My local range has a Cabot Circular pattern Damascus 1911 that has an $8,000 price tag on it.
EDIT: http://cabotgun.com/better-than-custom-1911-pistols/the-damascus-ladder-deluxe/#1
Apparently its “on sale”, MSRP is listed at $10,000
Doesn’t meteorite tend to be brittle? I’d hate to be the first guy to shoot one of those guns to find out if it holds together.
Looks like most of the ware and pressure holding parts arnt from space metal…
I won’t buy a flashlight thrown from the 50th floor with tons of nicks and cracks. :smiling_imp:
I would much prefer an FW3A machined out of ice, to not be burn if it accidentally turn on in the pocket + active cooling for max lumens :+1:
The excerpt below, taken from THIS ARTICLE ; tells what they did.
“The pistols are fully-functional – and resultant of their National Match barrels, accurate; verified both on the rest and in off-hand shooting. Leaving nothing to chance in terms of functionality, our engineers used electron beam technology to meticulously add bimetal support only to the frame/slide rails, hammer, guide rod and extractor of the Big Bang set. – and the pistol’s components, down to the barrel bushing and trigger – are 100% Gibeon meteorite.”
<_<
>_>
Not sure if serious or humor.
I’m interested in one
Personally, I hope humor….
GOOSE, IF they do not glue the tailcap it can be easily removed. If they do use glue on the tailcap it might be a bit more tricky.
Snip the metal and file it down in worst case scenario.
Ah I see, thanks Teacher for clearing that up.
Today is the last day of CNY. Just sayin’.
If the tail is glued and you cant get the clip off I’ll be very irritated. Can’t stand pocket clips on my lights
Interested dependant on cost of shipping to Australia!
I would bet that worldwide shipping is included in the price.
I really need to not respond to threads first thing in the morning
It looks as though the front/rear thread o.d. is the probably the same, but if they did glue the tailcap that would permanently secure the clip and it could not be removed even if the user did not want it? I’d rather have the option to carry it in my pocket w/o the clip or be able to reverse it for a cap.
Im not above saying something stupid but…. I suppose it is no more ridiculous than flashlights made of meteorites and hiking boots.
Actually I was serious(but as I mentioned earlier in the link above)as a custom clip that would work on the bill of a cap…. why wouldnt this design work if the other clip could be removed? I realize this design would not be preferred for a ‘dedicated’ pocket clip even though it could still be used as one(using the 1st bend) but more important to me, also on the bill of a cap. As I said earlier, I dont like or use pocket clips and would probably remove the current clip if it wasnt glued.
My pleasure GOOSE. :+1:
If you still want to be on the list, you may want to edit your "remove me" post.
Actually I was serious, but only, as I mentioned above, as a custom clip that would work on the bill of a cap…. wouldnt this work(if the other clip could be removed)? I realize it wouldnt work for a pocket clip but as I said above, I dont like/use pocket clips and would probably remove the current clip if it wasnt glued.
Good point…. :person_facepalming: . :+1: .
I would personally prefer to be able to use the clip on a cap, or remove it, so I hope it is not glued. If it is glued, I will use it with the clip as is, and be fine with it.
