Wuben L50 is a multi-function aluminum flashlight for outdoor use. Cree XP-L2 LED imported from US, simple function operation, stable circuit design, 18650 battery powered, built-in independent charging design, convenient, energy saving.
Main Parameters:
Emitter: Cree XP-L2 LED
Max Output: 1200 lumens
Max Beam Distance: 200m
Peak Beam Intensity: 10008cd
Max Runtime: 143 hours
Battery Configuration: 1 × 18650 Battery
Working Voltage: 2.8V-4.2V
Waterproof: IPX8, 2m underwater
Impact Resistant: 1m
Output and Runtime:
High: 1200 lumens ( 1.5h )
Med: 400 lumens ( 2.5h )
Low: 75 lumens ( 8.5h )
Eco: 5 lumens ( 143h )
SOS: 1200 lumens ( / )
Product Features:
● Fully press the tail button switch to turn on the flashlight and press it again to turn off the flashlight. When the flashlight is on, half press the tail switch to change the flashlight brightness.
● Turn on the flashlight, tap the tail switch to adjust the brightness: Eco-Low-Medium-High-SOS-Eco cyclically.
● Built-in 18650 battery, can be charged cyclically.
● High-tech smart constant current chip, to ensure smooth output brightness.
● Can be used immediately after charging, environmentally friendly, full of about 4 hours.
● With one folder, easy to carry.
● Grade III hard anodized aerospace aluminum body.
● Surface vibration grinding, beautiful design, feel more comfortable.
● Waterproof level IPX8, 2m underwater for 1 hour, cope with all kinds of harsh environment.
It is suitable for camping, fishing, hunting, hiking, searching, working and so on, get it on GearVita now: https://gearvita.com/wuben-l50-led-flashlight-xp-l2-1200-lumens.html
Hot sale products:
xiaomi mi max 3 4g smartphone in stock
xiaomi lyej05lm in stock
