I just tried a 100K resistor with the OSRAM. The noise, amplitude and sensitivity didn't seem to change, but the fall time increased about 4X, causing clipping to occur sooner. However, whatever seems to work - which is why I said "the resistor values on my schematics can be taken with a grain-of-salt. My values are just a starting value. You may find lower/higher values work better in your circuit". . Was your supply voltage the same as mine?
The Thorlabs DET36A2 uses a 12V battery for biasing voltage (significantly higher than what I used), and they recommend a 50Ω BNC cable impedance matched to a 50Ω terminator. Can't say if this would give better results for measuring display PWM. If you decide to buy one, let us know the results.
This is a good thread. I managed to miss it when it was new, but I wonder if you might be able to scope the results when using a regular LED as the sensor?
I realize this idea was ruled out since they aren’t optimized for use as a photodiode and may produce less than satisfactory results. But I wonder what the results actually are. I’ve been able to measure frequency pretty effectively with a plain XM-L2 inside a Convoy S2+ head to focus incoming light onto the LED… but I don’t have a way to see the actual waveform.
Problem is - I don't do modding, so don't have much in the way of LEDs to test. The only LED's I used during my sensor test, was a stock off-the-shelf LED like this one. I do remember trying to use the white LED as a sensor, and it hardly worked at all. HOWEVER, other LEDs (actually used in flashlights) might work better. If you or anyone else want to mail me a particular LED, I will certainly volunteer to test it (will return if they are expensive).
Hey, if it will help further BLF driver development, I’ll send you some emitters for free. I’ve got lots of different LEDs that are just lying around right now because I pretty much lost all my modding time to a change in work hours a while back.
I’ve got…
a couple hundred cheap XP-sized “1W” Chinese emitters. These are “bare” in a pick-and-place roll.
several XP-E2 on 20mm non-DTP Aluminum MCPCB’s
a few XP-L HI. I can’t remember how many, but not much. I’m not using them, so they are available.
a few XP-G3. I don’t know how many of these either. I haven’t counted recently.
one Sofirn Q8 MCPCB still populated with the stock XP-L HI emitters. I replaced the whole thing.
a couple of de-domed Luminus SST-90 on the stock DTP MCPCB’s
some other random XM and XP emitters pulled from lights that I’ve modded.
maybe still a MT-G2 around somewhere as well
ToyKeeper, the offer is open to you as well, of course!
EDIT: To clarify, I’m not offering to send “all of the above” for free. I’m just listing what I have to let you know that I could send you several kinds. But if you decide you do want it all, I can let it go for a small amount.
I wouldn't have time to test all of them - but if you could pick about four of them - that you think might work in reverse to measure PWM - I will test them - to see if they are anywhere near as good as PIN photodiodes. Would be an interesting experiment. PM me.
ToyKeeper, do you have any input about what kind of LED is the most likely to give the best results as a photodiode? Is it the same property that makes a good LED or something else?
Mostly, the same things which make it good at producing light. But in particular, a large die surface and probably a relatively high Vf. That raises the amount of voltage it’ll produce. A reflector helps too. And being a recent LED helps, instead of an older model with a slow response time. Upgrading from XM-L to XM-L2 allowed me to measure a bit better.
If an emitter normally starts lighting up at ~2.4V, it’ll generally produce up to 2.4V when a light is shined at it. But if it’s a higher-voltage model which doesn’t light up until ~4.8V, it can produce twice as much voltage, which might be easier for the attached DMM or scope to read. Generally the range is from 0 to the lowest voltage which will make it light up.
I have a bunch of broken lights I could take apart for parts if it would help. For sensor purposes, it just needs the head of the light with two wires sticking out. I have several dev hosts set up this way so I can access the driver for easy flashing and testing purposes… I generally just grab one of those and clip on some DMM leads.
I’m not sure if it helps to remove the phosphor layer. I haven’t tried. Also not sure if it helps to add something to pull down the signal faster after each pulse. It probably does. With just the emitter though, I can at least confirm it handles 36 kHz PWM with no problems.
When I tested flashlights I used a photo diode parallel to a resistor directly connected to the scope for measure PWM. The value of the resistor has a significant influence on the fall time, but also on output voltage.
The red line is voltage on led, the blue voltage from photo diode.
HKJ, can you sketch out that schematic? I wouldn't have thought that a resistor in parallel with the sensor would work, as the reverse bias would cause the current to seek the path of least resistance, mostly going through the resistor and not the sensor.
Thanks ToyKeeper, that makes sense, from my original post:
[quote]
It was also noted that the best sensors in this review had large sensor areas.
[/quote]
I managed to get one of these lights apart, a Sofirn SF36 with a broken driver. The LED is fine though, and works as a PWM sensor. It looks like an original XP-L, which is basically XM-L2 with the sides of the dome chopped off. It handles 36 kHz just fine on my DMM, but I don’t know how the actual scope traces would look.
I could send it, if desired. Either the whole light or just the head.
