I do have a hot air gun but for reflow purposes I prefer to use my stove. I take my time, a good reflow matters.
I've reflown some really big stuff in my kitchen, 12" × 2" 5730 aluminium bases, with the help of some big & flat cooking dish (using a llanda, a cooking dish usually employed to bake a sponge cake dessert).
By the way, how do these hot plates take so long to reach reflow temp? 15 minutes? C'mon! 5 - 6 minutes is enough, imho.
I’ve seen MCPCBs look like that before, but you’ve really got to get them HOT HOT to do that. Mos often I see that when I am trying to remove an old MCPCB from a heat sink and don’t intend to save it. I’ve left mcpcbs in my skillet and forgot about them coming back like 20 minutes later and not had them look that bad. Boards with white mask will turn a bit dingy from being hot too long sometimes.
Seems that there’s no clean soldering paste with or without lead. Does it make much of a difference considering the small amount? Also, is there much of a need for flux here, or only with cleaning off an MCPCB after removing an emitter?
When using a heat gun, I assume you’ve got an alligator clip holding the MCPCB and you’re blasting it from below. Do you start at a low temp for a min or so, then gradually increase heat until reflow occurs?
My UYue looked dirty/used and had minor scatches on the surface and I was afraid it was DOA because it initially emitted fumes at 170c+ but it quit doing that and functions just fine after I let it cool and ran it again. The biggest struggle was trying to line up and resolder the tiny wires back on the mcpcb of the E03.
Mark I ordered a stencil withe the reduced pad size for my 3x XPL 32mm board frames, I am eager to try this. I have been using a stencil for my XML boards in the same size, but sometimes I think the paste does not spread perfectly in the large center pad. It seems like maybe running a thin strip of stencil metal right through the center long ways might fix it, but I am wondering if that would reduce the solder too much… What you would recommended for XML size tipples?
I begin to try this method with cheaps single LB Leds.
Also solder and desolder the same many times and worked good
Never have burned one or damaged.
Only few second with thin flame under pad without toast Led for minutes.
Stop immediately when soldering start melting,small tap on top to remove excess solder with cotton fiock
But maybe this isn’t orthodox way for multi emitter pads
I use to use a lighter to do my reflows back when reflowing became a modding thing.
A flame is not the best method for reflowing but with a enough practice and a understanding of the heating process that’s laid out in most reflowing datasheets it can work decently. Even using a hot air station requires a little practice of the heat setting and just how far away to hold the tip from the mcpcb. When reflow paste begans to start heating up it out gases, this can sometimes cause components to jump or slide around out of placement. Its like a tiny bubble bursting under the led or components causing them to move. Its best to heat slowly with a slightly increasing temp letting the gases vaporize instead of bubbling. As the heat climbs slowly to the melting point the led should jump into its pads location. I tap the top of the led with a sharpie to release excess solder as vestureofblood does (thanks for the tip by the way). A sharpie has a cupped bottom to it.
As a practice test you can use a old mcpcb and apply some solder paste. Slowly heating with your source watching to see how it reacts. Different solder paste will react differently so I find it best to test and see how it does first before using it. This should help to figure out if your heating to quickly or to slowly or if you need to adjust the temp. You want the temp to just reach melting point and plateau until the led is seated, then remove the heat.
Heat slowly, slowly reach melting point and when its reflowed remove the heat and blow on it or let it cool on its on. I think its better to blow on the mcpcb a little getting the temp down quicker than just letting it set. Less time the led see’s under the high temps the better. Just holding a flame under the mcpcb until it melts is quite harse as Barkuti pointed out. By the time the solder melts you have already over shot the melting point quite a bit.
I do realize that not everyone has or needs a hotplate or a reflow oven even though that’s the best methods. The frying pan method is good also as long as your trying to follow to the datasheets suggestions. I think it’s more important in the stragey your heating for reflow than the actual heat source. The difference being some heat sources make it easier with less guess work. Just my opinion I guess.
thanks all for suggestions,
For occasional jobs, work with what little you have,
increase creativy and can get good results with the experience.
I apply wire SN60/40PB on mbpcb layers with Iron
for what I read less you put better is.
Tin alloys have average thermal transfert,is that critical?
I would try use Indium for high power Leds.
Everyone does it his/her own way. Personally I use my induction stove with a frying pan, aiding myself with an infrared thermometer to monitor temperature. I use moderate, controlled stove power to emulate the pre-heating, soaking and etc. phases of reflow soldering, and take my time once the solder paste melts to achieve well centered and as flat as possible led (or whatever components) reflows, while peeking with my IR gun once in a while to make sure the temperature is right. Due to habit, though, I can feel the temperature in my bare hands while using toothpic and cotton swab and intutively know if it is right (toothpic and cotton swab :-D are my main reflow tools).
I’ve had good luck with an electric griddle that is no longer used in my house. It heats up slowly, gets hot enough to reflow, and cools down slowly. And as a additional benefit, it smells like pancakes when reflowing!
