This Lilliput-001 1080P IP camera features HD 1080P display image and recording resolution. It is equipped with 2pcs array IR LED and IR-CUT double filter, provides with good day and night vision. It is also with functions of motion detection, two-way audio monitoring, and phone APP control, etc., can remotely viewing by PC client, phone APP, and mobile devices anywhere at any time.
Product Features:
● 1080P full HD videos, 2MP photos, never miss any detail.
● No dead zone with PTZ gimbal, has a 355-degree ultra wide angle of view.
● 15m night vision with two high-quality IR-cut sensors for 24h surveillance.
● Built-in microphone for voice call.
● Remote access of up to 6 devices supported simultaneously.
● Motion detection within 10m and real-time alarm to protect your property effectively.
● Insert a 64GB microSD card for 12 days recording, neither need to delete the old videos nor format the microSD card.
● IP66 waterproof, suitable for more indoors and outdoors environments.
● Audio identification technology can identify baby crying and send "Baby Cry" alert message.
● Support real-time monitoring of multiple terminals such as smartphones, tablets, notebooks and desktops at the same time.
The Lilliput-001 IP camera is designed for home safety and security, the compact design makes it very easy and convenient to install anywhere inside your home. With this surveillance camera, you won't have to be anxious about going outside. You are able to check the house through the mobile phone, which is easy and convenient: https://gearvita.com/lilliput-001-1080p-wifi-security-ip-camera-2mp.html
The Xiaomi Yeelight Pro smart LED desk lamp has an intelligent eyes protection system thanks to the SunLike technology. It adopts simple and elegant design, with a circular weight base, a foldable arm and a mirror-like LED light that is adjustable according to your requirements. The articulated arm is adjustable in height and the LED light offers up to 650 lumens with a consumption of 15W, the color temperature remains fixed at 4000K. The LED lighting filters out blue light, offers a light very similar to natural illumination, to protect your eyes and avoid eye fatigue. With WiFi connection, it is compatible with the Yeelight and Mi Home APP.
Product Features:
● A uniquely-crafted look with durable build that fits simply everywhere.
● No buttons design, adjust the color temperature and brightness with a simple touch.
● Energy-efficient LED light emits non-ghosting and non-flickering lighting, no blue light hazard to protect eyes.
● The height can be adjusted for better visibility.
● APP intelligent control to help children use their eyes scientifically.
● Set "time management" and start "children's eye protection mode" to prevent children from using excessive eyes.
The Xiaomi Yeelight Pro YLTD04YL is an exquisite accessory and stylish lamp that takes care of your vision, modern design and a wide range of features will make it a central part of the working space: https://gearvita.com/xiaomi-yeelight-pro-yltd04yl-smart-eye-care-led-desk-lamp.html
Have you ever used a light strip? Which could decorate your home to enhance the sense of space. The Xiaomi Yeelight light strip extended cable is used to extend the length of the light strip, which can let you decorate your home more freely without worrying about the length of the light strip.
Product Features:
● Supports stitching, free and flexible, can cover a longer surface of objects.
● With a flexible ribbon structure that is easily shaped according to the object.
● Superb LED, low carbon, no radiation, no flicker, and no pollution to human and environment.
● Customized special back adhesive and release paper with easy tearing for simple and convenient installation.
● The length of cable is 1m.
● Only for the use of extending YLDD04YL version.
The high-quality light provided by the light strip extended cable can effectively switch the home lighting tone, from refreshing blue light to warm yellow light, creating a different atmosphere for the home environment. It can be placed in many corners of the home, achieves freely switch of a variety of preset scenes. DIY colorful home atmosphere is just missing your imagination: https://gearvita.com/xiaomi-yeelight-ylot01yl-light-strip-extended-cable.html
Xiaomi Yeelight remote control is a mobile alternative to wall switch and APP. With Yeelight remote control, you can turn on and off, adjusting lighting comes with ease, also try out cozy moonlight mode. It brings you a brand new experience of lighting, lets you enjoy the real convenience.
Product Features:
● Adjusting brightness and color temperature at a touch of the fingertip.
● Small body with ABS material, easy to carry and control.
● Minimalist and simple design, easy to operate.
● More flexible than the wall switch and more convenient than mobile APP control.
● Compatible with Yeelight LED ceiling light via Bluetooth.
● CR2032 battery power supply, lower power consumption, longer stand-by.
● Equipped with push back cover, changing battery becomes so easy.
If you have a smart home, this remote will be a great complement to your Yeelight light, the ability to turn off the light in your interior from the comfort of your bed is simply priceless: https://gearvita.com/xiaomi-yeelight-remote-control-for-smart-led-ceiling-light-lamp.html
Xiaomi Yeelight YlXD04Yl LED ceiling light mini uses classic bright white light with 5700K color temperature, matching with the side light emitting structure, the light is gentle and even. Adopts the quality PMMA material, good transmittance, brightness up to 650lm, even and bright light. Anti-dust and anti-bug, no visible flash, simple and rustic design for any home style.
Product Features:
● With a side-emitting stucture, the light is soft and even.
● Using SPCC base plate, PMMA lampshade material makes uniform light, translucent strong.
● Super bright LED beads, energy saving and environment friendly.
● Multi-layer sealed design to prevent mosquitoes from entering.
● Suitable for 10 square meter room.
Placed in a 10-12 squara meter corridor, where is just right for the light, so that every corner is warm and comfortable: https://gearvita.com/xiaomi-yeelight-ylxd04yl-led-ceiling-light-10w-mini-simple-round.html
Xiaomi Yeelight LED ceiling light 480 is designed in a circular shape and white colour, allows a flexible adjustment of brightness and colour temperature. In addition, a moonlight mode which gives the look of the moon when turned on is surprisingly comfortable. Being a smart light, it can be controlled by smartphones through WiFi or Bluetooth. It also comes with a Bluetooth remote control that allows you to remotely switch on and off your light without necessarily being in the same room.
Product Features:
● Simple round design, not only lighting but also decorating the house.
● Adjustable color temperature between 2700K and 6000K.
● Adjustable brightness and luminous flux is up to 2200lm.
● Unique moonlight mode with ultralow brightness of only 1.5lm.
● High color rendering index (CRI) up to Ra95.
● Energy saving and environmental protection without flash.
● IP50 dust-proof and insect prevention.
● TV backlight technology and high-density lamp beads arrangement make softer light
● Unique coupler quick-installation module, easy to install and remove.
● Remote control via MIJIA APP or Yeelight APP.
Most of the ceiling lamps on the market are illuminated downwards, the ground is the brightest, followed by the walls, and the ceiling is the last. However, the dark ceiling will give us a feeling of depression. This Yeelight LED ceiling light adds ambient light function, both the main light and the ambient light can be used together to reinforce the light, or it can be used alone as an ambient background light: https://gearvita.com/xiaomi-yeelight-ylxd05yl-led-ceiling-light-32w-480-simple-round.html
This Xiaomi Yeelight Bluetooth dimmer switch is for intelligent lighting to turn on/off, dimmable and changing lighting modes and color temperature after connecting electric appliances remotely. Compact and mini design free up more spaces for you.
Product Features:
● 3M glue on the back, no need to install wiring.
● Bluetooth connetced function to turn on/off, adjust brightness and change lighting modes after matching.
● Press and rotate the knob for changing 3 levels color temperature - warm white: 2700K, neutral: 5000K, white: 6500K.
● Equipped with operating indicator lamp, makes you know working progress.
● Superb ABS + PC shell, safe and long service life.
● Built-in button battery, battery life up to 2 years for 50 times per day.
The Yeelight smart dimmer switch uses Bluetooth remote control technology, does not directly cut off the power supply, enabling the smart light to continue online, solves the problem that the wall switch cannot be intelligently controlled after the power is turned off: https://gearvita.com/xiaomi-yeelight-ylkg08yl-bluetooth-smart-dimmer-switch.html
With simple and exquisite design, the Xiaomi COOWOO U1 LED desk lamp is built in 4000mAh battery, combined with 4000K color temperature LED chip and brightness memory function, it is capable of protecting your eyes and minimizing glare and eyestrain. Doubles as a power bank with two adaptive USB ports.
Product Features:
● 4000K soft neutral light for eye protection, no UV, blue light and other hazards.
● Built-in 4000mah Li-polymer battery, provides super-bright illumination for over 7 hours and standby time of about 100 days.
● Doubles as a power bank with two adaptive USB output ports to charge two devices simultaneously.
● Memory function automatically resumes the brightness setting of the previous use once restart.
● Touch or long-touch the button to achieve switch or stepless dimming.
● Color rendering index of up to 83, presents natural and vivid color.
● Constructed from quality aluminum alloy, PC and silicone, effectively solves the heat dissipation issue, protects the LED chip and increases the LED lifespan.
● Minimalist design, the curvy arm can be bent freely, bright and no dead ends.
If you prefer minimalism, then U1 is definitely your choice! The adaptive USB ports on the base solve the trouble of limited sockets, you can charge your devices anywhere and anytime: https://gearvita.com/xiaomi-coowoo-u1-intelligent-led-desk-lamp.html
OPPLE blowing control candle lamp is shaped like a wineglass and made of ABS plastic environment frirndly material. The lamp features 3 levels dimming with memory, can deliver a smooth, steady and comfortable natural light even on the lowest brightness setting. It is built-in rechargeable lithium battery and adopts wireless design, portable and convenient for use. Thanks to the blowing sensor, you can light up or extinguish the candle light by blowing toward it.
Product Features:
● Creative blowing control induction, blow once to light on, blow again to light off.
● Three levels brightness, 3000K gentle natural white light.
● Small and exquisite, one han d can hold.
● Lithium battery with USB charging, environmentally friendly and durable.
● Power display, the remaining power is clear at a glance.
Put it on your table, creates a little more light at home, the life is a little more romantic. Using coupon code "HUAWEI10" to obtain 10% discount on this candle light: https://gearvita.com/huawei-opple-candle-night-lamp.html
The Xiaomi video doorbell set brings both convenience and security to your home by streaming a live view of the doorstep to your smartphone, whether you are on the other side of the door or the other side of the world. It has a motion sensing and night vision, when someone approaches 3 meters from the door of the house, it will automatically take video and send a notification to the phone immediately.
Product Features:
● Accurate AI face identification
● PIR motion detection and SMS video message notification
● Infrared night vision
● Free cloud video storage
● 105-degree lens angle, 720P HD resolution
● Voice-changing intercom
● Real-time remote video conversation
● Low energy consumption FastWake technology, 6 months standby time
● Doorbell can connect with 4 receivers simultaneously
● Transmission distance is more than 50 meters
● Bayer fire protection material, V1 level fireproof receiver
The smart doorbell combines the functions of doorbell and security monitoring into one, not only realizes all functions of an ordinary doorbell, but also plays a role of security monitoring: https://gearvita.com/xiaomi-ai-face-identification-720p-ir-night-vision-video-doorbell-set.html
The Xiaomi Xiaobai smart 1080P IP camera is suitable for indoor environment with nursing and security needs. It provides safe protection for family members and property security solutions for indoor places through complete functions, convenient installation and high cost performance.
Product Features:
● Mijia APP supports real-time remote viewing, two-way voice calls, and automatic alarm when an abnormal situation is detected.
● AI humanoid detection is optimized for the target, effectively filters invalid alarm and makes the alarm more accurate.
● Dual motor drive, 360° horizontal rotation adjusts the angle of view, high-definition picture quality allows the picture to retain more details.
● Noise reduction infrared night vision can present a clear picture even at night.
● Adopts H.265 video coding technology, the viewing is smoother and the video takes up less space.
● Automatic loop recording, multiple storage methods - cloud backup, micro SD card, and NAS storage.
● For historical video recording stored in micro SD card, supports 1x/4x/6x double speed playback, and can be quickly searched.
● Mix with other Mijia smart products with Mijia APP to achieve smart linkage, better protect the privacy of individuals and family.
● Support multi-person terminal remote viewing to share real-time pictures to family and friends at the same time.
● Support flip install, provides a wider field of vision from a height.
With the Xiaomi Mijia Xiaobai smart 1080P WiFi IP camera pan-tilt version, you can sleep soundly: https://gearvita.com/xiaomi-mijia-xiaobai-smart-ip-camera-1080p-pan-tilt-version.html
