What blade did you EDC today?
Good looking knife! Are those G-10 handles with Carbon Fiber inlays??
What model is it & where did you get it.
TIA …. :slight_smile:
NICE…!!! :sunglasses: :+1:
Thank you :slight_smile:
That’s a Sanrenmu Land 811, the smaller brother of the SRM Land 9104
It comes with two washers per side, after polishing the copper ones it’s nearly as smooth as the big brother with ball bearings
It’s just so much easier to make scales that way, I definitely won’t make another linerless scale for a framelock flipper again
The scale is made from carbon fiber on both of them, on the SRM 811 I used some selfmade blackwood carbon fiber (epoxy 5 or more sheets of cf, saw it in a square angle). I used a base plate of cf to get only the fibers but no woven pattern at the side
SRM 9055
IIRC I got the SRM 811 from Exduct and it was more expensive than any of my knives from the 910+ series :stuck_out_tongue:
(still less than $20)
All in all the size suits me well. The SRM 710 is too small and I hate the tip down only clip, even though it was the first knife I made a scale for
the SRM 910 feels a bit too big for edc but perfect for real work.
@ Adahn
Thank you for the info. :+1:
You made those scales!! :open_mouth: .
Very nice work my friend… impressive actually!! . :beer:
My Land 8103 was awkward to open. It needed more force than normal, in a very particular direction.
Was not just a one-off, most owners at the time said the same, even the stores who sold it!
I don’t know if they improved it in later batches.
Messerunco who sell the Land 812 Ti specfically state “optimal detent, unlike the steel version”. So I guess that means the steel version still sucks !
Well, mine didn’t suck when it was new and I have no problem with the thumb studs like others, so I was positively surprised.
But polishing the metal washers definitely helped, I can shake it to close at the last half.
The metal washer must lay on the blade obviously. And oh, there were some burrs on the outside at the pivot screw.
and sadly even on the inside :frowning:
polished
As it comes it should cost as much as a SRM 710 but on them I never had such issues. Also the 910s I had in hand were all close to perfect.
For a tinkerer like me the 811 is a good knife but it should’ve appeared like 5 years ago already.
Yes, I have many 710s, 910s and other SRM models with no fit & finish issues. 8103 just seemed to be a turkey … at the time a store rep told me they were aware of the problem and it would be revised.
It’s funny, around the same time Sanrenmu were moving towards more ‘premium’ offerings (sometimes $70 or more) and yet they had many quality issues on the 8103/4 - which in my opinion was a little bit overpriced anyway. I guess maybe their attention was elsewhere.
Anyway it is a shame now there are many interesting models which you cannot buy from Gearbest, Fasttech, Exduct etc. You can only buy them from European dealers or a couple of Aliexpress stores with high prices.
Ganzo F759M in ruby red:
What’s the blade on the top left?
Wesn Allman and a Reylight LAN. Titanium all the things lol. :sunglasses:
CIMA M831
https://www.gearbest.com/knives-tools/pp_628419.html?wid=1433363
Ganzo FH41, my new favourite: :slight_smile:
Thank you for your recommendations isti242.
I guess it’s hard to resist Ganzo’s FH41 and FH51. However, I found the Sanrenmu 9165 on your blog and this one seem to be the right thing. Sandvik 12C27 steel, carbon fibre handle and slipjoint with removable lock pin for the price of a tasty steak meal. Moreover, this knife will be conform to Germany‘s (stupid) §42a.
Can anyone help me to pick the right seller? I saw it here for a bit less and customer feedback is quite good.
https://www.aliexpress.com/store/product/SanRenMu-9165-Pocket-Folding-Knife-Fold-12C27-Steel-Rescue-Survival-Tool-Outdoor-Camping-EDC-Mini-Tactical/4665095_32961483497.html
However, this here seems to be the „authentic“ Sanrenmu store but it’s more expensive.
https://www.aliexpress.com/item/Sanrenmu-9165-12C27-Blade-Carbon-fiber-G10-Folding-Knife-Outdoor-Camping-Hunting-Cutting-Survival-Tool-Utility/32955956309.html
I bought from them the aluminum version, they are a good store. Its the genuine item with the box.
You’re welcome! :slight_smile:
I also bought from both sellers without any problem.
How do you like your alu version? Isn’t it slippery?
Blur :smiley:
You already asked me the same question. Yes it is but not too much thanks to the holes. The biggest mistake from this knife is that you can’t unscrew the thumb-stud…
I just needed a good excuse not to order a 2nd one. :smiley:
The thumb stud is looking like the same construction as the one used on the SRM Land 910 series but more resembling to the SRM 710s studs.
That’s a screwed construction :wink: One side is held in a D-shaped hole, the other one is the screw head.
IIRC the one to turn was on the locking side so it won’t unscrew from opening.
You should heat up the lugs and apply some tape onto you pliers. It really sucks to scratch a satinized blade that way.
On others Sanrenmu its easy to remove but not this one... its impossible to remove this garbage. Must be welded or something. So I grind it;
