Anyone have a datasheet on the S2WP. I just got Nightwatch sample from Neal with it, but can’t find anything about it. Love the consistency of the tint though. No rainbows here.
But why do we need it? The SBT-90 Gen2 has a single die of basically the same size (=> no donut hole) and is really not too expensive for what it does. The luminance should also be similar. I guess a 2S2P or even 4S configuration of the Osram LED might make sense in some applications, the drivers are smaller and cheaper this way.
I would be VERY interested into testing the NI40 Stalker with Osram's Stage S2WP LED but I feel somehow reluctant buying one as a friend of mine lately got a sample of the NI40 with really poor build quality (fingerprints on reflector, crooked tailcap spring, missing thermal compound, razor-sharp threads with bad machining).
Can you please find out some more information about this special S2WP version?
What driver is being used with the S2WP?
What UI/firmware is being used to select different colors/brightness levels?
What current is applied to the LED?
Any beamshots yet to see how the beam will look like?
Last but not least....any chance for a nice discount? ;-)
Oh, I wish I know the answers to some of your concerns.
Beamshots to be taken when weather permits.
As for a discount, I will ask Neal and post it here if ever there will be one.
All right, just to make double-sure.
So the XHP50.2 De-domed means it’s a blue led without dome? If so, can you please confirm the performance numbers in the table are correct?
I’m getting 20A on turbo, which is activated with a double half-press, but it’s a bit too hard to do as the off timer is very picky about the speed. The firmware needs tweaking for sure. Most of the time a double click just advances the normal mode cycle. I didn’t even realize there’s a turbo mode before. In addition the half presses need to be kind of deep but not too deep not to activate the mechanical switch, otherwise the light flickers between modes and since some steps are very small, it’s difficult to tell if you’ve managed to even advance to the next mode.
There doesn’t seem to be any PWM on any mode. Practically no ripple at all either. But there’s a strange bug I haven’t encountered before. After first activating turbo and then coming back to a normal mode, any of them, PWM is suddenly there at 15kHz. But it’s gone after advancing to the next mode.
Here’s what one of the mid modes look normally
Here’s when I activate turbo with a double click and come back
I just purchased a 50.2 6500k. Why are the sites pictures showing a smo reflector,but In this thread, it’s op reflector?
I wanted to get a smo. And what’s the diff between the xhp 50.2 blue?
