For the newbies like me:
The FIRST click on lock is the floor setting on RAMP.
The SECOND click on lock is the floor setting on STEP.
For example, for the first click to be moonlight and the second to be Turbo:
From ON, click 4 times
When you get the pulsing light click one time
After the flash, on the pulsing light click as many times as you want to subtract from turbo for the high ceiling - I think there are 150 clicks total, so 10 clicks would be 10% less (or whatever).
After that is done, click to turn the light off, then click to turn back on.
Now Click three times, that gets you into STEP mode.
Click four times. That gets you into low ramp.
At the pulsing light, click 150 times. That sets the floor at Turbo
After the flash, click one time on the pulsing light. that sets the Ceiling at Turbo –1
After the flash, click as many times as you want to set the number of steps. For this example just click once, there will be no steps.
Now turn off and click 4 times. You are locked. First click will be moon mode.Second click will be Turbo.
This is just an illustration. Real world, when you are in the setup for STEPS, click as many times as you want for brightness, suggest maybe 20 clicks just to see what it does. On the next pulse set the ceiling. Remember, that is MINUS clicks, it starts at full or turbo and works down, try 15-20 clicks to start. The third set of pulses sets the number of steps, do as many as you want.
Hope this helps someone. Took me a while to “get” it. I never use stepped mode, so I set the floor fairly high. Now I have a usable light from lock, two clicks gets me to maybe the equivalent of med mode.
