cell (Sanyo NCR21700A 5.000mAh 15A).
Format
Name
Type
PCB
Impedance (mΩ)
21700
Samsung 30T
FT
6.0
21700
Samsung 40T
FT
7.4
21700
Sanyo NCR21700A ("Tesla")
FT
11.2
21700
Sofirn 4.000mAh (w ring)
FT
13.5
21700
Sofirn 4.000mAh (w/o ring)
FT
13.6
21700
Efest 5.000mAh
FT
20.6
21700
Samsung 50E
FT
22.0
21700
Acebeam 5.000mAh
BT
x
30.4
20700
Acebeam 4.250mAh
BT
x
21.6
26650
Shockli 5.500mAh
FT
12.5 - 12.6
26650
Shockli 5.500mAh
BT
12.7 - 13.0
26650
Keeppower 6.000mAh
FT
16.4 - 17.5
26650
Keeppower 6.000mAh
FT
x
31.5 - 33.2
18650
Sony VTC6
FT
11.8
18650
Samsung 25R
FT
12.2
18650
Samsung 30Q
FT
12.5
18650
JetBeam HR26 2.600mAh
BT
x
16.5
18650
Imalent MRB186-P30
BT
x
19.3
18650
Wuben 2.600mAh
FT
23.4
18650
Sofirn 2.600mAh
BT
x
41.9
18650
Sofirn 3.000mAh
BT
x
45.2
18650
Xanes 2.600mAh
BT
x
45.3
Obviously, Sofirn rewraps cells of different manufacturers as can be seen on my comparison of two Sofirn 21700 4.000mAh batteries. Both batteries were part of two C8F 21700 flashlights. The one with the recessed ring in the bottom seems to be a Lishen 2170SA. Fortunately, both the one with ring and the one without seem to have similar specs in terms of capacity and performance.
I have been pretty happy with my YR1035+. I chose it because it displays more digits. It also has a backlit display and a rechargeable battery inside. I had it for a couple of months, but I only charged it once.
It displays up to 4 decimal places in voltages for Li-Ion batteries, 2 decimal places for internal resistance in mOhm range. I cannot tell how accurate the numbers are, but the numbers are at least very consistent when I measure the same battery multiple times.
