a little more progress today made 3 plates for the base
this machine rocks for drilling !
the trial unit still going strong on the front of the car, no driver issues.
You are getting lazy in your old age. What happened to a bit of blue, scriber and centre punch?
cant find the scriber or the centre punch .
cut the lenses
these are Lexan apparently tougher, but acrylic is more scratch resistant.
can allways make more if needed.
started on the pockets for the led’s/reflectors
next pass is with a ball mill then a skim for the leds
Looking good LTP. When your not working I’ll drop in for a look.
ok
first pocket for leds
about 1 1/2 hours each.
Had a little on of late ,have also upgraded the computer on the machine,
todays effort the other 2 pockets.
some machine vids hop they work
so will need a skim in the bottom of the pockets for final height/depth.
Nearly there
thought id engrave it
pile of parts
and some black paint ,lightbars are always black
assembly to come
Mtolya’s drivers, right ?
Yes, these ones
Did you use primer under the paint?
I tried painting a light but the paint doesn’t stick good. The primer helps but its still not as good as anodizing.
just engine enamel ,guess I will se how it goes.
have you tried the bake on exhaust ceramic paint evdsg
Nah i haven’t but its on my list of things to do. I am on an Aussie EDC page on Facebook and some people swear by cerakote. There was an older thread on here talking about it.
I am not sure what abuse the light bar will see, but i am wondering if things like sand or tiny rocks hitting it will be an issue at higher speeds?
Where as my painted light was used as an EDC on my keyring so it was well abused.
You are right .I am thinking paint jobs will come with lense replacement.2 of the lenses are lexan 1 is acrylic. I am told acrylic is more scratch resistant.lexan stronger.so will see how it all goes.its all a learning curve all be it a expensive one.i think I’m well over the $400 au mark.makes rmm’s bars cost effective
If you add time in.
Looking forward to seeing the final product.
Do you have another light bar to compare the beam with ?
Only a ebay/osram thing. which draws about 9amps.this should draw over 30amps.
A bit of a tease,
mounted the leds and wired the centre section
as thought each bank of 4 leds draw 11.2amps.
this drops if the car is turned off ,
Was that running only the bank you were testing or running all three and testing one?
just one bank of 4leds. haven’t finished wiring the rest yet.
Aah, I see. Just wondering if the auto electrics can maintain that current for all three ? I don’t know much about it ???
my plan is to wire the Centre section on one relay,And the outside two on another relay ,most relays can handle 30a.
so I can run 4,8 or 12 leds at once, depending on need
.will probably check out Jay car tomorrow for a switch etc.
