CRI Babies…
I got a 31, and I admit I’m not as sensitive to tints as some - my wife in particular!
I do appreciate neutrals, and 219B’s are particularly pleasing, but so are MT-G2s and XM-L2 T6-4Cs. Another trait which may be connected is that I’m comparatively unaware of PWM. It has to be pretty slow before I pick up on it visually.
For comparative purposes, I’m over 70 and have had lens replacement cataract surgery on both eyes.
I always score a zero on this test, and I think it’s safe to say I’m pretty obsessed with CRI and tint. I am quite sensitive to poor colour rendering and immediately notice the difference in most settings. I’ve seen lots of people say it makes no difference to them out in nature because all the colours are so similar anyway, but the first time I tried a high CRI light in the woods it was immediately obvious all the shades of brown and green were rendered much better than my CRI 80 Zebralights, and certainly much better than the average CRI 70 LED. All the more so in the browns with a high R9 like the R9080 219B and E21A. Everything outside just looks “dead” to me without high CRI.
I got a 4 age 65 and I have Tritanopia
What I got:
Not bad for someone that trusts his ears far more than his eyes (I’m 4.0 nearsighted on both eyes and a lazy right eye, though thankfully no astigmatism).
I got a 0. I guess I’m a tint freak now. Is that how it works?
I scored 4, age 66
I wear bifocals, have trouble reading street signs, have cataracts and CSR, with essentially no vision in the center 50% of my left eye.
my favorite LED is the N219b 4500k 9080 sw45k, and I dislike green tint with a passion. I dislike my 6500k Optisolis due to the tint above the BBL. I generally dislike 219c LEDs, because I find them too yellow/green.
What color is this dress?
Green and Light Green…maybe yellow green?
Just kidding…. white/gold but it is probably Black and Blue
All the balls are the same color.
Either you ninja-edited this or what display I’m using has a huge impact on that pic. I know there’s a confirmed answer after it went viral but if you didn’t swap pics I can see where the arguments came from over it haha
Yep, depending on what device you view the dress, it can appear blue/black or white/gold.
try scrolling down until only the bottom half of the dress is showing
that was the only way I saw any blue/black in it
and then having seen the blue/black then that’s all I can see
before I only saw white gold in this and other online images
I just got a 4. Age 25
Ah the dress. Brought to you by bad lighting, bad photography, and a monitor with no color calibration. It leaves so much to guess for your brain.
you are bypassing the fundamental conundrum which is not a figment
I’m not sure what you are saying. I was saying your brain interprets the color wrong because of the mix of indoor/outdoor lighting, the fool that got to close with the camera to get any context to the shot, and the tendency of monitors to be setup to exaggerate colors instead of render them correctly. All this assaults your brain’s ability to determine if the dress is in a shadow. Resulting in a failure to adjust your vision to the scene.
and because I initially saw white/gold and now only see blue/black?
under the exact same conditions?
That makes sense, there is conflicting info in the image. After you found out you were wrong, your brain tried again and paid attention to different clues.
wtf is the conflicting info
it is an image much like any other image
can we ever consider an info from the internet other than what it is
