Lumintop FW1A discussion and review
What exactly are those two lights?
The one on the left is a Lumintop EDC05 standard OP reflector, XP-L HD and the one on the right is the Sofirn SP10S on which I've swapped the original OP reflector to the SMO one from the older SP10A revision and it runs a LH351D (reason for the lesser tint shifting)
Both reflectors are the same geometry and they would be interchangeable if it weren't for the deeper cut on the outside on the EDC05 (deeper border on the Sofirn's reflector and deeper cut on the head)
Of course. The primary characteristics of the emitter and optics play the largest role. But I thought the point being made was that, all other things being equal, with SMO vs OP as the only difference, you are disappointed that the FW1A uses OP instead of SMO.
That preference is totally fine; each person looks for different things in a light. The FW1A reflector is a good design though. It works well, aside from one visible ring outside of the spill area. There is also a mild Mach band effect at the outer edge of the spill. But the hotspot is nice and smooth with a fairly decent blended corona around it. And the spill is bright enough to provide some useful wider context without wasting a lot of light. Lumintop did a pretty good job with the FW1A optics.
Those are usually caused by two things:
  • Large square emitters in well-focused small round reflectors (corona petals)
  • Overlapping reflectors like on the SP36 (spill area petals)
If the LED is smaller, or the reflector is bigger, there is less flower petal pattern. Or if the reflector is defocused or blurred slightly, there is less flower petal pattern.
Lots of things can cause rings in the beam. You listed several of those things. There are a lot of ways optics can go wrong. :slight_smile:
However, the sharp edges from precise optics can also be considered rings. Extremely well-focused reflectors tend to have mach bands between different parts of the beam, and that effect can be undesirable.
Apologies for going on a tangent. I find this stuff kind of fascinating. Here’s a visual summary of what a Mach band is:
In the graph you created for an egg yolk beam, it looks like the brightness is highest at the edges of the hotspot and slightly lower in the middle… like turning a soda can upside-down so the the concave bottom is on top. That mild donut hole effect is commonly perceived with well-focused smooth reflectors.
But in general it’s not actually dimmer in the middle. It’s an optical illusion caused by the mach band effect. In order to look flat like a plateau, the hotspot needs to be brighter in the middle and have somewhat more rounded edges. A truly flat center looks like it’s less bright in the middle.
As an example, here is a rendering of a beam with a perfectly flat hotspot and a perfectly flat spill area, with linear transitions between:
It appears to have a mild donut hole effect, but it is only an illusion.
Of course, virtually no lights actually achieve this degree of flatness. But the effect is still present and somewhat visible even with the edges rounded off a bit. For a beam whose hotspot appears flat, it’ll be shaped more like a round hill or a slice from the top of a sphere.
Yawn
Neat stuff toykeeper. I didn’t know about the Mach band effect. I have seen that before and found it puzzling.
Welcome to our humble thread.
Pull up a saddle, have some tea, make yourself at home.
{ gestures at horses }
Here are the stables…
{ gestures at other horses, which are flickering and vibrating }
{ one horse explodes }
… and here are the unstables. { sigh }
Enjoy your stay!
Those mach bands are quite an interesting effect and pretty much what I've noticed on a few of my lights, that apparently had a slight/slim brighter ring just at the edge of the Hot-Spot. Now, makes sense why..
Hasn't bothered me too much, but I could've done without them (visually perceived), thus a bit of blending between the individual areas, on a much smaller scale compared to their own areas would be welcome.
Not so much so to the extent that an OP reflector would blend them combined with such a small emitter like an XP-L HI - the size of the blended area would give too much of a faded Hot-Spot and no definition.
That mock-up beam pattern drawing, looks pretty close to what I'm always after in a beam pattern - only slightly less bright corona and brighter spill, maybe I'd take even more fade from the corona to the spill.
Basically, I'm still ending up giving as example the right side of my first comparison picture of the two Hot-Spots - that beam pattern really has the near perfect balance of definition, smoothness, Hot-Spot size, etc.
That is as far as my preference goes and the purpose of that light's intended use - that being low powered close to mid distance small EDC.
For this small emitter, the SMO reflector's imperfections are smoothing the beam just enough to be.. "soft" to the eyes, but still carrying enough definition to the beam's elements and keep the Hot-Spot.. "flat".
Just enough to trick out that mach banding effect, but not enough to blend the beam's elements in a complete smooth, undefined blur. I just don't.. "feel" when I'm pointing the light when it's so blurry and faded..
Here's an example of an OP beam and a small emitter that I cannot stand:
Likely close to what a FW1a is looking like currently (maybe a tad bigger Hot-Spot tho.. )
And here would be an example of a beams that I would very much like:
I've probably exaggerated with the size of the Hot-Spot for this comparison, but regardless, this would be a nice SMO beam pattern and would make a good contrast to represent what I like in a beam VS what I dislike..
Cheers!
EDIT:
Just found this YT comparison of 2 lights (Olight S2R Baton II & Baton Pro) where someone with a proper camera took some decent captures of the beam patterns of these two lights and one extra (Klarus E1)
Ok, the 2 Olights are TIR optics, but basically, as far as the Hot-Spot goes, there shouldn't be any relevant difference between reflector and TIR. One of them would be the equivalent of a SMO, the other an OP.
The SMO counterpart is just a plain smooth TIR, while the OP counterpart is a frosted TIR, both of them on top of a big die XM-L2. The E1 it's a weird diamond pattern textured TIR on top of a small die XP-L HI
So.. first, worst of them all, the Klarus E1 - small die emitter (XP-L HI) and textured (diamond texture) optic - small Hot-Spot with loads of blending in comparison to it's area/size/diameter:
Next, comes the second worst, the Baton Pro - large die emitter (XP-L2) and frosted optics - reasonably large Hot-Spot, but still too much fading/blending of the Hot-Spot in relation to it's size/surface:
And finally, best of them all by far, the S2R Baton II - the SMO counterpart - large die emitter (XP-L2) and SMO TIR - large, defined, homogeneous Hot-Spot with just the right amount of smoothing on the edges:
Now this.. ^ ^ this is a beam that I really like
Im enjoying your conversation about beam clarity, diffusion, profile shape, donuts and beamrings too. All good and very interesting stuff.
For reference, can someone show me a picture of some Actual FW1a beams please?
Have you seen this?
A few lights for comparison…
(pics taken at a bit of an angle to avoid direct reflections, sorry for the skewed perspective)
FW3A XP-L HI: ~4 cd/lm
FW1A XP-L HD: ~11 cd/lm
Emisar D4S XP-L HI: ~10 cd/lm
Emisar D1 XP-L HI: ~33 cd/lm
FW1A HD (left) vs FW3A HI (right):
yes, but that only pointed out the difference between a triple and a single
it does a good job, but not they type of beamshot I was hoping for
this is the type of beamshot I wanted to see, I consider this an excellent beam btw, for single LED reflector application
ToyKeeper, thank you, I chopped your last pic to show 80T, so we can discuss the actual specific beam of the FW1a in a visual:
so, is that FW1a beam too fuzzy for you @80T?
it looks pretty good to me, I like the smooth gradient (but I have no direct personal experience, and pics only tell so much)
Most pictures will have the hotspot come out slightly more defined than they appear to your own eyes in my experience.
That’s for sure , I wanted to post some beam shots and quickly realized an IPad camera is not representative of what the eye sees. Not even close.
I don't have a good setup for taking pictures of a flashlight beam and likely not many of us around here do, thus, as someone previously mentioned, it's easy to get mislead by a a beam shot picture.
For ex. here's my S2+ XP-G2 / SMO reflector - tried my best to get a decent shot, but really don't know how to get a proper brightness balance..
It's looking overexposed, but overall, it does catch the basic pattern of the beam (well, the Hot-Spot and the Corona in this crop as I don't have a big enough white wall available)
Note how dim the Corona is in comparison to the defined Hot-Spot, even with this exposure.. they're both dimmer irl, but the ratio between them seems about right as when they are dimmer.
As for the beam shot that you've posted above - It's still looking overexposed, so I can't really tell. The Hot-Spot alone, as is, is looking quite decent, the Corona is looking too bright, and with too much blending in the Hot-Spot, but that might just be the exposure.. So, all in all, for a semi thrower, the Hot-Spot looks about right and maybe in person, the rest of the beam might be looking just fine, or it could be looking worse and the camera is.. "compensating"..
The pic from TK's FW1A looks a bit harder to interpret, but I'd say it's the same case of overexposure and the Hot-Spot is even more faded than the camera is showing, pretty much in line with what my previous mock-up was looking, the one that I've said it might be looking close to what the FW1A does.
Anyways, my preference still is in simple terms, a big "flat" Hot-Spot with dim corona, and low blending between elements, just enough to look smooth and not eye-popping.. I don't know how to put it any other way.
Looking at the popularity of smaller lights to use TIRs and textured reflectors I think you might be in the minority for wanting a very defined beam in a light this size.
I would say its probably much easier to make a beam smooth and artifact free than it is to have very sharp cutoffs between beam elements without having ugly artifacts (like even some throwers still do, with the trade-off being 100% worth it there IMO).
I don't know about size and the type of reflector, but my SP10S is a 14500 (granted, the reflector was replaced from the earlier revision, the SP10A, but that's basically the same light, just different driver)
The other light is a Convoy S2+ which I've swapped in an XP-G2 and this is pretty much the same size reflector as the FW1A, I think even smaller.
So definitely a small light with no bells and whistles can have a very nice beam, just with a small enough emitter to accommodate the reflector's angle. Thing is, everybody is aiming for the highest lumen count and the highest candela rating. This causes some issues - the emitter choice gets bigger in size, and the reflector angle gets low, thus the emitter's die area heavily overflows the reflector's intended angle of reflection going way into what should be the corona and spill areas, basically throwing out the window the intended beam pattern and beam elements ratios - So how to fix it ? Simply.. adding blur into the mix - add an OP reflector and that's it.
My S2+ with its original emitter (XP-L2) was indeed brighter, but with the SMO reflector the beam was bland and undefined - swapping it to the XP-G2 made the beam pattern nearly perfect and defined with all the 3 beam elements in their own place and with their proper ratio, not overlapping and not blending more than they should've, just enough not to be an eye-popping sharp artifacting mess. And the slightest imperfections in the SMO reflector are enough to do just that.
@80T, if you really want maximum throw, then get yourself an SMO reflector light with a dedomed SST-20.
You’ll see how intense the beam can be.
I never implied that I wanted throw, "big flat defined Hot-Spot and a dim Corona" have nothing to do with throw, just with the.. beam's shape/look.
For throwing I have a couple decent throwers, from de-domed XP-E2's to XHP-35's - all of them having decent defined but not sharp beam patterns - actually on the contrary, they have smooth enough beam patterns.
Maybe the GT-Mini (XP-L HI) and the Manker U23 (XHP-35) have the egg-yolk effect in the Hot-Spot, but that is due to the tint-shifting, not because of the beam pattern.
So, in a small EDC flashlight like this, I'm not looking for either throw or power, especially with the small thermal mass.. What I'm looking for is a nice beam pattern with a nice big flat useful Hot-Spot for short distances.
This way, it would be just perfect for EDC: Low power - low temps, long run-times, low to no step-down, good close range useful quality beam, very nice UI and good size for EDC and holding it in hand.
Cheers!
Sorry for the double post, but just to keep things separated..
So.. First things first, obviously I do like this light as it's potentially covering lots of my requirements for a compact enough EDC, thus, I might bite the bullet sooner or later.. so that's out of the way.
Next, I would want to know some info about the reflector and the driver and maybe make a few small suggestions, just to know how moddable this host would be to better fit my own preferences.
What is the reflector size for the FW1A - Diameter, Depth and less important emitter opening Diameter ? Is there any compatible size common reflector that could be used as a drop-in replacement (S2/S2+ for ex.) ?
How is the power stage driven ? I know there's a 1 + 7 + FET setup, but I'm not really sure how that works.. I'll take it that the 7135's are driven in high freq. PWM and the FET in voltage ?
And how and why is there a 1 + 7 setup for the 7153's ? What would be the difference to.. say, 8 + FET or 1 + FET ? Also, how is the MCU driving them ? each channel gets a PIN from the MCU to drive it ?
Like in 2 PWM pins from the MCU are driving the 1 * 7135 and the 8 * 7135's and a 3rd pin is driving the FET ? In this case, could the driver be modded to accommodate a less powerful emitter like an XP-G2 ?
So, with only 4 * 7135's and no FET, the MCU would only drive the 4 * 7135's and that would leave 2 available pins for controlling a bi-color LED (Red/Green) as a battery status indicator while the light is "On" ?
What I'm thinking is having the reflector replaced, remove the FET and few 7135's, leaving only 3 to 5 of them depending on the emitter, swap the emitter to an XP-G2 or an LH351D or a Nichia 119D/219D, or something nice, then drill a small, plain round hole on the side about driver level to accommodate a small SMD bi-color LED that will be used as a battery indicator and use the 2 MCU pins that are remaining from the FET and one of the 7135 channels to drive that small battery indicator LED. All of the above if possible ofc.. :)
Another thing I've noticed, was a tactical ring accessory for the FWXX lights and it's looking nice, only I would take a Nitecore style one over it because it would make for a better anti-roll design.
Ex. of a Nitecore Tactical Ring:
Very nice anti-roll design, in comparison to the current offe.. ring:
Which is nice and slim and good looking, but not really looking like it's serving too much practical purpose. I get that the pocket clip would be the actual anti-rolling element, but I can still see a bit more.. "tabbed" ring would do even better.
Besides this tactical ring, I would also add another two optional rubber elements/accessories (color options maybe ?) to the head and tail of the light, just to add to the anti-roll design for one, add some bezel cutouts and also protect the light from drops and scratches, something along the lines of this light, but ofc. slimmer and removable:
Yay!..
Yeah, that’s kind of the opposite of what I usually want. I typically want the beam to be a smooth slope from the center of the hotspot all the way to the outer edge of the beam, 180 degrees wide. Brightest at the center, of course, and different curve shapes between the center and the edge to allow for both throwy and floody lights… but ideally no flat sections at all.
If I point a light forward to illuminate my path, I ideally want it to light up the whole path to approximately the same lux. That means the beam is brightest at the center and then fades smoothly out to the very edge. At least, that’s how the beam looks when pointed at a wall. But when pointed forward into the distance along flat ground, the result is to illuminate everything to the same level.
A beam with a big flat hotspot is better for pointing at a wall, to illuminate the entire wall to a single brightness. Or really, any time the light is pointed at things which are all the same distance away from the light, a flat beam makes sense. I keep a couple lights like that around… I just don’t use them much because I don’t often encounter situations where it is needed.
