If you aren’t wowing people with turbo then don’t worry about using a GA. In reality I think the light is capable of pulling 15A per cell like komeko says but in my testing my light is only hitting 10K lumens briefly with a 30Q. So 15A is pretty much the upper limit with a 30Q using this light.
Interesting, the flood optics I got from Hank look different than both of those. They seem to be somewhere in the neighborhood of ~60 degrees?
There were wider ones for sure but I got the narrowest two that would fit 219b LEDs
I did this for science but the results are so similar i’m not sure it’s helpful to anyone. The hotspot appears to be ever so slightly less defined and edge of spill slightly cleaner. I thought the efficiency might go up but it appears to produce more or less the same lumens with both optics. I still think XP-L HI might benefit from this larger LED opening but i’m only going to try 219B.
Datasheet has support for other small-ish die emitters: XPG2/3, 219B/C, Oslon Square, E21A, LH351B
OEM / FP13028_LISA2-M-PIN
Finished up my D18 219B 45K mod:
When is Clemence making a E21A MCPCB for this thing so I can have a floody version?
What does 45K stand for? Do you mean 4500° Kelvin? It can’t be 45 thousand lumen.
yes 4500K
I guess a lot of Nichia fans use their terms like this, I left out the ‘sw’:
Nichia 219B R9080 sw45k
Nice mod, contactcr! That’s a lot of rosy goodness!
Yes, ‘sw45k’ is Nichia-speak for 4500 Kelvin.
It’s part of the emitter’s ‘color rank’ specification.
Here’s a label from one of the last boxes of 219B emitters from Clemence’s group buy nearly a year ago.
I was fortunate enough to stock up then, and I have about six lights using them. I still have some to spare for future projects, but I still get weepy thinking about my favorite LED being discontinued.
I think I’ll turn on my 219B sw45k Emisar D4 to cheer myself up.
There’s very little Nichia data in my head. I can barely remember all the Cree related data. Lol
Has anyone ordered a D18 without LEDs? I am curious about the price.
I would like to put 18x 319A 5000k into it.
First you need to see what replacement optics will fit. The stock ones have such small LED opening almost nothing besides sst fits
Someone got a quote from Hank without leds, I think they posted it in this thread. It wasn’t a big reduction, $10 less I think.
I got my emisar d18vn with the osram white 2 mm… this light is perfect. No green tint at lower mode… I got 14740 lumen @ turn on. Amazing! Throw is 140Kcd.
That must have been a nightmare to reflow
I want to see a beamshot
When I first got the Emisar D18, I didn't have enough high-drain button-top 18650s to test the D18 with, so I used Sanyo NCR18650GA, which fortunately worked on the D18.
I have since then been able to get a few button-top VTC6, and re-tested the D18.
On an uncalibrated lux meter and doing a simple ceiling bounce test (with fully-charged 3x GA and fully-charged 3x button-top VTC6), the button-top VTC6 has higher lux reading.
Below are video beamshots of the D18 (but taken on different nights), using 3x raised-flat-top NCR18650GA, and 3x button-top VTC6
Emisar D18 (custom mixed tint, using 3x Sanyo NCR18650GA medium-drain raised-flat-top 18650)
Emisar D18 (custom mixed-tint version, using 3x Sony VTC6 high-drain button-top 18650)
Anyone know if hank will be releasing these with aux lights or lighted switch?
Yep - Captain Obvious. GA, and even better: Samsung 35E's are a great cell to up the runtime, lower the amps, though the 35E's in my experience do higher amps than the GA's. You could be pushing the GA and 35E cells rather high on the amp draw though which lowers the runtime -- funny how these tradeoff's work.
Check the batt comparator: https://lygte-info.dk/review/batteries2012/Common18650comparator.php
You'll see the GA cell doesn't lose much capacity when drawing 3 amps vs. 10 amps - yes capacity lowers but not a lot.
On 3 cells like the GA on the D18, speculating amps is 15-20 amp total (???), so only 5-7 amps per cell, which should be fine, and of course, only that much on max output.
Even if the draw is closer to 30 amps, still 10 amps per cell is good on short max runs.
hopefully hank will do limited edition of d18.Maybe different material for the host or something.
