So are “flat” top NCR18650GA going to work without modification in the LT1? They’re not really flat and do have a slightly raised center positive contact unlike most other flat tops though not to the magnitude of a button top.
I’m always doing long term testing. After the power outage a few nights back, the test unit after running for 3+ hours on maximum, next day the cells were at 3.89 volts. it took only 5 and half hours of sunlight to fully recharge them with the Eceen charger. Again reinforcing the viability of the LT1 with a good solar charger being an indefinite light source for years off the grid.
Updates are usually only published Sunday evenings. This past Monday an update was published because there were 139 additions made that day. You requested 2 lanterns on 8/20 per post #6312 which I saw and so added you into my database. Be at peace……your requests have been captured
We are actually looking to see if its possible for this group buy if Sofirn can swing it. (Green, gold sand, and clear/white anodized in addition to the black anodized.
The interest list is updated typically the same day as posts are made. The interest lists on SigShooter’s computer in NorCal. Typically on Sunday nights he shares the updates to the interest list, since the last time he posted it in this thread, on Sunday evenings. I think this week he did Monday also, since so many people expressed interest on Monday. Check back Monday morning and I’ll bet you’ll find your name posted in updates near the end of the thread. Then DBSAR will update the OP sometime following that.
Due to the volume of adds here is another update to the interest list. The files linked in post #1 have also been updated so please verify that your name is correctly spelled if you haven’t already done so, and of course that you are in the files
Don’t forget to have PM enabled in your profile (the default setting) since you won’t get a PM if it’s been disabled.
