Amazon Deal Alerts & Discussion Thread
decypher, did you get much heat off these on your discharge test @ 500mAh?
I only tried one cell and kinda got scared to use any more.
There was some heat — but it wasnt to a concerning level. No worse than my NIMH recharges. Was yours really warm?
I don’t expect a 500mah discharge for my application — but expect there are some who will.
I was holding it in my hand after the current draw test in my light. Its cold here so my hands are NOT 98.6*F… Just didn’t feel like my hands were helping it to cool at all. After about 30+ seconds, and no cooling at all, I put it into a metal dish.
$15 - https://www.vipon.com/product/5833686-POCKETMAN-Super-Bright-XHP70-3000-Lumens-Tactical-Flashlight
Thoughts on this one? Looks like a crappy 3 mode zoomy with a XHP70 Emitter, usb charging, battery indicator and takes 2x18650 or 2x26650.
I tried the code just to see if it worked and it didn’t for me. I’ve had that happen every now and then on their deals, most do work.
(15.00 light)
Interestingly enough… I noticed the Wuben e05 had a 12.00 coupon on amazon. Apparently I also had an old Vipon coupon for that item in my cart (I must have added it and never completed the checkout). I went to checkout now and it applied both coupons. It was like 4.00 out the door. Kind of hard to say no at that price.
I dont even see a listing with a 12.00 coupon
Wow…you stole it. Good deal !!
https://www.amazon.com/gp/product/B07K23G51F/
Above is what I ordered with the 12.00 coupon. Not sure if its still there.
Yep… you flat out stole that one!! … Congrats…. :+1:
Yeh, coupon still showing…now if I only had a code…. :weary:
Me too, just cleaned out my Saved for Later items yesterday. Had one in there too.
Still not bad @ 28 its a great light , one of my favorites in the AA size. I did get one a while back on the bay for 24 shipped but he’s got no more. But its still not 4.00 .
Yes, it’s still there. I apparently had a 50% off coupon in there somehow and the $12 dollar coupon stacked on top of that. So I grabbed it at $8. I already have one I put a Luxeon emitter in. I guess I will do the same with this one and give it away to somebody. Bought a returned Zebralight SC600 MKIII as well. Got both after discounts for $43 and some change. I guess it was just my day for a change. I hit Place Order Now before they changed their minds. :smiley:
Some nice features like the battery indicator and mag tail cap, but torn as that is still $10 over other good AA/14500 lights.
I think $40 is too pricey for the light. While it is a step above most AA lights in brightness and build quality alone. I still wouldn’t buy a $40 AA light. Well unless it was some kind of alternative material like copper or something. While the emitter is just fine if you like cold white I replaced it with a 5000K one. Which is super easy. Bezel isn’t glued and a 16mm board with your choice of emitter slips right in. Though the copper board from mountain is a bit thick but, a little sanding had it fitting like a glove in just a few minutes. Fair price at $30 maybe, a good deal at $20 but I couldn’t pass up another for $8.
No I couldn’t either too bad you could only get one .
Me three… :frowning: … I tried a code I guess I had already used… no joy. :frowning: . :frowning:
now the deal is even gone on Amazon.
Looks like its a $10 off deal now.
I grabbed two of these lights when Vipon had a $26 off coupon. For $16 bucks I couldn’t pass it up. It really is a nice light. The only thing I dislike is the long press to turn it off. Other than that it’s really nice.
