[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
The ramp curve is not a neat thing that can be easily calculated and implemented based on pure theory, one size fits all.
Particularly once you start multiplexing in a FET for direct drive at the higher levels, mixed in with the characteristics of particular cells, be they brand new, or aged, full charge, or lesser (realistic).
Hence the need to try to wind things back, where there is an obvious miss-match between the capabilities of the LED and the cell, and the thermal capability of the rest, ultimately leading to consumer dissatisfaction, warranty claims, reputational damage, if not addressed.
It has to be tuned, subjectively. But if you use a TK derived firmware, you can always change it to suit your own preference, if you take the trouble to learn how.
Frankly, you might be better off using modes. I do, after having given ramping a good shot. Which also allows me to have a pretty good idea of run-time at each level, which is important to me, and at what level the torch is going to turn on at…
Then there are the actual characteristics of the LEDs, which are all different. We have a couple of experts who do their best to measure them quantifiably, but manufacturers have to source what is available, which may be very different.
Then there is the subjective discussion based on no data, except observations such as “I like it. I see a hint of green. I cannot tolerate any hint of green. It is nice and rosy, creamy white, too cold, too warm, Goldilocks’ bears wouldn’t eat it. I expected a miracle gazillion lumens but only got what was obvious from a few minutes research of e.g. Maukka and Djozz test results, etc.
And in each torch design, the effects of e.g. good, or poor thermal management, and ambient temperature, and driver design, component selection, even things as seemingly simple as springs, will alter the actual response of the LEDS, brightness, tint shift, etc.
Which is what makes it interesting.
Ultimately you can only use your own eyes (all different) and decide what you like, subjectively. This is not a subject where numbers count for much at-all, no matter how tempted you are to try to put things into neat little boxes, and insist on asking questions such as “what is the best … I must have the best … and the brightest … I want lumen numbers only, because I don’t understand what candelas are and just like simple numbers, … only the best bin is good enough (all the rest should be binned) but I don’t want to pay any more, I won’t buy it unless I have a discount code, and I want it now, why don’t I already have it, It must be below the BBL (not that they have any idea what the “BBL” represents, that would take a little bit of scientific knowledge and critical understanding of why, instead of a buzzword to fixate upon), such discussion is frankly Wank.”
Otherwise it is worthless, e.g. the usual “my tracking number isn’t working, I’m going to file a PayPal complaint and get my money back, I will never trust this outfit again, etc. etc.”
It’s hardly a matter of life and death, but it is a livelihood for the suppliers who make these esoteric things for us, but don’t quite perform as well and in a timely matter, nor communicate as some would expect, it is a different culture, for individuals particularly so.So cut them some slack. Otherwise we’d still be thinking that a Maglite was the height of sophistication, and something to aspire to owning.
Or that crude FET+n drivers derived from Comfychair’s great Nanjg mods, back in the day, are still the bees knees.
Rant over, but really, this is just a torch that deserves to do well, despite the sniping and negativity. Whilst being realistic about what is realistically possible, and delivering.
My PL47 just hit the USA. 17TRACK showed it as not even received from the seller on the China end all this time. This is how bad overseas tracking is. You have to be patient. Then there’s the slow cargo ship that got caught in a big storm, my flashlight went overboard, got swallowed by a kracken, he shat it out, a dolphin found it and used it to light his way to Nova Scotia, he passed it to some Canadian geese who used it to light their way flying to Florida for the Winter, they dropped it (butterfingers) over the harbor in NYC, it landed on a pimp who traded it for some rock candy with a lady who also works at a mail sorting center, it then fell out of her pocket and got scanned into the USPS shipping system and now I have some tracking finally. Whew. Look at the positive, at least it’s tested as working :smiley:
Go for a e07 and use 40t.
Pl47 should be fine with 18650.
Just received mine. At first it worked fine, but after I unscrewed battery tube and screwed it back, flashlight stared on turbo and can’t be turned off. The only way to turn it off is to unscrew tail cap. I tested with LG 21700 which i got with the light and Sanyo GA with the adapter.
Any idea why is wrong with it?
It’s in the PL47 config file, but if I recall correctly I think the default ceiling is set to ramp level 120 of 150. And I think that works out to about a 30% to 50% of the full lumen output, but with all the nonlinear response curves involved it’s hard to say exactly without measuring.
If a light is in full turbo any time power is connected, that usually indicates a short somewhere, allowing current to bypass the driver and go straight to the LEDs.
That makes sense, I guess I should contact Fireflies then.
Thanks for the fast response ToyKeeper .
As you guys know, skylumen have two dead pl47. FYI
Any details posted about that somewhere?
It may or may not posted… I communicate with him on the Facebook messenger.
I bought the XPL Hi V2 3A 5000K Neutral White. I’ve been reading about some battery restrictions for the Nichia 219B. Other than some of the size issues are there any amp issues? Can I use an EFEST 35A for example?
Finally received my lights. After being held in my local postage service for a week.
Had that same feeling too! Red led ?
post #192
The red light in the center is a warning that the voltage is low.
It happens when unscrewing the light because, for a very brief moment, the voltage passes through the “low” range before it hits zero.
It also happens when the battery is genuinely low.
Nice feature!
I just got my pl47 219b. I am not happy with it. I put 10 amp 18650 and the light goes straight to blinking mode.
I can’t switch modes… it stay on low…
How can I reset to factory ramping mode?
did you tighten the rear cap well?
My other pl47 xpl hi 5000k is working fine…
This pl47 219b is no good… aux was off from the factory… i click 7 times to turn it on…
When i press the button, th aux will turn off… then the low mode came on. Then the light switch modes by itself…
Junk junk junk
Here is the video for the pl47 219b. Is my pl47 defective ?
