To illustrate max-width, here’s an image of two Emisar D18s. It’s 619px wide, so if you view it on a typical phone, it will be wider than the post panel, or the phone’s screen. Viewed on a desktop, it’s considerably narrower than the space available.
First, with max-width: 100%
And now with width: 100%
Both fill 100% of the space on a narrow screen, but the second is stretched on a wider screen.
I always put 95. I absolutely cannot stand when people ignore scaling their image. Maybe the webmaster can set some kind of default width of 100? That way this catches mistakes. But yeah, I also think it’s painfully negligent and inconsiderate for people to embed images greater than a couple megabytes. 15Mb? That’s OBNOXIOUS.
Nothing to envy….in fact it’s pitiful. It’s in the old country and maybe 10 people live in the village in winter. 100 in the summer. If I don’t pour money into it, it’s going to fall.
Every time i go back, I check up on it, but never slept a night in my life in it. But the view….oh God. It’s feeds the eyes and the soul.
This seems like the most universal way to improve things, and should probably be in the default CSS.
Also, I just added this to the script I use to generate the markup for adding images. I had been doing 800px images, but now it’ll do 800px which also scales down on small screens. A normal width=“100%” hint is annoying on large screens, but the max-width method can improve things on small screens without creating extra problems on big screens.
I thought the beer was a ploy, he was buying you had to come to the cache site to drink it… his place that needs work. Figured he’d gather a crowd on the beer premise then put everybody to work.
This forum “speaks” two languages, and I mean the Advanced Post Editor. I use no other due to the Simple Editor's unability to handle special character links.
The max-width thing does not work in the advanced post editor, or I do not seem to make it work. The advanced editor may thank some improvement. As I have said elsewhere this could get improvement with unification. Concerning conversion Simple to Advanced is incorrect, and Advanced to Simple is hopeless.
Onto what matters: the max-width thing is not really necessary for those who care to check their image's size. Images up to ≈640 pixels can be left unscaled, while the remaining can use width x%.
The following is to report something I already noticed in the past with regards to the max-width property. Let's see an example with a funny gif:
With 336 × 210 pixels of actual resolution I've scaled the gif at 3x its per axis resolution: 1008 × 630 pixels. Also, the max-width property is set at 100%. You will see the upper, scaled gif with wrong aspect ratio in small screens (with less than 1008 pixels of available space for the forum box).
Is it possible to set a youtube video to a % of column width.
I tried a few different ways and all I seem to be able to do is set the width in pixels.
Thanks for the help,
All the best,
Jeff
Setting the width in % as you did in the Simple Post Editor does not work, also tried a max-width attribute to no avail.
Let me say I've always been using fixed resolutions for videos via the Advanced Post Editor. Any video's optimal resolution can be obtained selecting “Nerd statistics” in the drop down right click/long tap video window menu.
Just tried setting the video width in % in the Dimensions left, horizontal box, using the Advanced Post Editor. It actually works, albeit it will look garbled while editing and Preview gets broken. Here it is set at 70% width:
