You do realize this light is larger than you might think. As a 26650 light it’s going to be along the lines of a Klarus G20 or a Thrunight TC20.
Well I have asking for a size comparision between E07 and the mf01 mini… so yes… I am not 100% sure of the size difference
I’d rather not hunt through all 27 pages for the answer. But can anyone tell me what the UI will be on this light? Everything about this light is nearly perfect for what I want (except maybe it could have better emitters). But if it doesn’t have Narsilm, Anduril, or a UI with ramping, I won’t buy it…
It has Anduril.
Thank you.
It’s right in the thread title.
To be clear, the doesn’t have a tripod mount, yeah?
There’s a tripod mount screw listed in the details…
No, there is the button and the USB charging port is on the opposite side.
They apparently copied some of the info from the bigger MF01S light.
Ordered 4000K Sand + Diffuser. Thanks
it has ANDÚRIL ui…
Tom White:I’d rather not hunt through all 27 pages for the answer.
Thanks, can’t believe I missed that!
I just ordered 2 with the BOGO code. One in 5000k, and one in 6500k, since not a big fan of the warmer tints.
I imagine on turbo these flashlights will get hotter much faster than an Emisar D4, am I correct?
says on BG it ships end of month, is this true or are they shipping sooner ?
I was also curious about when these might be shipped. No pressure, just hoping to get a ballpark idea.
Ordered silver with diffuser will order another one tonight once again thanks freeme
Thank you SKY89... oops.. it's SKY69
Sorry if this has already been asked/answered… is there any info on the output in moonlight mode?
JasonWW: Tom White:I’d rather not hunt through all 27 pages for the answer.
When we’re you able to get that bogo code work? I’ve tried at the beginning of a new day, and still reached its max use
Same here on the BOGO code. There are only 5 available per day so i guess I’m just too slow.
Ordered one silver 5000k + diffuser. Thank you
I don’t think so. It’s 3 extra emitters, but it’s also a bigger light with more mass. They probably heat up similarly fast. It’s still early and we haven’t tested it yet. It will also depend on the battery that’s used.
