*BLF LT1 Lantern Project) (updated Nov,17,2020)
No, it is Lexels programming Key: BLF driver programming key v3.2 launched on Oshpark
Thanks for confirming it was the second option.
Ouch… I bet somebody got a serious black mark for that little oversight…. :smiley: … :person_facepalming:
I see two different ones available in the jungle store. When open, one is roughly square with two panels, and one is rectangular with three smaller panels. One of the rectangular ones is only $16, while the other ones are $30. Which style or 10W panel do you have? (DBSAR and goshdogit)
Do not get the clone with square panels! - I have the real Eceen 10-watt folding panel,)(that has the cut corners of the cells) This one, but its from the Amazon.ca Canadian site, its available form the Amazon.com US site too. >> Amazon.ca
or go to Eceen’s website here, which is where i got my genuine Eceen 10-Watt from: >> ECEEN Solar Charger External Battery 5V 10W Folding Solar Panel For IOS and Android ECE-647 Cam,solar panel, solar charger, foldable solar charger bag, solar battery charger, solar battery pack, flexible solar panels, waterproof solar bags, solar backpacks, solar cell phone chargers, mobile,ECEEN Electronic limited.
(the real one, the other is a knock-off)
I have the same ECEEN 10 Watt model that Den has in his video, but mine is black and his is camouflage. They fold in half and close with a zipper around three sides and look like this:
I got mine on ‘the auction site’ for $14 late last summer. It think it may have been a pricing error. :smiley:
Den and I discussed this ECEEN panel a while back, and I linked to a couple of review videos I found. One of them discusses the ‘automatic reset’ function that Den mentioned.
Yes, it works. The HQ ProgKey Universal adapter is what I’m using. It works with any layout which has the pads spaced at the right distance, as long as it’s 4x2 or smaller. Admittedly, that’s still pretty specific… but it’s universal as far as my current set of drivers go. I have a few different drivers with different pad layouts.
Either one should work though. I just went with this one because it’s smaller, cheaper, slightly more flexible, and easier to reconfigure.
I’m interested in one.
Which is the exact reference of this model?
thanks DBSAR and goshdogit. The picture and links are very helpful. Both panels I described are listed as sold by ECEEN, but as I look closer now the less expensive model has only 3 panels, not four. Both have the cut corners, but the 3 panel one definitely looks different. It is marketed as “Waterproof” which may be why it looks different. Regardless its unlikely they can get the same power (10W) out of both the 3 and 4 panel version. I’ll be picking up the one you recommend. :+1:
@fneuf, this is the one they are recommending:
In camo color
In black color
Then "ECE-647" it is ! Thanks.
Unfortunately this is difficult to source in EU. Only found a 53€ deal...
I'll take two (2) please .. ..
I’d like two, please
I’m interested on one (1) to keep my Q8 company. :slight_smile: Thanks.
looking good!
re-subbed
:+1:
I’m putting in for 2, please. Thanks
Please put me on the list for one. Thank you!
Here are the additions since 5/12. If you haven’t already done so don’t forget to check that your BLF user name is correct on one of the spreadsheets linked in post #1.
This is a 1 time only check.
Thanks
1546 O26Rcr
1547 O26Rcr
1548 Tarvos
1549 Eggun
1550 mb200k
1551 LoPan12
1552 funkychateau
1553 OtisCampbell
1554 Bayside_Tigers
1555 Bayside_Tigers
1556 TanteElfriede
1557 Alphacentaury
1558 Lux-Perpetua
1559 RainF
1560 RainF
1561 taenzerwalze
1562 Hellie112
1563 lroach
1564 Grinspooner
1565 Grinspooner
1566 hunter1
1567 hunter1
1568 mitsuki08
1569 Naxos
1570 Oodin
1571 sleasys14
1572 Tredd
1573 muddyone
1574 cyropro
1575 Melez
1576 Sparks65
1577 Brinkmann
1578 radicalphoton
1579 Blinded by the Light
1580 Blinded by the Light
1581 Ssthis
1582 Ssthis
1583 terranaut
1584 Sper17
1585 AgentWhiteBread
1586 AgentWhiteBread
1587 BillyBobJoe
1588 djypo
1589 KawiBoy1428
1590 KawiBoy1428
1591 CLB
1592 Flintstone
1593 Kiltan
1594 Sparky.
1595 Sparky.
1596 BVH
1597 BVH
1598 Rexlion
1599 bf125
1600 bf125
1601 Esociform
1602 marknate24
