Hi Fin:
I only tried these 2, but both of the 30W and 60W solar panels get this message: “This coupon has expired” and do not work.
Hi Fin:
Still new. On the ones that say ask me do I just send a pm?
Yes, just send me your question in PM
Hi Fin, would like to get current codes on 60W Solar panel. I tried the 20w, the 30w and the 60W you list on page 1 and they are all expired. Thanks
Be aware that 60W panel has no direct USB output and this picture is misleading.
You would need an adapter to connect MC4 cables with the USB output.
Doh! Thank you, that’s troublesome although I’m going to hook it directly to a Lipo battery backup with MC4 cable connections so I should be good? Do you happen to have a link to an adapter that would work?
Couldn’t find one tbh and was seriously considering making an adapter by myself from parts:
1FT 2.5mm2 MC4 Connector and DC Power Cable 5.5mm x 2.1mm Female Jack
Fortunately Banggood sent missing adapter (just after 3 chats with their customer service)
Whoa when did they release the sand color FW3A?
release just getting ready )))
ATTENTION!
Procedure for using coupons has been changed!
1. Select the product(s) and put it in the cart.
2. Go to the cart and click "Proceed to Checkout":
3. Select the checkbox "Clip coupons" at the bottom of the page:
4. Enter the coupon code, click "Apply" and check the discount:
5. Go to the payment process
Hi Fin,
Code for Lumintop EDC18 does not work for me. Updates?
Thanks!
Keepitsharp
Coupon will work after the end of promosale
coupon for Xiaomi 2C 20000mAh don´t work.
