13583 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 9 min ago
This should probably be in every FAQ, just after the part where it tells people to put the battery in from the front instead of the back. It seems to be one of the main things people don’t know, but should.
cannesahs wrote:
2) Why muggle mode steps down to bottom of muggle ramp? It seems to happen from every higher muggle ramp power – the higher the faster. You can ramp back to higher or switch off and back on to get back to higher muggle ramp power. Battery has plenty of voltage: works fine without stepping down in non-muggle-mode. And thw FW3A stays cold.
alex64 wrote:
This “problem” it happens in my two Fireflies E07 with Anduril, so it’s due to the design of Anduril and not the FW3A.
If muggle mode steps down, you need to calibrate the temperature sensor.
This only needs to be done once, when the light is new. Afterward, the value is saved permanently so there should not be a need to do it ever again.
The sensor is built in to the attiny85 chip, and the attiny factory does not calibrate it. The flashlight factory does not calibrate it either. This, unfortunately, leaves that job to the user. If it is not calibrated, it will have no idea what the temperature is. It could be off by as much as 25 C.
To calibrate it:
  1. Let the light settle to room temperature.
  2. Go to the thermal config mode.
  3. At the first menu option, while the light flickers and waits for input, click to enter the current room temperature. This is typically about 20 to 25 C, meaning 20 to 25 clicks.
  4. Wait until the light falls out of the menu.
On this version of Anduril, here’s how to get to thermal config mode:
  1. From off, click 3 times. This goes to battery check mode.
  2. Click twice. This goes to sunset mode.
  3. Click twice. This goes to beacon mode.
  4. Click twice. This goes to temperature check mode.
  5. If you feel like it, let the light blink out what it thinks is the current temperature. On a new light, this number is probably wrong. Have a laugh.
  6. Click 4 times to reach thermal config.
This is also shown in the UI diagram. Follow the pink line:
On newer versions, I’ve also added a shortcut to this, using ten clicks from off. But that’s a very recent thing, and isn’t on the FW3A yet.
WalkIntoTheLight
Last seen: 4 months 4 days ago
Based on experience, muggles (i.e., kids) tend to like to click things a lot. They could very easily do 10 clicks in a row, then who knows what to the thermal setting.
Maybe this is already the case, but perhaps don’t allow users to enter configuration settings if in muggle mode. I’m guessing you already did that, but just in case…
Without the 10 clicks, it’s not so important. It seems difficult to get into thermal config by accident.
saypat
saypat's picture
Last seen: 4 hours 4 min ago
To calibrate it:
    • thank you for the simple explanation here. Could you please explain in simplicity part 2, the temperature limit thing? Thank you from us who find this rather confusing … even after watching M4DM4X video of it Wink
teacher
teacher's picture
Last seen: 9 months 3 weeks ago
@ Saypat
Here you go, in detail…. Temperature Calibration & Setting Temperature Limit
Thumbs Up
saypat
saypat's picture
thank you kindly teacher, appreciate your help….
xevious
xevious's picture
Last seen: 20 hours 21 min ago
My FW3A arrived on Saturday, but I was away—just picked it up out of the mailbox. It wasn’t functioning right out of the box. It would not stay on. I discovered that the tail cap wasn’t fully seated (per the instructions I had inserted the battery by removing the head — hadn’t touched the tail). After tightening it, it worked initially, but would “wink out” on max. Apparently the seating wasn’t quite complete, so I loosened the tail cap then tightened it again. After that, it started working OK.
Overall, seems like a terrific light. Has that HDS form factor with superior UI. Can’t get over how it’s only a few millimeters taller than an Astrolux S43 with 18350 battery tube, while the FW3A uses an 18650. Truly remarkable. Glad I got this and thanks to the FW3A team & Neal for the wonderful Group Buy opportunity!
teacher
teacher's picture
My pleasure… Thumbs Up
Boaz
Boaz's picture
Last seen: 1 day 17 hours ago
moridin wrote:
JasonWW wrote:
Nev wrote:
moridin wrote:
Does anyone know, if the emitters (XP-L Hi 3D) are sold separately?
Yes & no , if you buy a FW3 you get 3 ,XPLHI 3D emitters free ^:)
Too expensive.
Yeah, i was hoping for a less expensive solution ;)
 Buy them from someone who pulls them from their light. I'm guessing they probably don't want them very much if they are pulling them. If you're in Germany maybe Lexel? Odds are at some point he'll be modding a few FW3A's for some folks . Maybe start watching some of the mod threads or start a WTB thread .
Sudsy
Last seen: 1 day 20 hours ago
I just got my shipping notification from Neal for one 7A and one 3D. I was the 1472nd person in line for the coupon code private message, so we must be very close to the end of shipping out all the pre order lights!! Party
JasonWW
JasonWW's picture
Last seen: 1 hour 30 min ago
They are not being shipped out in any particular order.
Edindevon
Last seen: 6 months 3 weeks ago
Marc E wrote:
Nev wrote:
PreacherCasy wrote:
Edindevon wrote:
G0OSE wrote:
Same here, so it’s not just yours if that makes it feel any better Crying
I think 4 of us are in a similar boat. Around 5 am on Sunday morning?
Yep, that’s what I’ve got. Fingers crossed they’ll be out on Monday!
5 .
2019-05-05 04:48 LONDON Arrived at LHR, Custom clearance processing.
Six Big Smile
Has tracking stopped for anyone else today? I get an error in Chinese, Google translate suggests “please enter verification code”
EnlightenMe
I finally figured out what that fifth pocket is for on your jeans: the FW3A. Crown
Marc E
Last seen: 7 hours 25 min ago
Yes, me too, using Flyt Express.
Given that the error message only flashes up for about 3 seconds with nowhere obvious to enter a code i get the impression it’s a site error rather than anything to do with the delivery process, but have no idea how to check this or actually track the delivery :/ (It’s not showing up on RM or Yodel).
Edindevon
Marc E wrote:
Yes, me too, using Flyt Express. Given that the error message only flashes up for about 3 seconds with nowhere obvious to enter a code i get the impression it’s a site error rather than anything to do with the delivery process, but have no idea how to check this or actually track the delivery :/ (It’s not showing up on RM or Yodel).
Thanks, I had a similar thought. As it’s more than just me I’m more happy that it’s a site problem. I know it’ll arrive in good time, just excited.
When it was working it brought up a code beginning with an F which worked to give the same information on 17track. Wish I’d made a note of it.
Marc E
It’s handy having someone to compare notes with!
mortuus
mortuus's picture
Last seen: 10 hours 19 min ago
my tracking only shows this, not sure whats going on ?
May 10 08:08
Electronic shipment information received
PostNL
...where Frugal meets with Flashlight!
caplang
Last seen: 8 months 1 week ago
My FW3A arrived after precisely 2 weeks.
teacher
teacher's picture
May 10 08:08
PostNL
That means the shipper has been notified (electronically) to expect a package. In other words, your package will be shipped soon.
jknut
Last seen: 1 month 1 week ago
I wanted to share my attempt to make a diffuser. The diffuser rests on top of the clip when extended. The diffuser can be pushed down and held in place with the clip with minimal increase to overall diameter or length.
1) Purchased glucose tablets for $1.89 from CVS drugstore (USA).
2) Removed label and sanded to roughen finish to better scatter the light
3) Sanded top to remove raised edge
Tom E
Tom E's picture
Last seen: 10 hours 34 min ago
I should be getting a 3D and a 7A today via DHL. I'll report on the the 7A comparing to the 3D - don't think anyone received a 7A yet.
contactcr
Last seen: 3 hours 56 min ago
!{width:15%}https://i.postimg.cc/xCC0ptzt/20190513-093111.jpg!
I always wonder how these types of diffuser would look with some foil in the top (bottom?)
xCentrino
xCentrino's picture
Last seen: 1 year 2 weeks ago
how well does the “diffuse” stay on? While simulating signalling to person or vehicle?
Mine still in transit, or would test myself.
jknut
xCentrino wrote:
how well does the “diffuse” stay on? While simulating signalling to person or vehicle? Mine still in transit, or would test myself.
I’m planning to use it while tail standing so this works okay for me. Tape could be used to reduce the inner diameter of the tube a little bit to make it more secure.
Scallywag
Scallywag's picture
Last seen: 2 days 10 hours ago
Mine arrived Friday! Busy weekend.
Impressions:
  • It's very small. Shorter than my SC62. Almost the exact same length as my D4, while being thinner.
  • The design is unique among my lights. Very sleek.
  • I initially wished the pocket clip was of a deep-carry style, but after two days I don't care. The design is extremely secure, and I don't notice that the clip ring is "too wide" unless I try.
  • The anodizing is very smooth, almost slippery. However, I don't have any issues hanging on to the light.
  • The button is very tactile. It can be pressed from the edge, and it will kind of rock slightly, but it still registers the press.
  • The beam is very nice with this optic/emitter combo.
  • Turbo will cook the light very quickly. It gets hot faster than my D4 with Luxeon V. Nobody was kidding when they said this host was not designed to handle high-power turbo heat. I have reconsidered my desire to swap Luxeon Vs into this light.
  • First Anduril light. Neat stuff.
God, with lights this compact using 18650s, all my 16340 lights make me feel like I'm getting screwed on capacity & output.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
BlueSwordM
BlueSwordM's picture
Last seen: 6 hours 54 sec ago
Oh this would make me wish the FW3A was built like an Emisar D4 and an 8A linear driver.
Would be a very nice upgrade.
Rando
Ditto.
Nev
Ditto, but if you go to 17track it still works but it still hasn’t moved.
xevious
xevious's picture
Impressions:
  • It’s very small. Shorter than my SC62. Almost the exact same length as my D4, while being thinner.
  • I initially wished the pocket clip was of a deep-carry style, but after two days I don’t care. The design is extremely secure, and I don’t notice that the clip ring is “too wide” unless I try.
  • The anodizing is very smooth, almost slippery. However, I don’t have any issues hanging on to the light.
God, with lights this compact using 18650s, all my 16340 lights make me feel like I’m getting screwed on capacity & output.
Good points. It’s amazing how compact this is for an 18650 flashlight with triple emitters. It’s exactly the length of a Zebralight SC64 (single emitter 18650), while being slightly wider. Will have to show a photo comparison. So pocket-capable. I thought the super smooth anodizing would be a problem, but the wide band of knurling on the head module is decent enough for grip, and the lip of the tube where it meets the tail cap helps a lot. A fully knurled body would ruin the aesthetics. The lack of any markings whatsoever adds to the cleanliness. Button design is excellent and feels tight to me (don’t perceive any rocking). My only gripe is that press-hold for moonlight requires a little longer hold than I’d like (I trigger last mode a bit, forgetting I need to hold a fractional second longer for moonlight). Turbo does indeed heat up pretty fast. Something like an Astrolux S43 has a much beefier heat sync. But one has to keep in mind this form factor with present day LED’s is just not appropriate for long max output. The 3D tint seems to be like a neutral that reveals cooler on turbo, which works fine for me (generally I prefer warmer, like Samsung LH351D in ZL SC64c LE, but also enjoy neutral). This is also my first Anduril light and the UI has some interesting differences from NarsilM.
Bob_McBob
Last seen: 3 days 9 hours ago
Tally-ho wrote:
The average value can be considered as medium but in details, colors rendition are pretty mediocre : see Bob_McBob’s measurements *here*.
I have measurements on other levels in my Reddit mini-review. Unfortunately I couldn’t get a 7A or 1A to test.
Cree XP-L HI “3D” (4750-5000K)
Level CCT Duv CRI (Ra) CRI (R9) Data
Turbo 5052K 0.0006 70 -27 TM-30, R-values
Ramp Ceiling 4856K 0.0037 70 -31 TM-30, R-values
1×7135 4796K 0.0040 71 -26 TM-30, R-values
Nichia 219B sw45k R9080
Turbo 4550K -0.0163 94 85 TM-30, R-values
Ramp Ceiling 4483K -0.0106 94 94 TM-30, R-values
1×7135 4477K -0.0095 95 91 TM-30, R-values
Edit: I forgot to include the dedomed LH351D results.
Dedomed 5000K Samsung LH351D (SPHWHTL3DA0GF4RTS6)
Turbo 4447K 0.0008 92 52 TM-30, R-values
Ramp Ceiling 4294K 0.0003 93 59 TM-30, R-values
1×7135 4164K -0.0003 94 64 TM-30, R-values
xevious
xevious's picture
17track worked well for me, showing status from shipped to delivered. Since it was handed off to USPS for final delivery, I was expecting the USPS tracker to show it, but it never recognized the tracking number.
2019-05-10 11:29 Union City, NJ, US, ARRIVED USPS SORT FACILITY
Weird that USPS never showed it.
