If loosing some throw and about 5% lumens doesn’t bother you too much—- Try some DC Fix —-It works well in these cases
Like robo819 shows above, dicing the phosphor off the substrate goes a long way towards eliminating the unwanted tint shift on the flip chip emitters.
When the dome is on it’s somewhat difficult to see where the die actually is, but once the dome is sliced off it’s much easier to see the actual die and make the vertical push cut down to the substrate, a flick outward then usually dispenses of the phosphor that is layered onto the substrate. I don’t do this so much for gaining throw as to rid the beam profile of the ugly tint shift in the aura. This is what I refer to as a slice and dice.
Finally finished my last GAW light!
Built these 2 drivers (all 0603 components and legs bent in on tiny85’s)
Stacked them together, wired the Nitecore stock drivers switches and switch LED to them with 32AWG wire (first pic is first driver of stack up going in and being wired then second driver set down on top and wired)
Dual drivers tested and running, just waiting on mcpcb glue to dry to assemble it!
Edit teaser pic for now, video of running tint mixer light coming later once it’s dark out.
Your solder-Fu is much greater than mine!
Orsm work Ck. I greatly admire your skills. I wish I would hurry up and grow up so I can be just like lots of members here.
Nice C_k !
Your pics load slow, I think because you insert them full-res. You set them to display a screen percentage so it displays good, but the page still loads the full file sizes.
Great work CK!
I put a 4000k sst-20 in my D1.
It cleaned up the beam a bit, less tint shift and hcri.
Thanks!
I’ve noticed that too, I host with imgur, how do I get downgraded images for posting?
You can upload them in smaller resolution
There are some resolution options on “Auto resize”. I normally upload mine in 1024x768 and they open fine!
Besides this: AWESOME work!!! I wish I knew the things you and many other people know, machining, soldering, electronics…
Great work!!! :+1:
I use flickr and although it is a pain to extract the links for use in inline images, they do offer links for a variety of smaller sizes of your uploaded picture.
I do not know how that can be done with imgur.
You take the URL and add a letter at the end.
Thumbnail Suffix Thumbnail Name Thumbnail Size Keeps Image Proportions
s Small Square 90x90 No
b Big Square 160x160 No
t Small Thumbnail 160x160 Yes
m Medium Thumbnail 320x320 Yes
l Large Thumbnail 640x640 Yes
h Huge Thumbnail 1024x1024 Yes
Also I found ‘r’ makes 1456 x _, also keeping proportion. So even bigger than the “huge thumbnail”
And I found another, ‘g’ does 728x_ with proportion.
b:
t:
r:
Gave my enogears some love.
Copper mcpcbs and hicri.
Left 219b sw40 9080, right 3000k sst-20.
Nice emitter swaps Geuzzz !
Changed the optic on the jaxman e2l.
It had a frosted wide optic and changed it to a 10507, narrow spot optic.
Actually a very nice and usable beam.
Thnx. Verry nice and warm around the house lights now and muggle proof on nihm.
Never Ender beam
Never Ender beam. I had top read this twice before it sunk in.
“What did you mod today?”
I could better say; “what did I destroy today?”
Wanted to change the LEDs in de jaxman e2l for some LH351D’s.
First I desoldered the driver and wires.
Then I wanted to pry out the board.
I don’t know what type of glue they used but it doesn’t want to come out…
I lost my patience and went on a rampage, destroying the LEDs and led board.
And its still stuck in there.
Looks like I’m going to order a host and let this one sit for a while.
Ha Thijs, since the board is toast anyway, remove the driver and heat the head up to very very hot (not so hot as to decolour the ano) and see if the glue will give in.
