GearVita Daily Deal: Xiaomi Xiaobai Smart 1080P IP Camera - Panoramic HD, AI Humanoid Detection, Remote Alarm
PIR solar sensor wall light automatic ignition by detecting people coming and shutting down automatically when the detection of people abandoned. It works up to an angle of 120 degrees and detects movement up to 3 meters away. With the solar panel, you can convert solar energy into electricity, there is no need for external power, energy efficiency and environmental protection. IP65 waterproof grade, perfect for the garden, patio, balcony, etc.
Product Features:
● Polycrystal solar panel, high efficiency up to 17%, no wiring required, intelligent energy saving.
● High quality ABS lamp body, high temperature resistance, anti-corrosion, IP65 waterproof, damp-proof.
● Easy to install and easy to maintain.
● Import Epistar SMD2835 chip, high brightness, long lifespan.
● Detects movement within 10-26 feet and 120 degrees of angle.
● Integrated design of PIR motion sensor and light sensor, high sensitivity.
● Recharged by sunlight and battery storage power.
● Auto charging in the sunlight, perfect charging time of 6-8 hours.
● Auto turn on the dim light mode at night.
● When people close, auto turn on bright light and continue 30 seconds. When people gone, auto turn on dim light mode again to save power.
● More than 12 hours of lighting time after a light day of charging.
Install it in any place you want where is full of sunshine, the simple fashion design, not only is a motion sensor, light control lamp, but also an ornament: https://gearvita.com/pir-motion-sensor-wall-light-20-led-solar-powered-waterproof-garden-lamp.html
You may also like:
cheap xiaomi 70mai dash cam pro
cheap xiaomi mi band 3 global version
Xiaomi Yeelight Meteorite smart pendant light can be adjusted between the color temperature of cold-warm light and the second weaker RGB with 16 million colors to arrange the right mood. Yeelight Meteorite has two light sources, 12 RGB LEDs with 7W power are responsible for the colorful light on the ceiling. You can change the color using the Yeelight/Mi Home App, scenes with other devices or a voice assistant, including Siri from Apple.
The body of the lamp has been made of plastic, making it lightweight which will facilitate assembly. Total lamp power is 33W, the main light offers a color temperature from 2700K to 6700K, and the light output is from 450lm to 1700lm. Yeelight Meteorite lamp will ideally fit into the dining room above the table, the length is 90cm, thanks to which the whole table will be evenly illuminated. The part which attached to the ceiling has a length of 48 centimeters, it hangs on three cord-wires with adjustable from 0.5m to 1.5m.
Product Features:
● Uses side-lighting technology, 280 light bulbs pass through a high-transmittance light guide plate and then diffused by a diffuser to form a uniform light-emitting effect.
● Professional dining table optics designed for restaurant lighting, luminous flux up to 1800lm, support stepless adjustment of brightness.
● The color rendering index is up to 95, restores the true color of the illuminated object and effectively eliminates the color rendering index, low impact on vision.
● The top of the chandelier has a colorful atmosphere lighting, using 14 lenses, 60 degree illuminating angle to create an even and transparent atmosphere.
● The hanging wire length of the chandelier can be adjusted from 0.5m to 1.5m, the recommended light level for the table is 150lux.
● Color temperature support 2700K - 6500K, stepless adjustment, from warm yellow to cool white light for you and family a specific dining mode.
● Support mobile APP remote control, intelligent voice control, wireless dimmer and wall switch control.
● Supported intelligent control devices and platforms include Xiaomi, Xiaoai, Speaker, Yeelight, Voice Assistant, Amazon Alexa, Google Assistant, IFTTT, etc.
● IP50 anti-mosquito seal design to solve the problem of flying insects and dust accumulation in the lampshade.
Do you associate the Jiaoyue lamp with Ambilight? Yeelight Meteorite smart pendant light is the first product that had a double light source, can achieve this: https://gearvita.com/xiaomi-yeelight-meteorite-led-smart-pendant-light.html
Hot sale products:
cheap huawei honor 10 lite 128gb
cheap xiaomi mi pad 4 lte tablet 64gb international version
Xiaomi Yeelight YLDL03YL pendant light has an unique simple design, not only lighting but also decorating your house. Using metal lampshade material, it is durable and practical. The top is made of the radial hollow structure, which makes it easier for air to circulate inside and outside the lampshade, forming convection heat dissipation, quickly dissipating heat and prolonging the life of the light source. Energy saving and environmental protection without flash, it is suitable for room size between 10 to 15 square meters, can be placed in the bedrooms, study rooms, dining rooms, hotels, etc.
Product Features:
● Minimalist design matches with various decoration style.
● Using down lighting design to ensure even lighting.
● Heat-dissipation hole on the top to prolong LED lifespan.
● 0.8mm thicken mental body, uneasy to deform.
● 100cm adjustable light chain meets a various need.
● Three-layer insulated cable to ensure safety.
The pendant light takes care of even the smallest detail and that are simple while modern are worn. All features are put together, makes it one of the complete options in the market for this price: https://gearvita.com/xiaomi-yeelight-yldl03yl-three-head-pendant-light.html
Top sellers on our website:
best xiaomi huami amazfit bip smartwatch
best xiaomi minimalist portable flashlight
Xiaomi Yeelight YLYD03YL smart induction light abandons power supply, adopts plug-in design, plug and play, no wire is required. It only occupies two-hole position, does not affect the normal use of the 3 socket. Uses infrared induction, the positive induction distance is 7 meters, and the bilateral orientation is 3 meters, provides satisfying lighting experience. At night, there is no need to turn on manually and turn off with 30 seconds delay. In addition, the built-in photosensitive sensor can automatically light up at night/extinguish during the day in normal light mode, it is easy and intelligent to operate manually with farewell.
Product Features:
● Advanced PIR Motion Sensor
Featuring 120 degree wide angle, with sensing range up to 7 meters. Light auto on when a motion is detected at night, and light off 30 seconds after object being out of the sensing range.
● Plug and Play
Plug type, easy to use, simply plug and play, no need to frequently recharge or replace battery.
● Intelligent Recognition of Day and Night
Built-in photosensor, accurately judge the brightness of the ambient light. In constant light mode, it will automatically light up at night, automatically turn off during the day.
● 2500K Warm and Soft Light
Use high quality LED beads, 2500K color temperature, soft lighting effect, bringing you peace of mind, safe to use even in the baby room.
● Fresnel Ultra-thin Lens Technology
The interior uses a unique diffuse optical design that evenly disperses each beam to ensure soft light without hurting the eyes.
● Low Power Consumption
0.4W ultra low power consumption, energy saving, and long lasting to use.
Yeelight YLYD03YL plug-in smart induction light can fulfill your imagination for night light, it adopts round elegant outlook and fits dual sensor inside, not just about night light, it's all about lifestyle: https://gearvita.com/xiaomi-yeelight-ylyd03yl-plug-in-smart-induction-light.html
Hot sale products:
best huawei honor band 4 running version
best xiaomi 70mai dash cam pro
Boruit B23 headlamp is a night fishing headlamp that comes with two kinds of lights: white light and red light. The white light with high brightness and long range can illuminate everything, suitable for patrol hunting. The red light does not stimulate the pupil, night version is better, not easy to attract mosquitoes, suitable for night fishing and camping.
Main Parameters:
Light Source: LED bulbs
LED Bulbs: 1 × XPE(White) + 1 × 3030 COB(Red) + 12 × 3030 COB(White) LED
Light Color: White + Red
Material: Plastic head lamp + elasticity head band
Brightness: Up to 15000 lumens
Lighting Distance: 200-300m
Wattage: 10W
Beam Angle: 180°
Switch Mode: Zoom out
Battery Type: Lithium ion
Power Supply: 2 × 18650 batteries
Charging Time: 8 hours
Working Time: 4-6 hours(depending on battery capacity)
Product Features:
● LED output lifetime can up to 100,000 hours.
● With 2 × 18650 batteries, the illumination is high.
● Brightness is adjustable to meet different demands.
● The lamp head angle is adjustable by 90°.
● Micro USB port charge, support variety of charging methods.
● After staying for 5s in any gear position, enter the memory function.
● Main headlight is IPX6 waterproof and battery pack is IPX4 waterproof.
● Adopting elastic and breathable headband, it is soft and comfortable to wear.
It can be used for patrolling, camping, picking, hunting, night riding, night fishing and more: https://gearvita.com/boruit-b23-xpe-cob-red-led-headlamp-15000-lumens.html
You may like:
best samsung evo plus micro sd card
best raspberry pi 3 model a+ motherboard
Xiaomi Lofree candly ambient lamp can lighten up any situation whether it's a lively house party or a relaxing girls night in. It offers dual lighting modes to switch the electric flames from static to candlelight and vice versa. The lamp is equipped with 1800K of adjustable LED brightness, you can set it to whatever suits your mood by the charming knob on the side. With the built-in 2200mAh battery, it can stay on continuously for 20 hours at low light.
Product Features:
● Comfortable Texture
The lampshade is made of transparent acrylic material, which feels comfortable and the bottom is made of ABS material to extend the service life.
● Rotate to Adjust The Brightness
The 1800K LED light source is used for the light, and the brightness of the light can be adjusted by turning the knob from . In the low light, even in the darkest environment, it is very soft as if the air is warm.
● Charging for 3 Hours
The built-in light 2200mAh large-capacity lithium battery, the low-lighting can provide up to 20 hours of battery life, just charge about 3 hours, you can live a full day.
● Dual Mode Charging
When it does run out of battery, just charge it via the micro USB cable or through the charging base.
● Dual Light Modes
General lighting and Candle lighting.
● Convenient to Carry
Comes with a lanyard which is soft and comfortable, more durable than ordinary lanyards.
Inspired by soft candlelight flickers and vintage lanterns, Candly is a lamp that flickers to the rhythm, can brighten any atmosphere and room, is the perfect light for friends and families to gather around: https://gearvita.com/xiaomi-lofree-candly-ambient-lamp.html
You may also interested in:
best lenovo z5 pro 128gb
best xiaomi mi portable mouse
The Boruit D25 headlamp uses Cree XM-L2 LED beads with a max output of 1900 lumens and a max beam distance of 150m. Coming with 6 modes for various lighting demands, it is an essential and first choice for hiking, camping, touring, home using and emergency lighting etc.
Product Features:
● High-quality and super bright LED beads, energy saving and environment friendly, long-lasting output can up to 100,000 hours.
● Made of durable aluminum alloy with high-quality anodizing case, durable and practical.
● Small body, lightweight of just 0.09kg, easy to carry.
● Performance with excellent heat dissipation structure.
● 6 lighting mode adjustable - low light/high light/stepless dimming/strobe/SOS/slow flash.
● Button switch for easy operation in the head of the headlight.
● Detachable design, can be used as a flashlight.
● Ergonomic design, high elastic pattern webbing, comfortable to wear.
● Micro USB charging interface, supports a variety of charging methods.
● IPX6 waterproof.
Powered by 1 × 18650 battery, it is not only a headlamp, but also a flashlight: https://gearvita.com/boruit-d25-portable-double-head-led-headlamp-1900-lumens.html
Hot sale products:
lenovo s5 pro global version
honor play 64gb smartphone
Xiaomi Yeelight Jiaoyue ceiling light has the diameter of 650mm, the lighting surface is significantly larger. There is an RGB light strip on the back which acts as an ambient light. After setting up with the Mijia app or Yeelight app, you can adjust both the main light and the ambient light. Moreover, you can add the Yeelight to Google Home and adjust both of the lights. Specifically, you can use your voice to adjust brightness and color temperature of the main light, and change color of the ambient light. The RGB ambient light can display 1600 million colors, so you can easily choose a suitable color for your mood.
Product Features:
● Multi-way to Control Linkage with Smart Devices
Can be remotely controlled not only via smart phone and Bluetooth WiFi controller but Xiaomi AI speaker to voice adjust and control the CTT and brightness.
● Easy Fast Installation And Removal
No longer trouble for the installation and removal with the unique couple quick-installation module, just slightly push the slide lock to install and remove.
● 1600 Million Color Ambient Lights
Using quality RGB strip light, freely switch between 1600 million colors.
● Render The Brilliant Colors
Applying museum lighting standard the color rendering is up to Ra95 to render the original color of objects and effectively eliminate the impact from low color rendering index on vision.
● Adjustable CCT from 2700K to 6000K
Warm lighting, white lighting is free to choose to meet various needs.
● Unique Moonlight Night Mode
With ultra-low brightness of only 1.5 lumens, bright enough for you to get a cup pf water at dark night without disturbing your families.
● IP50 Dust-proof Design
Use IP50 dust-proof sealed design to solve the troublesome problem of backlog of dust and insert in the lampshade.
● TV Backlight Technology Makes Softer Light
Using TV lens technology and high-density lamp beads arrangement technology to fully divergent the refracted light to bring you a more gentle and more uniform visual experience.
● Bluetooth Remote Control
Comes with Bluetooth remote control that built-in CR2032 battery, without worrying about signal blocking.
Using PMMA blow molding process, the surface is smooth and translucent, and the internal film printing process. The light passes through the lampshade, shines brightly like a crystal, creating a starry sky effect: https://gearvita.com/xiaomi-yeelight-jiaoyue-ylxd02yl-650-led-ceiling-light.html
Hot sale products:
mi mix 3 global version
xiaomi mi box s
The Xiaomi Yeelight ultra thin ceiling panel light features modern simple style, not only lighting but also decorating your house. Made of high-quality material, this light is dustproof, rustproof, corrosion-resistant and anti-yellowing, suitable for lighting for kitchen and bathroom.
Product Features:
● White Slim Body
1.3cm slim body is close to the thickness of smartphones, simple appearance and classic white color, make it easily match with varieties of home style.
● Ra83 Color Rendering Index
Made of 96 LED beads with a great output of 1800lm to ensure high brightness.
● Two Color Temperature
4000K warm light and 5700K white light for different home improvement needs.
● Uniform Light Effect
Using side-emitting technology and special optical structure design, uniform light effect forms when the light through high-transmittance cover.
● High-quality Material
Delicate aluminum alloy frame, bright and clean. High-quality PMMA panel, high transmittance. Brushed aluminum backplane, efficient cooling.
● IP50 Dust-proof
The seamless frame prevents from fear of invasion from mosquito and dust.
The panel light can bring you a great visual experience of tidiness, show you a new looking of your home by the bright and soft light, say goodbye to the darkness: https://gearvita.com/xiaomi-yeelight-ultra-thin-led-ceiling-panel-light.html
You may like:
mi pad 128gb
honor band 4 running edition
Xiaomi Sothing Sunny night light features a very elegant design, the brightness is between 40 to 50 lumens, with 3 different modes of operation. The 500mAh battery can be recharged via USB, will provide a range of up to 20 hours activation time. It comes with motion sensor which is an automatic mode, it will turn on when someone passes by and turns off after 20 seconds. In addition, it has the possibility of being able to separate from the main body of the support and thus to take it where we want.
Product Features:
● Separating Magnetic Design
Connecting the foundation with the lamp by magnetic, without bolt. Using the "two points positioning" design to keep the inductor in the front always.
● 500mAh Internal Battery
Normal use can charge for 4-6 months at a time, always bright for 20 hours, waiting for wake up at any time.
● Intellisense
The sensor's effective range is 0-3 meters and the angle is 120°. The night light will turn on and keep 20 seconds when people walks by, and after 20 seconds, it will turn off automatically.
● Double Smart Inductor
Built in light sensor and PIR sensor.
● 3 Working Mode
ON/OFF/Auto, 3 working mode adjustable.
● Alete Mucilage Glue
Suit for all kind of slippy wall and furniture.
If you want a night light, you can not miss this new Xiaomi Sothing Sunny night light. It is available in two different colors, really a wonderful light: https://gearvita.com/xiaomi-sothing-sunny-smart-induction-night-light.html
xiaomi mi mix 2s 128gb global
huawei honor watch magic
Xiaomi Youpin V03 Bluetooth speaker night light built-in 84 RGB lamp beads, creates 360° light display. Following the colorful rhythm of the music, easy to create a cool light show. It comes with 5 light and shadow mode for you to switch at will.
Product Features:
● Vocal Highly Restored
Two 52mm full-range professional speakers, one 65mm low-frequency radiator at the bottom, built-in 20W Texas instruments high-power amplifier and DSP, achieve 360 ° shock surround sound.
● More Convenient to Control
The top touch panel can switch light and volume. Click the light button to turn on the night light mode, slide or tap the touch panel to adjust the light. Long press the switch button, connect to Bluetooth, slide or tap the touch panel to adjust the volume.
● IPX6 Full-body Waterproof Design
The precision body waterproof design achieves IPX6 waterproof effect, no need to worry if it falls into the water for a short time.
● Long Lasting Life
5200mAh lithium battery, 6 hours continuous playback (medium volume), music more lasting.
● Bluetooth Connection, Wireless Freedom
Bluetooth version 4.2 , within 10 meters, compatible with a variety of smart devices. Built-in microphone, short press the power button when a call comes in, one button to answer is convenient and fast, more support for sound card, LINE IN playback.
● Concise But Not Simple
333 components, 122 spare parts, 58 structural parts, more than 100 technological processes, for a better product experience and a more concise appearance.
Let the eyes see the heartbeat of music, let the ears hear the dancing of the lights: https://gearvita.com/xiaomi-youpin-v03-bluetooth-speaker-colorful-night-light.html
Other hot sale products from Xiaomi:
xiaomi mini speaker
xiaomi mi 8 pro 8gb
The entire system of Xiaomi Youpin Nanoleaf smart light plate is fully customizable, it is composed of 4 panels, each panel has a triangular shape, can perform multiple shapes or patterns. Compatible with Apple HomeKit, Amazon Alexa and Google Home and other smart home platforms, it is easy to achieve voice control after connection. Each triangle has 16 million colors, and with the dedicated apps, you can assign them different colors and brightness. As the fingertip moves, the color begins to flow.
Product Features:
● The modular design of the triangular plate allows you to distinguish it from the ordinary light bulb at the first sight.
● It is like the building blocks and the jigsaw puzzle, can be put together into the shape you want, to stimulate the artist in your heart.
● Each smart illuminating board has 16 million colors, through the intelligent control of the APP, you can adjust the brightness according to different usage requirements, stepless adjustment, color temperature, brightness and intensity change.
● Inserting the connecting piece easily connects the light board, and the installation and disassembly become so simple.
● Connect to the rhythm sound instrument, the odd light board can show every song you like through the dance of the light, feel the rhythm of the radiance.
● Using Cortex-M4 high-speed chip, 50ms speed response, simultaneous interaction of light and music.
● Energy saving, good light efficiency, longer lasting.
Xiaomi Youpin Nanoleaf smart light plate can not only light up your colorful life, the modular design also gives new improvements to your work space, leisure or rest with visually endless possibilities for shape, light and color: https://gearvita.com/xiaomi-youpin-nanoleaf-green-noble-smart-plate-4pk-updated-version.html
High cost performance smartphones:
lenovo k5 pro global
The Xiaomi Yeelight YLXD09YL LED ceiling light features modern and simple style, not only an illumination instrument but a perfect ornament for your house. Using high-performance LED chip, the light is safe and energy-saving to use. The white light will create a warm and comfortable atmosphere for you.
Product Features:
● Simple Shape
Unique simple design, not only lighting but also decorating your house.
● PMMA Material
Using PMMA lampshade material makes uniform light, translucent strong.
● Built-in Dual Sensor
Built-in infrared human body sensor, sensitive to your trace. When people entering the human sensing range, the light automatically turns on, when people leave after 60s the light automatically turns off. With a light sensor, the light is automatically turned off during the daytime, saving your electricity.
● Anti-mosquito Design
Fully sealed anti-mosquito stickers design, effectively solving the problem of flying insects in the lampshade.
● High Bright
Provides 670lm brightness and 5700K glow, illuminating your night life.
● Highly Restored Color
Color rendering index Ra up to 95, highly restored color.
● Less Energy Consumption
Energy saving and environmental protection without flash, intimate power protection case to prevent danger caused by accidental contact.
As an ideal choice to illuminate walkways and patios, the smart ceiling light is perfect to home use. It is 25cm in diameter and has an exquisite design that is also insert-proof. With built-in dual sensors and high color rendering, it will illuminate your home automatically to welcome you when you come back home: https://gearvita.com/xiaomi-yeelight-ylxd09yl-smart-induction-led-ceiling-light.html
You may also like:
mijia mjctd02yl
aqara hub
The Xiaomi VIOMI ultrasonic humidifier quietly releases a soothing fragrant mist, making your home smell better with advanced ultrasonic vaporizing diffusion technology. The humidifier function adds moisture to the air to help you sleep better, cough less and alleviate dry sinuses. Let it accompany you to read, do yoga, or sleep.
Product Features:
● Portable body, easy to move from room to room.
● The mist formed by essential oils and water mist can release the fragrance of essential oils in the air, which can nourish hydration,
purify the air, and relieve stress.
● Adopts a surrounding three-dimensional air duct design to ensure smooth airflow and fine mist, effectively forming a fogging effect of ring atomization.
● The atomized sheet produces a uniform mist at a vibration frequency of 1.7 million times per second, avoiding the condensation of water droplets, and does not wet the surrounding objects to moisturize the environment.
● Comes in a mute design, the sound is less than 30db, allows you to sleep comfortably.
● Embedded with a timer setting and 4 colors LED night light, you can set the appropriate time, warm night light function to protect your eyes, also set your favorite color or select color rotate option.
● Contains 200ml water tank, after adding essential oil, it can continue to fog for 6 hours. Choose intermittent fog mode, can continue to fog for 12 hours.
● Embedded with an automatic shut off safety system when it is dumping.
● The spray duration can be set as required, and there are three timing modes: lh, 3h and 5h.
● 4 colors LED night light: purple, blue, yellow, and crescent white, warm night light function to protect your eyes, you can set your favorite color or select color rotate option.
This humidifier can not only fill your space with a lovely fragrance to lift the mood and relieve stress from stressful and tired day, but also can illuminate the night and create a warm atmosphere: https://gearvita.com/xiaomi-viomi-aromatherapy-diffuser-ultrasonic-humidifier.html
Products worth browsing:
mi mix 2s 128
q50 smartwatch
Create a warm ambient in your room and wirelessly recharge your Qi-enabled smartphone using this Baseus mushroom wireless charger that with a mini bedside night light. This Baseus wireless charging pad is designed with smart technology that automatically recognizes charging protocols, and features 10W of output power to provide fast charging. It supports recharge smartphone even with a protective case, thanks to its charging distance of up to 6mm. With the ability of automatically detecting foreign objects, it avoids potential safety hazards.
Product Features:
● Handy 2-in-1 design, Qi wireless charger with a mushroom night lamp.
● Elegant body can blend in any environment, is a modern yet functional decoration for your home or office.
● Compact and lightweight, only 105g weight.
● Intelligent fixed frequency technology, automatic identification quick charge.
● Maximum output power of 10W provides fast charging for smartphone.
● Adjust the light brightness by holding the metallic button, which also has a mushroom design.
● Designed with silicone pads on the bottom to prevent slipping.
● Intelligent identification of metal objects to avoid otential safety hazards.
● Rufuse to run naked, support charging with case.
This small gadget is super convenient, not only reflected in providing wireless fast charging for your smartphone, but also when you get up at midnight, a warm and sweet lifestarts at a slight touch: https://gearvita.com/baseus-mushroom-qi-wireless-charger-with-bedside-night-light.html
Hot sale product on our website:
mi band 3 global
xiaomi mi 8 lite global version
Are you looking for a titanic gamepad capable of supporting wireless connection with a variety of smart devices? Flydigi X8 Pro wireless gamepad is a more than interesting alternative for those looking to play on smartphones with the game comfort offered by a gamepad with 2 joysticks, button mapping, crosshead and triggers.
Making use of the integrated Bluetooth 4.0 connection, you can pair your Android or iOS phone to play the catalog of the device available in the store, placing the mobile in the removable and folding support that includes the package to turn it into a portable console. By including a 2.4G USB Dongle receiver, the remote also supports wireless connection to Windows computers, tablets, smart TV and Android TV.
From mobile to tablet, from tablet to computer, so comfortable and practical. You can play on the bus with your mobile, play big on a smart TV or play the PC catalog with a single command. The correctly optimized 300mAh battery offers up to 80 hours of play with a full charge. As professional competition controller, less than 6ms delay, the Flydigi X8 Pro features high sensitivity and accuracy in overall performance.
Product Features:
● Wireless Transmission
Compatible with Android 4.4 or above devices and Window 7 or above PC, connected by Bluetooth 4.0 or 2.4GHz wireless USB receiver dongle.
● Motion Sensing Aiming
Built-in 6-axis gyroscope acceleration chip provides great motion sensing control and enables air mouse mode.
● Flymapping Button Mapping Technology
Flymapping function is developed based on button mapping technology, enables you drag button to adjust button position, makes the experience more smooth and convenient. Describe 120 points of high speed mapping per second, quick response to small changes of stick angle.
● Flydigi Utool
No need root for Android phone, with the included Flydigi Utool, connecting the power for 10 seconds to activate button mapping. Then you can play any mobile games with controllers.
● More Buttons
Has 3 function buttons more than other normal controllers, left and right triggers are used with mouse microswitch, enable you get higher shooting speed in FPS games.
● Dual-vibration Motors
The left and right grips adopt built-in asymmetric motors and using Japanese ALPS rocker, more realistic vibration feedback can be easily and fully experienced in racing, sports, shooting and other games.
● Battery Power
Equipped with Nordic 32bit Bluetooth chip, special for esports keyboard and mouse. Switch seamlessly between Bluetooth 4.0 low power mode and 2.4G wireless mode, the delay is less than 6ms and the built-in 300mAh polymer lithium battery lasts for 80 hours in normal condition.
● Ergonomic Design
Comfortable and exquisite stripe texture on the surface, anti-sweat, anti-slide, with better hand feel.
This Flydigi X8 Pro Bluetooth wireless joystick gamepad is designed to bring you brand new gaming experience. The detachable bracket makes installation more easier and reduce the head weight which make it comfortable to play games and it is widely compatible with 3.5~6.8 inch Android smartphones: https://gearvita.com/xiaomi-flydigi-black-warrior-x8-pro-game-controller.html
Other good products worth buying:
lenovo k5 pro
xiaomi mini flashlight
Imalent R70C flashlight with six output levels and hide strobe, ensures long runtime with low output or high output when needed, so you can plan and prepare for your night time outdoor journeys and activities well in advance. It is fitted with one latest upgraded Cree XHP70 2nd generation LED, delivering 6500 lumens of output and a beam distance of 1270 meters. Considering the user interface, the R70C is fitted with user-friendly side pressure switch for stepped light regulation to control the runtime and output selection. This versatile light caters for multiple output level demands.
Output and Runtime:
Turbo: 6500-4000 lumens ( 8+96min )
High: 4000 lumens ( 110min )
Middle High: 1800 lumens ( 3h 30min )
Middle: 900 lumens ( 7h 6min )
Middle Low: 500 lumens ( 18h 18min )
Low: 200 lumens ( 80h )
Product Features:
● Utilizes one American Cree XHP70 2nd generation LED, with a lifespan of up to 50000 hours and a maximum output of 6500 lumens.
● Ultra-long shot beam sistance, max beam distance goes 1270 meters.
● Powered by 4 × 18650 Li-ion rechargeable batteries, with USB magnetically charging.
● Built-in self-testing intelligent charging circuit which is convenient, fast and safe.
● Six power levels which can be changed quickly with instant turbo available.
● Battery capacity indicators show the battery level at any time.
● High efficiency constant current circuit maintains consistent brightness.
● Built-in thermal control module automatically adjusts the brightness output to keep the unit from overheating.
● Combination of toughened ultra-clear mineral anti-reflective coated glass.
● Aluminium SMO reflector.
● Aerospace-grade aluminium alloy body, wear-resistant type III hard-anodized surface treatment.
● Waterproof to IPX-8 standard.
Imalent R70C is a smart aid for night outdoor searching and rescuing and industrial tasks, as well as a backup lighting tool for your self-driving journeys, it will illuminate the road and guarantee your safety outdoors: https://gearvita.com/imalent-r70c-led-flashlight-cree-xhp70-6500-lumens.html
Recommended products:
xiaomi flashlight
xiaomi ip camera
Based on Cree XP-L HI LED, the exquisite compact Imalent HR20 headlamp is capable of bursting out 1000lm maximum output and 225m maximum beam distance. With infinite brightness adjustment and rotatory switch, you can adjust and read your desired brightness from 1lm to 1000lm easily, practicality enhances outdoor applications. Powered by 1pcs of 18650 Li-ion rechargeable battery or 2pcs CR123 Lithium batteries which will provide the runtime of 360 hours to the headlight. Besides, it has a micro USB charging port that is convenient for you to charge anywhere. Utilizes patented reflector vacuum coating cup with floodlight and spotlight, can be called as "outdoor lighting artifact". Featuring multipurpose and fine workmanship, the HR20 is the best gear for EDC and outdoor adventures.
Product Features:
● Weights merely 46g, lightweight and compact, easy to carry.
● Utilizes Cree XP-L HI LED in conjunction with copper MCPCB, maximum output up to 1000 lumens.
● Powered by 1 × 18650 Li-ion rechargeable battery or 2 × CR123 Li-ion batteries, runtime up to 360 hours.
● Rotatable brightness adjustment to any desired brightness, from 1 to 1000 lumens, coping with multiple unexpected accidents.
● Built-in micro USB charging port, the battery can be re-charged at any time.
● Innovative switch design for easy operation.
● High efficiency constant power circuit will maintains constant brightness.
● Anti-reverse battery protection.
● Combination of toughened ultra-clear mineral and anti-reflective coating glass.
● Advanced temperature control module prevents over-heat.
● Aerospace grade aluminum alloy construction with wear resistant Type III hard-anodized surface treatment.
● Comfortable, breathable and elastic material in the making of high quality nylon headband.
● IPX-8 standard waterproof (2m) for severe weather.
● 1.5m impact resistant.
● Tail stand function.
The HR20 is a versatile USB rechargeable headlamp with extensive runtime, extremely light weight and impressive output, headlamp and flashlight dual use, it is a necessary lighting tool for inspection equipment and outdoor reading: https://gearvita.com/imalent-hr20-led-headlamp-cree-xp-l-1000-lumens.html
xiaomi mi 8 lite
xiaomi airdots pro
Imalent BG10 bicycle light can solve almost any problems for todays riders. Its OLED display clearly shows present output levels such as brightness, capacity, and runtime. Thanks to the premium reflector design, the BG10 has a far-wider beam than other models.
Output and Runtime:
Turbo: 2300 lumens ( 4+55min )
High: 1200 lumens ( 8+69min )
Mid: 500 lumens ( 1h 33min )
Low: 250 lumens ( 2h 16min )
Product Features:
● Utilizes the latest Cree XHP50 LEDS with a lifespan of up to 50000 hours and a maximum output of 2300 lumens.
● The multi-functional OLED display can show various parameters and settings.
● Built-in 2000mAh 26350 Li-ion rechargeable battery.
● High efficiency constant current circuit will maintain constant brightness.
● Built-in thermal control module will automatically adjust the brightness to ensure comfort.
● Ultra-clear tempered glass lens, coated with toughed ultra-clear minerals and anti-reflective coating.
● Aluminium OP reflector.
● Aerospace-grade aluminium alloy body, wear-resistant type ard-anodized surface treatment.
● IPX-8 standard waterproof (2 metres submersible).
● Easy and safe to use when braking.
● Compatible with all bikes including road bikes.
The bike light is rechargeable via an included charging cable, featuring a USB one end and a magnetic disc to attach to it. This innovative method ensures quick and convenient charging whilst removing the requirment for a micro USB port which could compromise the waterproof rating and durability of the light: https://gearvita.com/imalent-bg10-led-bicycle-light-cree-xhp50-2300-lumen.html
High cost-effective products:
xiaomi amazfit verge smartwatch
meizu pop true wireless bluetooth earphones
This Xiaomi Philips Bluetooth induction night light adopts photosensitive sensing technology as well as human body infrared sensing technology. It has a super-angle sensing range of 120°, and the sensing distance is 5-7 meters. It can determine whether to illuminate by sensing the brightness of the surrounding environment, automatically turned on under dim light conditions and automatically turned off under good light conditions. 10 months long endurance, the real choice of saving energy.
It supports smart linkage, after all the Bluetooth night lights are connected at home, when the first night light on the bed senses people, the other connected night lights will be linked in sequence, and all light up automatically.
The Mijia Philips Bluetooth night light works with other Bluetooth gateway-enabled devices, such as Mijia bedside lamp, XiaoAi smart alarm clock, Mijia ceiling lamp, Mijia smart cameras, etc. So when the night light is on, you can also control other smart devices to turn on at the same time.
Preset 4 scenes to customize your home life, you can customize the duration of lighting and adjust the brightness steplessly through the Mijia APP smart setting.
The soft and comfortable front light source and the soothing back light source are hidden in the lamp housing. The light passes through a thousand turns and avoids direct light from both eyes, giving you a better visual experience.
Built-in Fresnel lens for improved sensor performance, the PE material with high light transmission and infrared ray is used to improve the sensing performance. Adopts hidden light source body, the back surface is treated with matte sandblasting, pure white appearance, create the artwork in the night lights: https://gearvita.com/xiaomi-philips-bluetooth-night-light-led-induction.html
lenovo z5 pro global version
