File a PayPal claim and they will get it resolved quickly.
Just send BanL a PM. He is very responsive. Uea holiday times are usually the busiest.
Yeah, you can send me your question via PM.
I am sorry a little delayed in recent. (Unlucky the computer ’s SSD sudden down )
Ban
Two type of new LED is arrived to KD.
Lumileds LUXEON V2 W (310 Lumens) Y (3V) White 6500K LED Emitter
http://kaidomain.com/Lumileds-LUXEON-V2-White-6500K-LED-Emitter
Lumileds LUXEON V2 X (320 Lumens) Y (3V) White 5700K LED Emitter
http://kaidomain.com/Lumileds-LUXEON-V2-White-5700K-LED-Emitter
Lumileds LUXEON V W (600 Lumens) F (2.65V) White 6500K LED Emitter
http://kaidomain.com/Lumileds-LUXEON-V-White-6500K-LED-Emitter
Since the Luxeon V needs to have 4040 type LED PCB, it will be available later.
Enjoy
Which SSD do you have?
I thought they were supposed to be very reliable.
I think this is not related to the SSD problem.
I am using the Samsung once. It is really good and reliable.
The computer is used for around 4 years. It is time to do the backup and re-arrange the files.
Too many dummy files
Hi ,BanL do you have Ultrafire F13 reflector ? I search your KD but not sure which one fit …THK
Hi Ban,
I see you have added the 2700K 95CRI SST-20
Unfortunately the JC1 tint bin is above the Black Body Line
Especially for high CRI leds the actual tint is really important for many of us, and most will like a tint under the BBL.
I ordered one to check it out anyway.
Just make it a one mode and drive it as hard as necessary to be right on the BBL. It probably shifts dramatically like all the rest
Wow! Do you like to make mountains out of molehills? High CRI emitters usually have little tint deviation, so no big deal.
Courtesy of maukka’s posts:
I don’t think it’s so simple to generalize every high CRI LED in respect to shift at different outputs.
Hi Ban,
I see you have added the 2700K 95CRI SST-20 :+1:
Hello Ban,
Probably a JD3 could be a bit better, but for me, JC1 is also very good, and I will definitely try it.
Could you please source GD2 tint as well?
JC1 tint bin is no good for me. I wish it was below the BBL. JD1 and JD4 would be even better since I use my WW lights at very low output mode most of the time where the DUV is much higher (greener/yellow). With JD1 and JD4, lower output modes should be just below the BBL.
djozz:Hi Ban,
I ordered one to check it out anyway.Hello Ban,
Sure.
I am trying to source the SST LED under BBL every time.
But it does not have so much choice for me to pick.
I will put the first priority on that.
Some Luminus SST-20 LED in promotion before the Chinese New Year holiday.
LUMINUS SST-20 L3 BA WHITE 6500K LED EMITTER
US$1.98
LUMINUS SST-20 J4 FB4 NEUTRAL WHITE 4000K LED EMITTER
US$1.98
LUMINUS SST-20 J3 HD2 WARM WHITE 3000K LED EMITTER
US$1.98
Enjoy.
BanL, if we order 1 triple emitter, it’s $5.78. Is that for 3 LED’s on the triple board? And I assume the triple board is compatible with carclo 10507 optics?
Hi
Yes, it has 3 x SST-20 LEDs.
Our triple pcb will include 20mm triple lens.
I am not sure the triple board is compatible with carclo 10507 optics or not.
Thank you
Ban
The triple with optic that I bought a year ago at KD was not compatible with Carclo optics.
Was the optic similar size as the carclo for fitment?
djozz:The triple with optic that I bought a year ago at KD was not compatible with Carclo optics.
The optic is similar but all dimensions (optic height, placement of legs, leg thickness, I think even led postion, is a bit different from the Carclo standard.
