Here are some (better) photos comparing the RovyVon A8U and the RovyVon A5R!
I’ll show the front and the side emitters and how they perform (mostly in outdoor environment).
As mentioned above, the A8U has a better tint than the A5R, even if it implies less output on the front LEDs.
On the contrary, on the side the A8U Red and White emitters are stronger than the ones from the A5R.
Thanks
Hum, actually I didn’t try it yet, but 99,9% sure it will work pretty fine on the cap/hat brim! The clip is strong so it will have enough grip to stay put . Also, as it is a side switch if you leave the button towards the top or bottom (depending on how you prefer to use the light) you’ll have a good pressure point with index or thumb
I’m not sure if RovyVon has a discount on this currently, but try leaving a message to Ken/Kay through their e-mail and see what you can get
I’m sure they take care of their BLF fellows
I guess that if the brim was thinner, it would go further into the clip, but this a thick one and I don’t have a thinner cap around! Still, you can have a notion on how it fits
Thanks for the thorough photo comparison, Mascaratum!
My Aurora A8 likely arrives on Tuesday. Tint looks very nice. I’d rather have that with slightly lower output. Very much looking forward to it! I had to return my Nitecore TIP CRI (2 of them failed on me) and I wasn’t going to chance it a 3rd time. While I like that form factor, the sad thing is that Nitecore made it a 2-piece shell, while other brands have done a similar design with a one piece main body (and separate piece for tail cap). It was worth an extra $10 to step up to the RovyVon A8.
We both missed the 20% off deal over the Chinese New Year. But there’s still a 10% off coupon floating around somewhere.
Thanks for your words
Now that you talk about it, here’s a photo comparing both!
I do like the TIP (mine is the CW version), I always carry it in my backpack, and it also has a 2mm “paracord” lanyard to be put in the neck if needed! That clip is handy to use it as a “mouth” light
The greatest difference we may get between these lights is the runtime as the TIP has a bigger battery! But if you use the light for short bursts on max, it will do great!
I guess you won’t regret those extra $ ! This is a sweet light
Is the UV emitter on the A8 effective for showing security markings on paper currency? If I buy a light with UV, that’s what I’d most likely use it for.
Hum, I guess the following pictures will answer your question, but in general, NO! The light doesn’t seem suitable for that!
This is a comparison between the A8U (left) vs Lumintop Tool AA with Nichia UV 365nm ZWB2 UV filter (right)+ .
Hum, it is not blue, it is like purple. But I’m not sure if it is due to the host. The other UV light I showed, when used without the UV filter produces a different type of “light” but we can still check those marks un currency. The UV filter only “filters” the more visible light.
So I believe it has to do with the type of emitter used and not the host itself ! Can it be :question:
If you take your Tool with ZWB2 filter and turn it on at Aurora - does the side white LED start to shine? If it does - the host passes the UV light which excites the phosphor. If it doesn’t - the host blocks UV.
You could also try to take ZWB2 filter and put in front of Aurora’s UV emitter and see how does it work…
I tried that in a photo from the OP! I guess this is what you mean, right? The Tool AA was shining above the A8U and this was the result!
Hum, I did it but it didn’t change much! I put the filter in front if the A8m but there was no change in the way I was seeing the marks in the 5€ bill! It never appeared as the Tool AA, the marks were never “revealed” with the A8 :weary:
I forgot about the OP pic.
Yeah, seems like the body is not the culprit. It surely absorbs some of the light and reemits it but seems that some gets transmitted.
I don’t know about banknotes….
I see that it shows some marks but very poorly. So maybe the issue is that it generates a lot of visible light (luminous body doesn’t help) relatively to amount of UV?
Then ZWB2 should help….but it didn’t…I don’t know.
Yup, there are only 2 or 3 small marks that could be seen, but nothing like the the other UV led form the Tool AA!
This A8 doesn’t have the luminous body, that one is the A5 So that part of glowing doesn’t interfere with that! The body is transparent, but even with the UV filter it doesn’t get different if front of it! Later today I will try to show it on a picture!
I guess it has to do with the UV LED used :zipper_mouth_face:
