Luminus SST-20-W 4000 K CRI95 color and output test
217 posts / 0 new
maukka
maukka's picture
Last seen: 1 day 7 hours ago
Shaving the dome off with a razor (not a very clean job), the tint got noticeably better.
hodor
hodor's picture
Last seen: 35 min 11 sec ago
Any beamshots? I’m tempted to do some slicing and dicing.
Also is there somewhere I can read up on how to interpret these charts? The only things I know are the numbers in the top right Blushing
Barkuti
Barkuti's picture
Last seen: 2 hours 34 min ago
Could you please append here a non-sacrificial output test of the razor-dedomed emitter, maukka? It would provide nice information regarding the potential output loss versus domed emitter.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
contactcr
Last seen: 1 hour 17 min ago
I second this, if it’s not too much effort. My triple had a better tint after shaving but it took a big output loss. That’s the thing with this LED, it’s throwy without dedoming so shaving the LED just to fix the tint is not a great trade off.
Bob_McBob
Last seen: 5 hours 5 min ago
I lose about 30% output slicing the dome at the bond wire height, with no increase in throw but a noticeably rosier tint. Increasing the intensity requires trimming the dome around the die and carefully slicing as close as possible to the phosphor while avoiding the bond wires. The stock 3500K SST-20s I’m using get about 600m throw in a D1S/GT mini, which I was able to increase to 685m with careful trimming. It’s not pretty, but it works, and it could probably be increased further. This is the best option for a high CRI thrower right now.
hodor
hodor's picture
30%? Ouch. I guess it will be better using a minus green filter to correct tint as there will be less risk? Do they decrease throw/intensity at all?
What is it about slicing that makes the tint rosier?
Do different depths of slicing have different effects, i.e. do deep slices, as close to the phosphor as possible, result in the rosiest tint, with the best increase in throw but at the expense of the biggest sacrifice in output and vice versa?
Agro
Agro's picture
Last seen: 1 hour 45 min ago
How about Luxeon Z ES? It’s just CRI90 but maybe it will throw significantly better?
ZED
ZED's picture
Last seen: 8 months 1 week ago
I just shaved 12 SST-20 domes in 3 D4’s. Been reading how they got rosier, had to find out. Started with the one I cared the least about just to experiment and ended up slicing them all. I thought my 4000K version was a wee bit green and my 3000K a bit yellow. Now I have white and rosy. The beam profile is maybe a little more wonky but only if you are looking for it on a white wall. I think these are pretty sweet little LEDs for what they are.
-Zach
hodor
hodor's picture
Any comparison beam shots or tips on how to slice?
ZED
ZED's picture
Yeah when I get off work. Beam shots suck on my phone, but I had a 3000K 4000K mixed D4 and when I shaved them it made my straight 3000K D4 look pee yellow when in reality it’s not. Then I did the 3000K D4 and it’s a much nicer rosy color than yellow now. Took any hint of green at lower levels out of my 4000KD4. No I don’t have too many D4’s.
-Zach
ZED
ZED's picture
Hodor, my phone doesn’t really show the difference in tint well, but take more word that it improves. I didn’t get too excited with the preciseness of the slicing. Just got pretty close to the phosphor opposite the bond wires and when I got to the bond wires just angled up. So a side view looked like a little ramp (half) half pipe. Didn’t seem to be too crucial to get it as close to phosphor as possible.
-Zach
contactcr
I can attest to the tint improving but the output does go down and since the beam narrows even more it makes the beam pattern look different. You see a starburst type pattern (at least in a carclo triple) more clearly at the edge of the hot spot.
I honestly wouldn’t recommend it unless the green makes it unusable to you or you dont mind replacing the LEDs if you dont like it.
ZED
ZED's picture
Good input contactcr. That is all true, but for me, preferable. I just went out in the snow to test against my 219C D4. I quite like the extra throw. A little bit more like a reflector light. I don’t have a lumen tube but I’d say the loss is not nearly as perceptable as the tighter beam profile. So I’m a vote for just do it. Depends what you like hodor.
-Zach
Bob_McBob
I took some measurements of my dedomed SST-20 GT mini. I’ll add data for the stock LED when I have a chance to install one in a light. It looks pretty nice on turbo, though it’s really too warm for my tastes. But, it’s a rosy high CRI laser thrower, so I suppose I can suffer through it Big Smile
Low
CCT = 3237K (Duv 0.0017)
Color Rendering Index (Ra) = 98.1 [ R9 = 93.0 ]
Turbo
CCT = 3349K (Duv -0.0023)
Color Rendering Index (Ra) = 93.5 [ R9 = 71.8 ]
contactcr
Nice, what meter do you use?
Bob_McBob
That’s measured using an X-Rite i1Studio and spotread.
maukka
maukka's picture
TA sent me some more SST-20s. Tint bins FA3 and FD2. The FA3 turned out to be pretty good at the BBL already at 1A. Maybe he can guide us on where to buy them?
djozz
djozz's picture
Last seen: 30 min 30 sec ago
Thumbs Up it looks like progress in getting what we like. Thanks TA and maukka for the effort.
Agro
Agro's picture
Indeed. I so wish it will be generally available in the near future….It negates the biggest issue with this otherwise-great LED.
Texas_Ace
Texas_Ace's picture
Last seen: 7 hours 43 min ago
Great, thanks for the test results maukka! Glad these are not flat out lies like the “FA1” that turned out to be FB4.
Djozz your samples should not be far behind (sent samples to both of you since it was only a few extra bucks and I knew you would both be interested).
Far as ordering them, sadly that is not possible for us normal people, it was from some wholesale distributor in china. I have spent the last few months talking to luminus and everyone else I can find to track these down. Ended up that these popped up at some distributor Mateminco knew and they snatched them up.
That said I am trying to get my hands on some of them and if that is possible I might run a group buy if there are enough to go around. There are only around 800 FA3 in the world that I could find but there are more FD2. Not sure how many I could talk my way into as they don’t even have enough for the MT18 they are planning to put them into.
I will update you once I know more about availability.
maukka
maukka's picture
Texas_Ace wrote:
Great, thanks for the test results maukka! Glad these are flat out lies like the “FA1” that turned out to be FB4.
I suppose that’s supposed to be aren’t, since to me these seem to land where they should? Smile
Texas_Ace
Texas_Ace's picture
lol, good catch.
SKV89
Last seen: 5 min 20 sec ago
Thanks TA and Maukka! Finally some good 4000k 90+ CRI emitters. The FA3 is further below the BBL whereas the FD2 is still mostly above the BBL so I think the FA3 should have much better tint especially when used in mid and low output. It could be just the random sample though. Hope we can get a group buy for these soon to be extinct good tint SST-20.
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 3 days ago
Huh, guys I just noticed.
The SST-20 4000k is now available on Mouser.
Will ask for the tint bin.
Might be good like the 3000-3500k, but I really doubt it.
Texas_Ace
Texas_Ace's picture
For some reason the WW (sub-3500k) and CW tint (5700k+) SST-20 are available below the BBL but the NW mid range tints are basically impossible to find. They have 100k FB4 tint bin LED’s ready to go though lol
SKV89
All the 3000k on the market are good. However, didn’t the 3500k group buy you organized that Mouser said was GA3 tint bin unfortunately tested out to be above the BBL and likely a GB4 tint bin?
BlueSwordM
No, it was a GA3, right on the BBL. That’s what Mouser told me anyway.
The problem for these LEDs is that they tested very slightly below the BBL, or on the BBL.
That means while an LED might pass Luminus’ binning tests, it might not for us flashlights.
SKV89
Actually it is slightly above BBL even without reflector or optics. Once you add the reflector or optics and/or run it on low output, it will always be above the BBL, so it is not like the 3000k HD2 tint bin that is always below the BBL. GA3 tint is supposed to be entirely below the BBL.
http://budgetlightforum.com/comment/1463714#comment-1463714
ToyKeeper
ToyKeeper's picture
Last seen: 33 min ago
This is really useful data.
I was really hoping the FA3 bin would be below BBL even at low power, but it looks like it still isn’t. Great tint at higher power though. I should put some on a MCPCB to see how it looks during use.
Agro
Agro's picture
Would it be safe to use SST-20 with a FET driver in 18650 light?
