*BLF LT1 Lantern Project) (updated Nov,17,2020)
Put me down for one, thanks
You’re now tied for 4th most lanterns with 6 other people :+1:
I don’t think so. I believe the driver is designed so that brightness stays the same regardless of tint mixing.
I’m amazed at the numbers!
Did any other BLF project gather so much interest before it went on sale?
Are the solder points on the extra 7135’s on one of the power legs, or on the PWM leg from the MCU?
If it’s on a power leg, I’m sure pencil lead won’t work for passing 350mA. It might work for passing the PWM signal, but I’m not sure.
You could probably also try taping a small square of aluminum foil over the jumpers for the extra 7135’s. Just be careful not to let it touch other contacts.
Interested in one with batteries
Mixed tint runs each channel at about half power. Power level is kept approximately constant across the tint range. The intent is to not see a brightness change.
The AMC’s run on full power without PWM at the extreme warm or cool tints.
That sounds right as far as I understand what TK has said before. It sounds like that includes if it is in auto-tint mode:
By the way, you can adjust brightness while in candle mode. I’m not sure if you can adjust tint, or if you would need to turn off candle mode, adjust tint, then start candle mode again.
it went our around 6:30 roughly. Yep that is a double-sided replica of the clock from Grand Central Terminal in NY. :smiley:
I am interested in one without batteries.
Taping down foil or a thin wire would work just for testing out how one likes it. For a permanent solution a solder blob would be in order but I guess conductive epoxy would also do the trick. Personally I would use solder since it’s not that hard to do.
Please put me down for 1 more, for a total of 2.
That actually brings you to 3. I added you anyway since more is better than less :slight_smile:
Please add me for 5 more bringing me to a total of 7.
Thank you. :slight_smile:
I wonder…wouldn’t it make sense to run the candle on the warmest tint regardless of output?
Done
I believe I’m in for 2 right now. Please take me to a total of 5.
I’m on the list for one, please add another one for a total of 2. Thanks!
So are “flat” top NCR18650GA going to work without modification in the LT1? They’re not really flat and do have a slightly raised center positive contact unlike most other flat tops though not to the magnitude of a button top.
I’m always doing long term testing. After the power outage a few nights back, the test unit after running for 3+ hours on maximum, next day the cells were at 3.89 volts. it took only 5 and half hours of sunlight to fully recharge them with the Eceen charger. Again reinforcing the viability of the LT1 with a good solar charger being an indefinite light source for years off the grid. :smiley:
If the metal contact of the positive end of the battery top sticks out past the insulation of the battery, it will work.
