Yes sir, and seriously, although there are disadvantages, donāt you guys find it easier to appreciate things, just simple things? I hope so. I know I do.
Remove the metal part of the switch. If thatās still too easy. Remove the nubbinā. Doing this has renewed my relationship with the light. Accidental activation and lockout woes almost divorced us. Thereās hope for happily ever after now.
The waterproofness is not effected by removing the metal switch cover. Also, the nubbin (or substitute) is required on most samples for operation when the metal cover is still installed, but once removed, it is unnecessary.
Yes. It is not as pretty looking without the metal cover, but for me, function comes first every time. Iāve never had a metal switch that Iāve liked. I hoped that the FW3A would change this, but it hasnāt.
Iāll be posting some other pics and solutions for the switch and nubbin substitution for those that care in the mod thread. But thatāll be this evening. Spoiler: replace the nubbin with a piece of 18awg Silicon wire insulation (length of your choice between ~1-2mm) and if available use a tiny tiny (thatās a very specific size lol) o-ring around the nubbin seat in the rubber switch boot. Together these provide a larger, softer contact surface to the diaphragm switch, increasing the required pressure to āclickā and being much more resistant to accidental activation.
Iām even stirring up some thoughts on what to do with this gap between the rubber boot and tailcap apertureā¦ weāll see if that gets anywhere
Yes. But without the nubbin, more central/focused force is needed. My personal light has a substitute (~1/2 height ā flush with the rubber around it) nubbin and to me itās perfect. Removing the metal part naturally recesses the switch. I think it feels great with the chamfer the FW3A has in the tailcap.
WOW, thank you for suggesting removing the metal switch cover guys. This makes the switch waaayyy harder to accidentally press and against my better judgement I think I can safely carry this light without locking it out now.
Its not just that the actuation force is higher now either, the switch with just the rubber boot sits much lower in the tail and is more shrouded from accidental clicks.
With the nubbin removed the switch still works but is even stiffer and that takes it a bit too far in that direction IMO, especially for multi-click actions.
