[♛ FreemeGB] Haikelite MT09R 3x XHP70.2 25,000lm & 3x XHP35 Hi 6500LM Flashlight Group Buy -【 ACTIVE 】
474 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 2 hours 30 min ago
scr79423 wrote:
JasonWW wrote:
scr79423 wrote:
have any of you tried bypassing all the springs successfully?
Which model?
I believe it’s fine to bypass all the springs on the 70.2 version. (Edit, if it’s the new factory driver this might burn the big FET)
You don’t want to bypass any of the springs on the xhp35-HI version.
i ordered a 70.2 MT09R and im planning to bypass all the springs with 20AWG
Only do this if you are also upgrading the main FET. The stock one will die if given anymore power.
freeme
freeme's picture
Last seen: 2 hours 13 min ago
Bypass not advisable. sealed
scr79423 wrote:
JasonWW wrote:
Which model? I believe it's fine to bypass all the springs on the 70.2 version. (Edit, if it's the new factory driver this might burn the big FET) You don't want to bypass any of the springs on the xhp35-HI version.
Andybibbville
Andybibbville's picture
Last seen: 2 hours 32 min ago
Is this flashlight really 25000 lumens?
John 12:46 “I have come into the world as a light, so that no one who believes in me should stay in darkness.” Genesis 1:3 And God said, “Let there be light,” and there was light.
JasonWW
JasonWW's picture
Last seen: 2 hours 10 min ago
No, Haikelite exaggerated a little.
BlueSwordM
BlueSwordM's picture
Last seen: 1 min 37 sec ago
Yeah.
You’d need spring bypasses and top LED bins only to achieve 24 000 lumens with a calibrated tube.
The MT03 TA is a more accurate representation of what it can do with spring bypasses.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
Andybibbville
Thank you all for the info.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 21 min 55 sec ago
BlueSwordM wrote:
Yeah.
You’d need spring bypasses and top LED bins only to achieve 24 000 lumens with a calibrated tube. […]
For those who use the original MT09R driver (not the TA or Lexel driver), it is highly recommended to exchange the SIR800 MOSFET by a better one that can be driven up to 100A (e.g. Infineon) if you plan to bypass your springs.
JasonWW
JasonWW's picture
You don’t mean the “original” driver (that one was rubish), your talking about the current, stock driver designed by TA. That’s the one that has the weak FET.
There’s 4 drivers for the 70.2 version and it can be hard to keep track.
Lux-Perpetua
Exactly, that’s what I meant to say. Thank you Jason! Thumbs Up
JasonWW
JasonWW's picture
MT09R or Astrolux FT03?
JasonWW
JasonWW's picture
Thumbs Up
Lexel
Lexel's picture
Last seen: 2 hours 25 min ago
So now I can also confirm it MCU and FET on the HL drivers for this light are faked from some chineese manufactory
MCU has not even unusual markings it has even a spelling error missing an S in the type
“ATMEL20U”
“TINY85”
“7 digit batch number”
while the original Atmel has
“ATMEL 4 digit batch”
“TINY 85”
“20SU”
“triangle”
and 3 rows batch data on the back side where the fake has nothing
I have measured the FET used on the red MT09R driver
its labeled like the original Vishay cant tell any difference
Original @10A and 4.7V Gate
https://eu.mouser.com/datasheet/2/427/sir800dp-93246.pdf
SIR800 —> 2.6mOhm —> 26mV —> 0.26W
the SIR800 has pretty stable resistance down to 2.5V Gate voltage so its a good FET for 1S lights as well
Fake
@4.7V Gate like the MCU delivers to the FET
I got 38.3mV 10A —>3.8mOhm resistance
@3V Gate
I got 165mV 10A —> 16.5mOhm
@2.5V which the original should have around 2.8mOhm as its gate voltage gets very deep till 2V pretty stable
I get only 2A with reasonable input volatge and the stunning drop on the FET of 1.1V
so here the FET has 0.55Ohm
Conclusion
the FET HL use is definately some sort of fake which wont work on any 1S driver well
with 4.7V on gate it has a usable resistance but still this FET is like the MCU fake
JasonWW
JasonWW's picture
Thanks Beer
scr79423
Last seen: 2 hours 41 min ago
So i just completed bypassing all my carrier springs with 20AWG, using x4 VTC5A flat tops, did a 35s run on max output and my stock FET is still working! 20AWG in driver spring and all carrier springs
scr79423
i recently got a set of the Murata version of the VTC5As, strangely i measured 2,000 lumens gain over my regular VTC5As in my MT09R all springs bypassed, I’m not sure if my regular VTC5As are fake or genuine but aged cells?
MT09R bypassed = 18433lm Murata VTC5A flat tops
MT09R bypassed = 16390lm VTC5A flat tops
DENGOH
DENGOH's picture
Last seen: 1 day 8 hours ago
Sigh… Haikelite has good product lines, but the brand is cheap to its management as they don’t mind using fake components and caused so much trouble to customers. Mine MT03 TA had faint leaking light during off and after spending month negotiations with CS to get a new driver from Haikelite and I paid for shipping, the new driver was having same issue. Desoldered and measured both fake SIR800 to be having around 50Mohm of resistance with 0Vgs, they are not completely open.
I replaced the FET with real SIRA60 and it works fine. Also replaced the FET of another driver with BSC009 and put it into old MT03 II, it works fine too. Now these two MT03 are always in momentary mode with 5clicks, have had blasting them side by side for 1+ hour in accumulation, almost burn my hands as they are really hot.
Good thing was Haikelite forced me to learn how to use hotair gun. After watching some YouTube video, i managed to solve it to good ending.
cool i'll see you when you get there
DENGOH
DENGOH's picture
Measure the internal resistance of those cells, the values should indicate which cells are aging more.
Lux-Perpetua
I recently bought the MT09R from HaikeLite‘s new store on AliExpress. It still uses the SIR800 MOSFET. In factory condition it can do about 50-60% of its advertised 25,000 lumens. Please read here for further details...
http://budgetlightforum.com/comment/1498226#comment-1498226
JasonWW
JasonWW's picture
Genuine or fake SIR800? The exterior looks the same, but they are different internally. This is the point everyone has been making.
Lux-Perpetua
Is there any way to tell them apart except for testing it in detail as Lexel did? However, it did not burn with all springs bypassed.
JasonWW
JasonWW's picture
I don’t think so.
scr79423
My MT09R all springs 20AWG bypassed using fully charged Murata VTC5A flat tops on stock FET, Measured 21433lm at start up.
hIKARInoob
hIKARInoob's picture
Last seen: 9 min 3 sec ago
Awesome beam.
