Mixed tint runs each channel at about half power. Power level is kept approximately constant across the tint range. The intent is to not see a brightness change.
The AMCās run on full power without PWM at the extreme warm or cool tints.
That sounds right as far as I understand what TK has said before. It sounds like that includes if it is in auto-tint mode:
By the way, you can adjust brightness while in candle mode. Iām not sure if you can adjust tint, or if you would need to turn off candle mode, adjust tint, then start candle mode again.
Taping down foil or a thin wire would work just for testing out how one likes it. For a permanent solution a solder blob would be in order but I guess conductive epoxy would also do the trick. Personally I would use solder since itās not that hard to do.
So are āflatā top NCR18650GA going to work without modification in the LT1? Theyāre not really flat and do have a slightly raised center positive contact unlike most other flat tops though not to the magnitude of a button top.
Iām always doing long term testing. After the power outage a few nights back, the test unit after running for 3+ hours on maximum, next day the cells were at 3.89 volts. it took only 5 and half hours of sunlight to fully recharge them with the Eceen charger. Again reinforcing the viability of the LT1 with a good solar charger being an indefinite light source for years off the grid.
